Ford Ranger III
This topic is a continuation of Topic 1165....
Ford Frontier II. Please continue these
discussions here. Thanks!
Front Porch Philosopher
It is very clear that it says NOW. Even the author disputes that it is better. I agree with you that plastics are preferable in some applications but I do not believe that in this instance Ford is driven by 'better' but by manufacturing cost. In paragraph 10, it states "Japanese and German auto manufacturers design parts with the life of the vehicle in mind, not the life of the warranty." I am sure it cost them money to lure me to their products, but IMHO Ford have failed to sustain their effort with tangible quality product and responsive franchised dealer service. If you are comfortable and satisfied with their product and services, more power to you. For myself, it is difficult to give second chances when Ford have not demonstrated the ability to provide a quality product, at least during the factory warranty phase. It is just a consumer opinion, I am sure your understanding of plastics is remarkable, but you do not have to brag about your knowledge with plastics, I could care less. I hope you are receiving a fat check from Ford Motor Company for vigorously defending their manufacturing judgment. Ford do not have any noble gesture other than lining their pockets so you can happily write them checks after checks.
That is, if you do not eventually sue or if they do not face another class action suit because of a defective product (1999 Mustang Cobra). Have you driven OVER a Ford lately?
The Ford 4.0 and 3.0 60 degree V6 engines are a German engineered engine.
Oops.
Do not forget to bring a camera. When we go 4 wheeling up Medano will get some nice shots. Perhaps we will swap cameras. I would choose ASA 400 film as the light is sometimes low due to tree cover.
Against the advice of the office know-it-all, I just bought my new 4x2 Supercab 3.0 yesterday. It's an automatic with power pkg and cruise/tilt. Drove it 300 miles to visit my folks (over rolling north Georgia hills) and got 21.6 mpg. Already it looks like a good choice. It's a bit slower than my 97 Civic, but it cruises well and really seems to run better the faster I push it. My back didn't even hurt afterward.
I had to back-order an under-the-rail liner from the dealer (as part of the deal, btw) since they usually do over-the-rail only. I'll end up installing either a cap or a hard tonneau cover within a few months.
Thanks to everyone for your comments on the 3.0 engine--I'm looking forward to a couple hundred thousand miles on this one! And no, mine doesn't appear to have a plastic intake manifold--it looks like anodized aluminum to this (untrained) eye.
Stephen
1. I have noticed that ~3 to 3.5rpm is the powerband for the 3.0L. I can get sufficient power when passing on single lane highways when I run 3rd gear up to ~4 to 4.5rpm. Will that hurt my engine, even if it is only for a few moments?
1. When my windshield wipers are on, my engine really loses power. Does this happen to all 3.0L or is my engine faulty?
2. The safety-belt alarm is driving me nuts! My dealer says that it can't be disconnected....Is he telling the truth?
Stephen
Top-end wear (valves, valve guides, camshaft bearings) would be the major long-term concern, and as long as your oil passages are reasonably clean (from regular oil changes every 3000-5000 miles) there shouldn't be any real danger (assuming the engine is put together properly to begin with. . .)
Stephen
Other than that, it could be that there's some sort of electrical problem that causes the alternator to run full-time when the wipers are on--maybe a faulty voltage regulator???
Stephen
Derek
The fluid was BLACK, not brown, or red, but black. It was very thin in consistency, almost watery and had a funny odor. Also there were a lot of metal filings on the magnetic drain plug.
The fluid in the transfer case was nice and red.
Anway I put new valvoline ATF in both the tranny and transfer case.
Any ideas as to why the fluid was BLACK ??? The trans has always shifted fine and is very quiet. The only thing that has me a bit concerned is why was the fluid so BLACK.
It was so dirty and black that I am going to change the fluid out to sort of flush it again soon. Is there any better fluid that I could be using ???
I recently bought a new 1999 Ranger Extend cab, 4x4 "Off Road" package last year. I really love the truck and its convenient 4 doors, but have heard what I think is a disturbing noise. When going from Park to Reverse, or while in Drive and shift to Reverse, a loud clunk noise is coming from what I think is the rear axle area. Has anyone else out there had this problem? I only have 7k on the 4.0L, and don't have too much faith in our "local" dealership, and wanted some input from you savvy Ford owners..
Thanks..
