Chevy Tahoe Maintenance and Repair
1910121415
    dlaceydlacey Member Posts: 2
    This may sound like i'm being a funny, but you didn't say if you checked the belts. It sounds simple but it took me 15 minutes to figure my same problem out. A missing belt woiuld most certainly make it very difficult to steer.
    tommyr43tommyr43 Member Posts: 2
    WHEN I FIRST START THE TRUCK AND DRIVE IT HAS NO PROBLEMS THEN WHEN I TURN THE ENGINE OFF THEN RETURN TO THE TRUCK AND GO AGAIN THE ENGINES SOUNDS LIKE IT IS MISSING AT TIMES AND IT DIES BUT RESTARTS AND SOMEITMES CLEARS UP AND RUNS FINE AND SOMETIMES IT JUST CONTINUES TO DIE. JUST RECENTLY WHEN IT DIED AND THE ENGINE WOULD NOT TURN OVER IT JUST CLICKED. AFTER SEVERAL ATTEMPTS IT FINALLY TURNED OVER AND STARTED. A COMPUTER CKECK WAS DONE BEFORE IT STARTED ACTING LIKE THE STARTER WAS GOING OUT AND IT SHOWED THAT THE EGR VALVE WAS NOT RIGHT. I TOOK THE EGR VALVE OFF AND THERE WAS NOT ANY CARBON BUILD UP ON IT AND IT SEEMED TO BE WORKING OKAY AND NOT STICKING. I PUT A NEW GASKET ON AND IT STILL DOES THE SAME THING. TONIGHT I STARTED IT AND DROVE IT AND IT DID FINE. I WOULD KILL THE ENGINE AND IT WOULD RESTART FINE. I FINALLY JUST LEFT THE ENGINE RUNNING UNTIL THE ENGINE WAS RUNNING AT NORMAL TEMP FOR A WHILE AND THEN KILLED IT. WHEN I TRIED TO START IT IT JUST CLICKED. I DON'T KNOW VERY MUCH ABOUT DIESEL ENGINES EXCEPT EVERYTHING'S SO EXPENSIVE. IF YOU HAVE ANY IDEAS AS TO WHAT THE PROBLEM MAY BE PLEASE LET ME KNOW . . . THANKS!
    73shark73shark Member Posts: 325
    Will make it easier for someone to possibly help if you tell us the vehicle, model, year, engine, etc.
    Plus, posts in ALL CAPS are hard to read so most people skip over those posts.
    It's a 1999 Chevy Tahoe 4WD with a 6.5 Turbo Diesel . . .
    kiawahkiawah Member Posts: 3,666
    Sounds like your starter could be bad. Works okay when it is cold, when it heats up it fails.
    This is assuming of course, that your battery connections are clean without any corrosion, as that adds resistance.
    wh7952wh7952 Member Posts: 3
    Over the last month my 99 5.7 4WD Tahoe has been giving me problems accelerating when I give it a heavy foot. When I hit the gas down it loses acceleration almost like it's being starved of air or gas. When I hit the gas the engines just bogs down, begins to hesitate, and will not accelerate. kinda like when you have a dirty fuel filter
    I have already cleaned the mass air flow sensor, air temp sensor
    Check your fuel pressure. Could be a failing fuel pump.
    or clogged fuel filter, from a bad load of gas
    I unplugged my mass air flow sensor and the truck was a new truck, ran scary fast and had so much power like it was a new truck. Is it safe to run the truck with the sensor unplugged untill i get a new one installed?
    I doubt it. It will set a DTC and probably go into a fixed fuel/air map that is rich to prevent engine damage. Probably why you're seeing/feeling increased power but have you checked mpg?
    moverforsmoverfors Member Posts: 1
    I just noticed significant drips on the garage floor coming out of the front differential....couldn't pinpoint where. Am I in for a big bill? Should I go to a regular mechanic or a transmission place?
