I don't own a odyssey. I have an Acura RL with the PAX and have had no problems. Maybe there's something going on with the compatibility between the van and the tires. I'm looking to get an 08 Odyssey with the PAX and will monitor these threads to see if I get the sense there's really something going on here.
Regarding my comment about tire pressure. I keep my RL PAX tires at 35 rather then the recommended 32. I notice no difference in ride and am trying to avoid this possible issue I've read about. I don't know if it's true about edge wear, but I decided to play it safe and watch my tire pressure more closely then I normally would have.
It may be that the typical Honda minivan buyer has different expectations than an Acura RL buyer.
Tire replacement cost, ride, tire life - these are things a minivan owner or driver is going to look at with less of an "enthusiast" point of view. This is basic family transportation.
The negatives of RFTs seem more tolerable on performance-minded vehicles than they do on mainstream family cars. Even so, the BMW 3-series RFT complaint thread is as big as this one.
Twitter: @Edmunds_Test
I agree, the RL is kind of a "sports" sedan. I've driven the RL with (and without) the PAX tires. It ran MUCH smoother and quieter with the PAX versus the standard Mich MXM4 tires. Also, much more responsive. Like I also said, I've had no extra wear problems, but, am certainly aware of the rumblings on the Odyssey.
That's why when I started thinking about getting a new Odyssey Touring van I started researching these threads. I'm not dismissing it totally but I'm still skeptical.
By the way, I agree, making it optional is a good thing. I hope the rumors are true. There are usually suspension differences to support the pax wheels and tires. Not sure how they can make that a dealer option.
I would assume that this is a factory option and not a dealer-add option due to exactly what you just said regarding the suspension tuning differences between the two. Most people don't "order" these vans as you know and it will be interesting to see how Honda deals with the allocations of PAX and non-PAX equipped Tourings.
If you like your PAX on the RL I would say go for it on the Touring. The TPMS allows you to monitor the exact tire pressure and I watch it closely as well and keep my tires at 38f/39r. No wear or vibration issues and no flats to date. It's all good.
The fact that you had no problems makes me think there's no mechanical "flaw" in the cars suspension causing this problem, OR if it was, it's something they addressed in the later models. As someone mentioned, the rims and tires are heavier then regular tires. Maybe their suspension tuning was flawed in the early years.
What year is your Odyssey?
It's unclear whether R&N will be bundled with PAX or not.
Now for the bad - the tires would not pass inspection in May and had to be replaced at 27,800 miles. The alignment is fine, tires were rotated as specified, and inflations monitored and maintained. I see it this and only this way. The PAX system is marketed as a premium tire system - and matched by a premium cost (up front, repair costs, replacement costs, and being locked into only Michelin tires, etc).
Michelin agreed to pay 35%, so if you do the math, it looks like they actually only expect 40,000 to 45,000 miles. So any way you slice it - the wear on these tires in my opinion is excessive. I was out $860 after only 21 months of operation.
I hope the class action lawsuit provides a way out/better option, but most likely will just benefit the lawyers.
One thing that caught my attention was your statement that Mich only expects the tire to last 45k miles. Are you expecting more? The average tire in America (there's actually a statistic on that) last 45k miles. That means some (like high performance tires) last less and some last longer. Point is, 45k miles is good. I've never gotten that on ANY OEM tire equipped with a new car. In fact, I'm starting to think there's lower grades of rubber they use on OEM tires versus off-the-rack. PAX or no PAX. Bottom line; if I get 45k on these tires I"ll be thrilled.
Second, I'm curious what it was about the tires that failed inspection. Was it uneven wear? worn tread? cut/scalloped treads? A lot of problems are directly attributable to the car (struts, allignment, etc). I'm still trying to compile enough info in my mind to see if its the Ody suspension from the early 05's that was the problem. if that's the case, then I would assume they've "tuned" the suspension system to correct the issue.
Not only that - but finding someone who will actually work on these tires is very hard. Most places that are listed as able will tell you the following:
--equipment is broken (most popular response in my area - metro Philly)
--the person who was certified is no longer employed here
My local Honda dealer is able to perform the work - but charges out rage ious prices ($85 dollars labor per!) while non PAX tires are free. Get Real...
