Cold Weather Problems
We left it in the attached garage, but the next day it was back to no start. Put some "Heet" in it and put the heater back on and it started again today, but after idling for a few minute it died and would not restart. It would crank but not give any sign of possibly starting at all.
I had assumed the problem was some water had frozen in the gas line, because it started right up after heating it for a while. But then why would it die after idling for a few minutes with a full tank of gas?
Oh, and all our gas here contains ethanol so I would have thought that would have absorbed any water.
The CEL came on with P0300 - "random/multiple cylinder misfire".
We did find out there is "extended coverage" from Ford for the fuel pump (they call it fuel delivery module). The description of this indicates that the fuel pump causes "contamination of the fuel filter" and this causes surging, hesitation, etc. and can ultimately cause stalling.
The way it was running seems to match this, though I don't think it normally appears suddenly like this. But since his fuel pump was never replaced under this program, I think we will assume this is the cause and get that done and go from there.
My practice now is when I pull out of my driveway I start driving down the street and do a hard break to warm up the breaks. Once I do this the breaks are fine for the rest of the drive. This can't be normal, several times I've been looking for a "soft" place to crash when I hit the breaks again and it stops.
I've mentioned it to the dealer but of course they can't find anything, problem is if I've driven there I've already warmed up the breaks. It usually only happens in the morning but sometimes in the evening if the car has been sitting out in the cold weather for a while.
It would be interesting to note if the pedal "feels" different upon first application---very hard and unyielding.
It would also be interesting to see if you could "stab" the brake pedal a few times before starting out in the morning, to see if that corrects the problem.