    Depends. If the drip is in the front case (the side with the ten bolts) that's pretty simple. If the leak is on the driveshaft side (shaft from the transfer case) , that could require a bit more skill. That would be a pinion seal and it requires about 1.3 hours labor. If it's leaking from either left or right axle seals ( axles going to either front wheel), that's more complicated about 3 hours for one side and maybe 4 hours total for both sides. A good regular mechanic should be able to deal with these but if it were a pinion seal I might go to a transmission shop as it requires precise torqueing.
    dustie1dustie1 Member Posts: 17
    My left from wheel is making a sound like I have hug mudding tires on, my husband removed the left front tire in hopes to grease and pack the bering but discovered he couldn't get to them. If you know what type of berings these are please let use know do we need to replace the whole thing or is there a way to do it from home to save the money and not take to dealer. If you have done this job from home and can tell us how please let me know. Thank you and happy holidays.
    if the bearing noise is that loud I'm afraid it's beyond the point of packing with grease. I mean, that might get you by for a little bit but the damage is done. Bad bearings can, in extreme cases, cause a lot of other problems as well.
    Front Wheel Hub, Bearing, and Seal Replacement
    Removal Procedure
    Notice: Never place vehicle on the ground with the halfshaft removed or the halfshaft nut torqued improperly. Otherwise, bearing seals may become dislodged causing premature wear and/or damage to the hub and bearing assembly.
    1. Raise and support the vehicle. Refer to Vehicle Lifting.
    2. Remove the tire and wheel.
    3. Remove the rotor.
    4. Remove the wheel speed sensor and brake hose mounting bracket bolt from the steering knuckle.
    5. Remove the wheel hub and bearing mounting bolts. (15 series)
    6. Remove the wheel hub and bearing mounting bolts , the 25/35 series.
    7. Remove the wheel hub and bearing and splash shield from the vehicle.
    8. Remove the O-ring seal from the steering knuckle bore, the 25/35 series.
    9. Remove the wheel speed sensor mounting bolt.
    10. Clean and inspect the O-ring seal, the 25/35 series.
    11. Replace the seal if the following conditions exist:
    o Nicks
    o Cuts
    o Dry or brittle
    o Compression set
    Installation Procedure
    1. Clean all corrosion or contaminates from the steering knuckle bore and the hub and bearing.
    2. Lubricate the steering knuckle bore with wheel bearing grease or the equivalent.
    3. Install the O-ring to the steering knuckle, 25/35 series. Notice: Refer to Fastener Notice in Service Precautions.
    4. Install the wheel speed sensor mounting bolt. Tighten the bolt to 18 Nm (13 ft. lbs.).
    5. Install the wheel hub and bearing and splash shield to the vehicle, 25/35 series.
    6. Install the wheel hub and bearing (4) and splash shield to the 15-series steering knuckle.
    7. Install the wheel hub and the 15-series bearing mounting bolts. Install the wheel hub and bearing mounting bolts, the 25/35 series. Tighten the bolts to 180 Nm (133 ft. lbs.).
    8. Install the wheel speed sensor and brake hose mounting bracket bolt to the steering knuckle. Tighten the bolt to 12 Nm (106 inch lbs.).
    9. Install the rotor.
    10. Install the tire and wheel.
    11. Lower the vehicle.
    If you need diagrams, check w/ your local public library or get a workshop manual at Autozone or Kragen.
    roadworkroadwork Member Posts: 1
    my 2002 runs rough, it bucks and wants to stall. The voltage gage bounce all over. check engin light say lean left bank lean right bank. it is almost lie it has a vacume leak. do you think it could be intake manifold?
    roadwork
    Check fuel pressure. Could be a fuel pump going Tango Uniform.
    d1extreemd1extreem Member Posts: 9
    I just spent about 4 hours reading all of the posts... this is a GREAT place to be!
    Ok, bought my '96 Tahoe LT in April, with 150K miles on it, of which 10K are mine. It has a full tow package on it and I first made use of it with a 5x8 U-Haul trailer this past weekend. About half way into the 700 mile trip, I was entering the Trans-Canada from a ramp and, while accelerating, at about 45-50mph, there was a "zzzzzz" sound, kinda like a power steering pump, but from the tranny area. I was in OD, shifted to D, same noise with power on, it stopped when I released the gas, but no noise at all in 3rd. Everything still worked fine, passing gear, etc., no sign of slipping and the noise quit at hwy speeds.