Add all of this up, and the PAX system is not living up to my expectations. I like having them, but will NEVER buy another vehicle with them. Now I know better.
In truth, I doubt that these tires will ever become mainstream to deliver the price margins of scale, because of the labor and materials required to service:
--Special Training
--Special Mounting Equipment (for tire to rim)
--Special jack to stretch the tire to fit over the rim
--Special gel slime kit
--complex procedure to remove and install (first use this machine, then that machine, then air up, then air down, use another machine, air up again, rotate tire, install)
--Time to complete - about 45 minutes off and 45 minutes on
Most people will not pay for the above - I am stuck, and should have been a better informed buyer. I knew it had run flats, but not this type.
If Honda has made changes to the Odyssey to address poor mileage, then they should fix all of the other vehicles - to date I am not aware of any recalls or TSB's to address.
Hmmm, interesting and timely comment. I was responding to a comment about the longevity of Goodyear Assurance TripleTred tires (available typically for less than $500 for a set of four installed, if you shop around) on a different forum this very morning. I put a set of the TripleTreds on both of our vans back in late 2005 and one of them already has nearly 55,000 miles on it since it got new shoes. I think the following picture illustrates quite nicely that these tires will last for their advertised 80,000 mile lifespan.
http://farm2.static.flickr.com/1317/851334723_36fcb731e9_o.jpg
Best Regards,
Shipo
I have a set of Michellin Pilot Z's on my 3000GT Spyder. This is my second pair. Their rated for about 25k miles and cost about $1500 for four. That doesn't mean the tires are crap. There's a trade off of factors with tread wear being just one of them.
I'm not arguing expectations about availability for replacements. I'm right there with everyone on that. It bothers me that Michellin has not done a better job in that category. However, I think expectations on tire tread wear rating may be unrealistic. Again, 45k is pretty good.
Well maybe I should have qualified my comments better. Sorry, my bad. FWIW, I'm very familiar with the whole performance rubber thing as the summer rubber (Michelin Pilots) on my 530i SP were only good for maybe 22,000 miles before they wouldn't pass inspection.
"However, I think expectations on tire tread wear rating may be unrealistic. Again, 45k is pretty good."
Hmmm, the Goodyears on our two vans have a tread wear rating of 80,000 miles, and it looks highly likely that both vans will exceed that by a comfortable margin. The Michelin HydroEdge tires on our neighbors van are rated for 90,000 miles and judging by their first 30,000 miles, those tires will make it the distance as well.
FWIW, I don't think I've ever had a car with All-Season tires that didn't do at least 50,000 miles on a set. While I probably wouldn't complain about 45,000 miles from a set of OEM rubber, I most assuredly wouldn't replace them with the same tires (unless I had to as in the case of PAX).
Best Regards,
Shipo
Honda and Michelin are facing a looming catastrophe and it doesn't help that Michelin's website is still boasting that PAX costs only a small premium over conventional tires. While that may be technically true, it glosses over the high mounting cost and is, IMHO, extremely misleading.
I read a rumor that the 08 Accord may come with a PAX option. May have read that here or on another board.
You make a very insightful observation there. With all the problems the Ody Pax system is causing for Honda, there could only be one reason for applying them to the Accord.
By the way, according to Michelin customer service, they are only promising 40k out of the Ody Pax tires, not 45k. But longevity isn't the only issue with Pax (neither is cost). One must still consider the fact that IF a PAX tire fails outside of a major metro area, you are probably going to be stuck for days. PAX equipped and trained retailers are few and far between...
I subscribe to the argument that there may have been a problem with the suspension tuning on the early Ody's that tore up these heavy pax tires. It's a Honda Ody problem. It's not some inherent flaw with the PAX tires. In fact, I suspect Honda probably resolved all this with the 06 Ody (certainly the 07). I haven't heard any large number of issues about premature wear with 07 owners. I'm sure it will be just fine with the Accord since Honda probably learned their lesson on the poor 05 Ody buyers.
Having said that, I totally agree (as a PAX owner), about the other issues that IS Michelin's fault. I am not happy that Michelin hasn't done more to get support available for these tires. For example, there isn't ONE single Michelin tire shop within 200 miles of me that sells or services PAX tires. WHAT? It's there system! They are letting market forces drive the rollout of this product. Instead, they should have done more to finance and force out the coverage for repairs and service.
