2000 Ford F150 Supercab Shutter
                    My 2000 F150 extended cab with the 5.4L and auto
trans appears to have developed a transmission
shutter while coasted at 40mph at 1100rpm on smooth
road surface. The OD solenoid and Shift solenoid
was replaced along with the valve body however
shutter still exists. 2nd visit to
dealership...unable to duplicate. I've heard of
Ford problems with torque converter shutter and now
I feel my F150 has it. Anyone elso with the 2000
F150 with the same concern?
JEFF
JEFF
I love my truck as well. I've also had tires rotated and balance but still have the shutter. Possibly the rims are suspect. I have the polished aluminum wheels with the tear drop cut outs. . . not the Lariat type. Let me know what happens.
Jeff
"Get a Dodge Ram so you will have room to work
under the hood."
This is very true if you buy a Ram. You will need the extra room to work on it the day you buy it.
Those who have no experience with the shudder, don't post erroneous garbage. Stick to the topic or find the post suited for response; in this case, dodgeram7 should have responded to the dodge ram trouble posts.
Jeff
Haha
Replace the torque convertor? Did you have something similar with your F150? With a 250lb load in the bed this weekend, the shudder was worse. I'll have dealer check but I need more background for my arguement with the service advisor.
Please advise,
jeff
Jim
With an automatic transmission the shudder is usually caused by the torque converter. I had a Mits that did the shudder every time it up shifted.
Rich
As for torque convertor shudder, it is common throughout many vehicle lines in the early and mid 90's. It is caused when the lockup clutch does not engage smoothly. Often cleaning the fluid - system flushing- will take care of the problem, although sometime the torque convertor must be replaced. Ford AODE transmissions are famous for developing a shudder at 40-50k if the fluid was not changed.
As for transmission quality, Ford's traditional worst is the AX4N - Taurus and Windstar. Usually their RWD trans are pretty tough, as long as you don't tow in overdrive. Chrysler has the worst transaxles (FWD)of any major manufacturer. I don't know if Chrysler has ever made a decent trans for any FWD vehicle (award winning minivans, huh). Most dealers have a small percentage of technicians working on transmissions. In a Chrysler dealership, you may find that over 50% will do trans work, since there is so much of it. Their transmissions(RWD) are pretty good though. GM is generally better at RWD than FWD automatics as well.
this topic is being "frozen." It will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