    When I stopped an hour later, for fuel, checked the oil levels, all ok, then put it through the gears. Noise in forward & reverse, with brakes on and slight gas pedal, but it did not last. I finished the trip with no further noise, and no drop in performance and no obvious slippage.
    Without the trailer, and in our new snow, I've been putting it through the gears a little more aggressive, but everything seems ok.
    I'm doing another 300 mile trip with aging Mom & Dad at Christmas and don't want any problems... any ideas?? :confuse:
    Tranny oil is ok and, red, not burnt. Thanks
    Don
    Get under the hood and pull apart, clean and "white-grease" all the electrical plugs and connections you can find... could be some wires giving mixed, (corroded, loose) signals.
    A smoke-test, for the vacuum will show all leaks, 20$-40$, but worth the bother, even if that's not the "real" problem... could be a combination of things, vacuum is a good thing to have!
    Fuel too,
    Might be a bad plug, injector, wire... battery connection= low, irregular voltage leading to computer confusion.
    But the smoke test will tell a lot, and eliminate that question! :)
    What conditions are you driving in?
    rolexrolex Member Posts: 1
    When I do the scheduled maintenance to my TAHOE (oil change), what do I have to do o reset the "OIL LIFE %" message on the dash screen?? Do I have to make some kind of rest or does it recognize oil was changed???
    well read the manual.............
    Display engine oil life on DIC, press and hold the reset button
    markedward1markedward1 Member Posts: 1
    I have the chance to purchase a 99 tahoe for $750. It has 135000 miles and runs. The engine runs rough but when I put my hand over the exhaust pipe it isn't a miss in the firing. The car has sat for 2 years. it blows hot air, but when I checked the antifreeze it was half full. This is a corporate vehicle so it has been maintained. I did drive it and it drives with the roughness and gets up to 65 easily. I have read about many intake gaskets, fuel problems, etc. and wanted someone elses point of vew on the . the truck is in great shape and has all the bells and whistles. it is an 8 cylinder, 2 wheel drive LS. Thanks in advance for any comments.
    Well you could have it scanned for trouble codes, and also do a cooling system pressure test to see where the coolant went---you'll have to find that leak regardless.
    If it's a LS, it can't have all of the bells and whistles as that was the base model and some options available on the LT and Z71 weren't available on the LS. That being said, if you like it and the price is right, then make it yours. You can check Edmunds, Kelley Blue Book, and NADA to see what it's worth w/ the options it has. Good luck.
    gsantosgsantos Member Posts: 1
    my tahoe is making a rattling noise by the front wheel on the passenger side. It is not constant. I also hear a humming noise when i am driving it. I checked the oil and it seems to be fine. Any suggestions on what the problem could be?
    bad cv joint, loose lugnuts
    Is this a very light rattle? If so, I'd check the retaining springs or clips for your front brake pads.
    krmcphersonkrmcpherson Member Posts: 1
    I have a 2000 chevy tahoe, that i've had for 2 years, it has a little over 15000 miles on it and we've never had any problems except for the battery dying, when we were a ways from home, the car started acting like it was outta gas, and after we pulled over we couldn't get it to stay running. dropped the tank and cleaned it out(had alot of sediment) replaced the fuel filter twice,(both of which needed cleaned after we tried to start) changed the fuel pump relay.The fuel pump itself will prime when the key is turned but it will never stay running, keeps trying but won't stay running more then a minute, and then our battery is usually dead and needs re charged.
    :confuse: :sick:
    Where do you live?
    First off, I've changed 2 alternators in the past 3 years in my '96... might be the cause of the dead battery. Otherwise, check for a light staying on, ie glove-box, under the hood...?