And you're ever so right about the lack of service. According to Michelin's website, there are NO shops capable of servicing PAX in metro Columbus (population 1.4 million) except for Honda stores.
When I bought the van, the dealer specifically pointed out the safety features and "peace of mind". He also emphasized that you got all these features at a cost of only 10-15% above regular tires. He failed to mention the lack of available service centers, shorter tread life, and real-world replacement cost at least twice as high as standard tires.
Shipo made a good point earlier with regards to enthusiast drivers versus van drivers. In addition to my Ody, I have an 04 BMW 330 Convertible. I didn't complain a bit when I had to replace the tires at 22k miles--I expected shorter tread life. Even then, a new set of the latest BFG performance tires cost less than half the dealer's quote on a new set of Pax tires.
There's definitely something wrong here...
All I can say is that when i read all this stuff I get a sense there's two types of complaints here;
The first group of complaints is due to unrealistic expectations e.g. People are complaining they only got 40k miles on their PAX tires. Well, that's about average for a good quality tire. High performance tires average about 25k, while "plastic" low grade tires can get you 60k, 70k, or more. However, there's a trade off with performance, traction, etc. when you harden the compounds that make the tire wear slower. Again, 40k is about average in the overall range of tires. Which means these tires are probably about in the middle for handling and performance.
Hoewver, the other group of complaints has my attention. People reporting getting 10k on their tires. ASlthough that happens all the time due to poor maintenance, I admit the frequency of complaints seems high. I agree something else must be going on.
However, all this isn't rocket science. It can only be a couple things. Either the tire system is truly defective or the suspension system on the Ody is not tuned properly to work with these much heavier tires. Given the fact that these tires seem to work fine on other cars, I'm left thinking it's the second. AND, if it's the second, I have to believe Honda addressed it and fixed the suspension by now. By the way, just because Honda didn't "announce" any changes doesn't mean they didn't tweak things.
I'd love to see a real aggregation of data showing premature wear based on year of Odyssey. if the problem is not going away, I agree, avoid these tires on the Ody. It's probably a problem that can't be "tweaked" away. However, don't let it leave a bad taste in your mouth about the PAX. That would be a mistake.
The sense that I get from having following the debate here and on the Ody club website for a couple of years is that premature wear is strongly related to how much in-town driving one does.
And my personal experience has been the same. My tires are still ok at 32K (most highway miles). A co-worker was his third set by 40K (mostly in-town miles).
If I was buying now, yes, I'd do it again, principally because prices are finally coming down and PAX mounting machines are multiplying.
To the best of my knowledge, no Honda dealer within 50 miles of my home has the PAX gear. For example, if one were to lose a PAX tire between El Paso and Fort Worth (about 600 miles), he'd be out of luck for 350 of those miles (pax range of 125 miles either side). On the other hand, a guy running regular tires would be able to use his standard spare tire to get him to any of the dozens of tire stores for a repair or replacement. If it's the guy's wife, she could just call AAA to come change the tire--no such luck with PAX.
Premature wear and differential cost aside, Honda should have required its dealers who sell PAX-equipped vehicles to install PAX equipment, keep PAX tires in stock, and train PAX installers. Honda has a responsibility to stand behind the products it sells--it has failed to live up to that responsibility in the case of PAX-equipped Odyssey Touring models.
By the way, my current Odyssey is my third since 2001. I love the van. Yes, I said I love my minivan. However, it will be my last Honda Odyssey if they don't fix the PAX problem.
Also, we don't know this person who got 20k miles on his 40k tires. Maybe he gets low tread wear on all his tires. We all drive differently. I've been in cars with guys who are in their 40's and still drive like they are 18. Cutting in and out, taking turns at excessive speeds, etc. If he's used to driving "hard" 60k mile goodyear tires then he will get slaughtered with softer "performance" tires like this. When I was 18 I could never figure out why my tires, brakes, and stereo speakers never seemed to last as long as they should in my car. I thought I was unlucky! Of course, I know the reason now. By the way, I haven't blown another set of speakers in 30 years
Maybe these softer tires are less then ideal for a heavy van. I'll give us that much. But, I still suspect a large part of these stories are due to the driving style and maintenance of the owner. It must be, for the simple fact that it is only happening to a small (albiet significant) percentage of people.