MERCON III AUTOMATIC TRANSMISSION FLUID
Make sure you do not use MERCON IV, it has to be MERCON III.
I do not know if the 3.0 tranny is the same but seriously you need to check. Because if you put the wrong oil in your tranny, it will ruin it.
Well black would indicate, I think, that it was overheated at one time.
Do you have the limited slip differential, the 4.10 rear end? Perhaps that is a comon noise.
You might try posting over here: http://www.homestead.com/therangerstation/index.html
Go to the 4X4 off-road section and just post the question, better Ranger sages over there. Plus that is a good place for info.
thanks again..
http://www.wieck.com/public/index.html
Just type Ranger in the search box.
Address is http://www.nhtsa.dot.gov/
Friend of mine had one and as I recall they did replace the rear driveshaft on his 4.0 auto extcab 4x4.
stuff...
I've got a 98 XLT 4.0L V-6 got about 14k on the engine and now it's making a sound like a diesel engine like marbles in a tin can type.
The dealer says it's part of the usual engine noise("that's normal" they say).
Does anyone else have this problem? ... I've read on othersites about the 'wristpin' working loose on the pistons. I'm not sure what to make of this.
Any advice/feedback??
As I recall, the problem that causes the noise is failure of one or more of the wrist pins. Left untreated, it will result in engine failure (thrown connecting rod).
Have you been able to demonstrate the noise to your service manager? It sounds like the folks at your dealership are either misinformed or deliberately lying to you about this being "normal." Since you have only 14k on this engine, you may have some recourse (assuming it is a new factory engine and not rebuilt by a third party).
Keep up the pressure and don't let them BS you.
Stephen
Stephen
1) What is limited slip and do I need it.
2) How much differents does 4 wheel ABS make.
http://www.pickuptruck.com/html/2001/ford/ranger/first_drive.html
I have one question about a part I have been trying to find. When I got my Ranger, they left that little white door guard on my truck. Stupid me did not notice that it was sliding up and down on the door and the door near the edge got scratched up. I would like to get a good door guard/bumper that will slide onto the door edge and the bumper part would hide the scratches that are on the 1/2 inch near the door edge. Does anyone know where I can find these? I've looked in the JC Whitney catalogs and a few others to no avail. The closest I found was one that sticks onto the door, but requires the door to be flat, but the Ranger door has that hump in the middle.
The Merg
Great review of 2001 Ranger! Thanks...
As for gas mileage, my driving is a mix of suburban stop-and-go and rural 55mph roads through the hills of central Georgia. My best tank so far is 21.x mpg, and I've never gotten below 19. Usually it's right around 20 overall. So the mileage listed on the EPA sticker seems like a reasonable estimate to me. Interestingly, it doesn't seem to vary much from tank to tank, regardless of how much stop-and-go vs. how much rural driving.
So the truck you describe is a good compromise between power and economy. Hope you can work things out with the dealer!
Stephen
First tank of gas got 21 MPG, which surprised me in a good way. Half the tank was used driving locally in the city and I also got stopped in a traffic jam for an hour and a half. The other half of the tank was rural state highways, but no interstate. Never went over 60 MPH so far.
I have an XL though, with smaller tires, 215/75/R15, than the XLT. This actually was my preference as smaller tires improve gas mileage. If MPG is a major concern be wary of putting on larger aftermarket tires, as they will degrade your MPG.
Also, if you put a flat hard lid (I do not have as of yet) bed cover on you will also improve highway MPG a mile or two.
Someone mentioned the rear slip. It is great for off road but if you live in northern climates this can be a mixed bag. The slip will improve your traction in snow conditions but it also makes the car unstable in sheer ice conditions (both wheels can simultaneously slip which is likely to put you in a ditch).
PepBoys has an edge guard, runs from the bottom rear corner to the top right on the edge. Sticks on with some type of glue in the guard.
It is flexable, comes clear or colored but only does the edge, maybe 1/8 inch or so. Is in maybe a 36 inch length times 2 for about 4 bucks.
Well finished the front reciever hitch and winch installation. Have my 99 Ranger with a Ramsey REP8000, front mounted reciever. Looks nice but is low, wish it was higer. Will design a carrier for the winch in the bed and install only when needed. The front reciever gives me the advantage of moving the winch from front to back as needed.