    You don't say if you changed the fuel pump, (low pressure) but I'd be looking for a gas line leak, sucking air, somewhere. Try bleeding the gas line at the engine, there should be what looks like a tire valve, if not, loosen the line...might be an air bubble, or dirt, jammed up in there...
    If you're where the temperature goes between freezing and not, and do a few miles before it acts up, look for a vacuum leak to the breather... the breather warm-air valve, from the exhaust manifold don't work, causing intake gas to freeze, reducing gas flow. Usually, the valve is ok, it's the supply line that's leaking... find a full-time vacuum line and plug it there, to get home, or use a lot of gas-line ante-freeze!
    Keep us posted! :)
    Need to check fuel pressure to verify if the pump is good or not.
    RobereRobere Member Posts: 3
    My a/c blower works fine,..( aside from some blower noise ) but there is no cold air. I have tried to recharge and it doesn't seem to take. A dealer has done a leak check and couldn't find any leaks. Occasionally, I hear a "gurgle" noise after the truck is turned off,...any suggestions? Could this problem be caused by a plugged drain line? Any help would be appreciated!
    Did you (or the dealer) put on a set of pressure gauges, to measure the pressures in the system on the high and low side? This checks whether the compressor is able to pull down a vacuum to the correct low pressure, whether you have too little or too much freon in the system, whether you are getting freon flow thru the orifice, whether your high/low switches are working correctly, etc.
    Once that is all working correctly, then they should check that air mixture doors are working correctly.
    well only on the charge side,...the pressure when charging is good,..when the compressor kicks in the pressure drops and nothing is discharged from the charging canister,.............
    oldtahoejimoldtahoejim Member Posts: 1
    I am trying to replace the turn signal switch on my 2000 Tahoe and the new part is missing a pair of wires with a quick connect that would connect to a switch directly behind the gear shift arm and this has something to do with taking the car out of Park. What does that control that is activated or de activated by the gear lever do? I'm guessing that it has something to do with the daytime running lights, but that is only a guess. By the way, the problem with the turn signal is that it continues to make the clicking noise after the wheel is centered. the lights are not flashing, but the noise is very annoying.
    The charging bottle should be connected to the low side. With the compressor running, the low side should be ~30 psi and high side ~250 psi. These are very approx. numbers. When you open the valve to allow the freon into the low side, the pressure will go up because the freon vapor pressure is ~120 psi. Also the high pressure will start to go up. When the valve is closed, the low pressure should go back down. Be sure you don't over-charge.
    Not sure I understand this: "and nothing is discharged from the charging canister,............. " Unless you have the bottle connected to the high side which is dangerous.
    Thanks,..yes I did have the initial pressure but when the compressor kicked in,..pressure was lost,....I would think that would indicate a small leak? Bad compressor? However the dealer couldn't find any leaks,...
    re: "nothing is dis,...." it seems no refridgerant left the container. The nipple on the charging unit doesnt fit on the high side,...so it was the low side,....
    I find this hard to believe, you need to get a different 'dealer'. Is this a Chevrolet dealership you are taking it to? Any competent dealership should be able to find and fix air conditioning system problems. They can tear it apart and rebuild it, if they have to.
    If this really was a Chev dealership, then go find another Chev dealership or a specialty air conditioning repair shop.
    anedreanedre Member Posts: 1
    My car has been drinking large amounts of anti-freeze recently. In the last months probably atleast 10 gallons. I've tried leak fluid and nothing has worked, and I haven't had time to drain it and try head gasket leak fluid. Also, today it broke down on the highway, I thought I may have run out of gas even though the gas light was still on 1/4 so I had a buddy bring me gas. The car started back up and a bunch of white smoke came out of the exhaust. I drove it to the next exit with the engine only allowing me to go about 40-50mph and as I got off the car stalled again and we left it there. Also, there is a red neutral on the transfer case on the inside that came on last night.
    I drive a 1999 Tahoe and we replaced a tube from the radiator to the overflow tank about a month ago. I do heavy canyon driving because I ski 3-4 days a week. Any ideas? What's the problem?