I can't wait to see where this class action suit goes. If there is some sort of real data to back up these stories, no doubt the hungry lawyers will find it. But, I'm sure Honda and Michelin have looked at the data too. The fact that they still put these tires on cars (and seem to be expanding it to others) makes me think they are comfortable that these claims are statistically isolated.
I'm no prognosticator, but I'm willing to bet that Honda and Michelin settle the suit. Like they do in the vast majority of class action suits, the defendants will run the numbers and pay off the lawyers. It generally has little to do with the veracity of the plaintiff's claim. It's all a numbers game. In this case it's going to be pretty simple because nobody has died from it.
As to why Honda may be continuing the PAX tire, it may have as much to do with the amount of money they have already invested and how much they save by not having to provide spare tires. I'm sure Michelin will hang in there because they've made a huge investment in these tires.
Having said that, I think there's still an issue of an adequate support network. Honda and Michelin are trying to address that by being very generous with replacement cost discounts, flying in tires overnight to remote areas, etc. This will probably derail some merit to the lawsuits, however, they can't keep doing this forever. Michelin needs to star forcing all Michelin dealers to be able to support and sell these tires. If I was Michelin, I'd be embarassed that none of their franchise dealers are willing to support this product.
Big news from Alabama today, the rumor today in Lincoln, AL around the plant is that PAX is history for '08. Thank God. They are going with 17" wheels, perhaps the same as the Ridgeline.
Alternatives at present are the EX wheels or MDX sport wheels 18 x 8 with the RDX tires 235/55-18. I have also heard of guys using the regualar RDX wheels too. All are almost identical in diameter so speedo won't be affected. The heavier springs in the front of the Touring models are a non-factor.
Honda needs to step up and offer a conventional set of wheels and tires and a @#$% spare! I've got the tools and the damned jack, but no bloody spare!
The 2008's are already in production, so hopefully the rumor is true.
For now those who use RFT's can consider themselves "early adopters" of a concept that will undoubtedly be on every car eventually. The idea is a no-brainer. Therefore, it's inevitable that they will work out the kinks in the idea, the prices will come down, and it will go mainstream.
Whether PAX is the answer or some form of SST, I don't know. I happen to be betting on a PAX type solution as an eventual standard. It just makes more sense then stiff sidewalls. You think Odyssey drivers are complaining? Go on a BMW board where most of their cars now come with SST's
Time will tell, but I'm betting directly against you on this one. ;-)
Best Regards,
Shipo
It's easy. Slice it and dice it any way you want, the physics of RFTs require increased unsprung weight and/or decreased ride and handling (both bad). True, the tire manufacturers and vehicle manufacturers will learn to adjust their designs to overcome the effects of these issues, however, taking those same new technologies and applying them to GFTs will make them that much better still.
Trust me, I am an agent of change. I love change, when it is warranted. That said, all too often folks hang their hat on the next big thing that turns out to be a blip in history. Take hard drives for instance. I remember a day in the early to mid 1980s where all those in the know were predicting the end of the hard drive era and the beginning of the solid-state storage device era by 1990. I mean, why not? Solid state drives were shock proof, crash proof, had the promise of using less power for any given unit of storage and had a virtually unlimited lifespan. What's not to like?
So what happened? For every advance that brought solid state drives closer to the mark, hard drives matched those advances (and then some). Here we are, over two decades later and spinning media is still the king and probably will be for quite some time into the future.
"By the way, RFT's are A LOT more popular in Europe then here. As usual, America is the last to adopt a good idea. Not sure why that is, maybe because we're such a big country it's harder to force out change on the marketplace."
You ever been to Europe? As a general rule, the surfaces of their roads are far superior to ours and as such, those with RFTs (still a very tiny minority by the way) won't feel the negative ride characteristics as often or as harshly as we will over here.