    :confuse: :sick:
    Sounds like a blown head gasket, very bad for your engine and catalytic converter.
    Get it fixed quickly before you ruin both.
    jason11111975jason11111975 Member Posts: 1
    i have a 99 tahoe and it keeps hesitating i had the codes read and it said misfire and 02 sensor was bad so i fixed both on passenger side then i changed the coil then it said the 02 sensor was bad in bank 1 so i changed the one on the driver side and the truck still is doing the same thing anyone have any ideas
    You have to remember that the DTC is only an indication of an area where you start the diagnostic fault tree, not necessarily an indication of what part(s) need replacing. The factory service manual has the fault trees.
    rox430rox430 Member Posts: 2
    I've had this same exact banging/clanking on my '01 Tahoe LT for some time now. Has anyone else experienced this or had it fixed? Not sure if it's a problem with the universal joint, or the clutch, or something else. Clank is loud enough to make people turn their heads.
    Replying to: shineslee (May 22, 2006 6:44 am)
    Hi, I'm new here, and my first topic of course is going to be something about my new truck. I JUST bought this Tahoe home friday night. We haven't signed the paperwork till tonight (Monday).
    First thing, the truck runs good. Bad thing, the Tranny is making a hard "clank" noise everytime it shifts to 2rd or to 3rd gear at 1500 RPM. And when it slows down, it does the same thing...
    Is it something that could be easily fixed? What could it be? Does it need a new Transmission already?
    edited March 2010
    Well hopefully you had someone check out what the clanking was in the transmission before you purchased the vehicle........
    You could be staring at a couple thousand dollar repair bill......used cars are sold 'as-is'.
    I'm the original owner...post was in response to an earlier similar post from a couple years ago
    dantheman3dantheman3 Member Posts: 14
    edited March 2010
    Hello out there. I have an 03 Tahoe with 64k. Truck has been babied, all service done. Front differential rebuilt at 60k (I tow in the summer) still shouldn't need that at 60k. I have a strange noise after truck has been driven and is still warm. Upon restart the engine idles rough and when I rev the engine on down rev there is a loud vibration, rubbing, something very loud coming from the the bottom of the engine area. After a couple revs the noise fades and the engine purrs. Anyone have an idea? I've had the idler checked, all belts, A/C system, worried I will be out towing the trailer this summer and this will bite me. Took it to the dealer and of course can never replicate. Happens 2-3 times a month.
    Is fan hitting the fan shroud?
    Thanks for your reply. I wonder if that would make the engine run rough for a few seconds then smooth out again. I will definitely have that checked.
    thunderchildthunderchild Member Posts: 18
    Man i just spent the past couple of hours reading this. I inherated a 2k4 Tahoe LT from my little brother last August. I had all the fluids and filters changed when I got it. He was not the best on maintenance. It has run fine since then. I had the plugs done last week. She is still running like a top. I let my wife drive it as I have a 2k3 Durango and a 2k9 Outback. I baby my vehicles so I always shoot for 300,000 miles. How many others have really high mileage vehicles and how have you maintained them? Hope this is not a thread hijack!! :P
    mountaineer4mountaineer4 Member Posts: 5
    I have an apparent problem with the steering in my "03 Tahoe with 30,000 miles (presently). There was a repair made within the warranty period by my Chev. dealer which seemed to correct the problem. This repair was made with the vehicle having approximately 12,000 miles. NOW this Government Motors Tahoe is clunking again with the vehicle out of warranty. Also several months ago I received an engineering blog wherein Government motors. was taking legal action against a supplier for their supplying this defective steering product which has cost Government Motors 90 million in warranty repairs. I haven't heard anything since although I did E-mail this info. to my dealer. I am not surprised that I received no reply!
    Anyway, can anyone provide me with info on just what the source of this steering "clunking" is and what is the part(s) needed to make the repair? Will this be a difficult repair? I most certantly am not going to pay Government Motors to make the repairs and most probably will not buy another GM product...Think Toyota.
    Thanks for the assistance.