Best Regards,
Shipo
In addition to that, this dealer took you for a ride (pun intended) and charged you some crazy price. This almost sounds illegal. I can't believe Honda doesn't step in here and mandate set pricing from their dealers. PAX has worked great for me and I like them. But, clearly Honda didn't think this all the way through. Having a tire that can't be serviced by anyone but Honda dealers in your area (I assume that's the case) will only create these price gouging situations. Maybe that's why the rumor has it they are making PAX optional next year for the Odyssey.
By the way, we have several non-Honda dealers (TIre Kingdom, etc.) in Orlando who can service PAX. Maybe that's why the price is $285 installed.
The other huge flaw IMO; No spare tire. I understand the tires can be driven for 125 miles, but what if you're on a road trip to your sisters house 200 miles away, etc. The PAX system prevents you from getting stranded around town and can get you to a place of safety when you're out of town on a lonely highway, that's great! However, having a spare would finish the package and make it a complete safety solution. That would allow you to change out the dead PAX with your spare and not kill the weekend road trip. Honda says the spare adds weight. So what. Let the purchaser decide if he wants to keep the spare always in the car or stored in the garage for backup on the occasional long road trips.
Either you have a serious toe alignment problem or you are driving that Ody like you're still a teenager in a camaro. As you very well know, these tires are expensive. I'd look into that further before you end up replacing that second set at 12k again.
Good luck Sweetums
"Q: What type of treadwear can a driver expect with PAX System tires?
A: PAX System tires should provide treadlife comparable to a corresponding traditional Michelin® tire."
So what exactly is a traditional Michelin tire's tread life?
If you look at what Michelin offers when the tires are worn out, you can ASSUME that Michelin expects about 45,000 miles. Clearly, the only chance a real consumer has at this mileage - is if they drive almost exclusively on the highway.
OBTW: I have another flat tire on my PAX, it has been in the shop since Saturday - since no one was working at any of the local places that is trained to work on PAX. At least with a donut spare - the wife could have gone grocery shopping.
Your comment about the flat this weekend is exactly what I feel is REALLY wrong with this setup. These vehicles need to have a doughnut spare. Something so you can wait the 12-36 hours to get it fixed. I have to admit, I never considered your scenerio a problem. I figured I'd just drive around on the flat (in town) until I could get it fixed. However, the thought of getting a flat on a Friday evening on your way to a destination 200 miles away seemed to be a real problem. That's why I bought a dougnut spare for my RL and normally leave it in the garage for emergencies. With this setup I feel I have the best of both worlds.
I've been taking the Ody to the dealer for oil changes every 3K and having them check and record the tire tread. I just had the tires rotated again (at the requisite 6K) and so far the tires are holding up. I'll let you know in another 6K.
I can't recall if they rotated the tires for free, but Michelin paid 50% of the cost to replace the tires.
What is Toe? Your wheels all need to be pointing in the same direction when you drive otherwise they end up "fighting" each other and creating extra friction with the road. This particular adjusment is called Toe. it should be at zero degrees relative to it's partner wheel on the other side of the car. Think about when someone first learns to snow ski. The first manuever they are taught (besides how to fall)is how to stop. They tell you to point the skis in on each other to create drag and slow you down. It's the same thing with tires. It will destroy them quick. If it's heavily out of alignment there will be signs of it (choppy tire wear, a pull to one side or the other, vibration at high speed). However, if it's subtle you may not notice it except for early tire wear.
BTW, the wheels also need to be riding at 90% relative to the ground. This is called the camber adjustment and misalignments here can cause uneven wear on the outsides of the tire. Rotation helps even out the wear caused by that but the tire still ends up wearing out earlier then it should.
I want to assume they put it on a rack and did an alignment for you that day (even if they didn't tell you). However, knowing how busy and uncaring some of these mechanics can be, I wouldn't bet my life on it. I'd have it checked.
Why static toe-in? When you drive, friction with the pavement applies a moment at the tire, which compresses the inboard suspension bushings, trending the dynamic alignment to the toe-out direction. You have to start with just the right amount of static toe-in so that the dynamic toe will be zero or thereabouts.
The amount varies with the suspension geometry and bushing stiffness - there is no one spec that works for all cars. Front wheel drive and rear wheel drive cars differ too, because in an FWD situation the tractive force of propulsion somewhat offsets the friction effects described above.
