2000 Silverado Bad General Tires
I ordered my 2000 4 door 2WD 1500 Silverado last
November and recieved it at the end of January. I
went with the highest upgrade ($295) OWL tires and
was dissapointed when it showed up with General
Tires.
After 3000 Miles I noticed that a thread became
exposed in the sidewall. I took it to the local
Discount tire and had it replaced Free.
After 6000 miles I noticed that the tread was
starting to crumble. I could pick off chunks of
tread with my fingernail.
It turns out this is covered under the
bumper-to-bumper warranty. I had Discount tire
replace the Generals with some Michelin LTX tires
and paid the difference in price ($160.00 for all
four).
Between the upgrade price from GM and the price
difference between the Michelins I coughed up $455.
I would have spent less getting the stock tire and
trading in for the Michelin's.
Tires.
four).
Clay Hodges
<<A HREF="http://drive.to/agmlemon">http://drive.to/agmlemon>
(GM Truck Lemon Homepage)
something that's suppose to be a workhorse, and
even i had to pay for the upgrade tires because
that's automatically optioned when you buy the
optional tow package. i would'nt trust these
tires on a trycycle much less for towing. my door
sticker says inflation cold- 35 fr and 35 rear
hah! all four skins are wearing out in the
center. dealer told me to lower pressure a couple
of pounds and monitor wear. if still cupping in
the center then try lowering pressure a couple
more. again what a hoot! i'm now going to a
different dealer who is going to help me get the
jelly tires replaced. right now though there
letting the first dealer dig a hole for
themselves. to tell someone to let air out on a
30k truck is a joke and probably few other
things. hopefully i'll be able to get the
michelins like you guys did.
...red
- Tim
Tim
Heard anything on Firestone Firehawks? Came on the Denali, tread looks aggressive enough but the ride is bumpy even on smooth roads
Dean
the tire option is listed as -- p255/70r16 als bw tires $170.... cold tire pressure is 30 front and 35 rear.
Jay
If I'm not mistaken, the noise in the steering was caused by a defective metering valve in the p/s unit.
gmcsierra
we have the same truck specs. And one says 30 the other 35....same tires, same truck style, different plant and manufacture date.
More than likely just a bored assembly line worker playing with the numbers on the sticker stamper!
Mine was ft wayne 10/99.
jay
If you agree than...Please click the EMAIL GM link you see in the center of my home page and tell GM your story and how you think they can best resolve the problems with your truck.
Thanks <<A HREF="http://drive.to/agmlemon">http://drive.to/agmlemon> or
<<A HREF="http://agmlemon.freeservers.com">http://agmlemon.freeservers.com>
I've said this before. Also let me warn you, I'm anal too!
You can get your tires to wear very evenly for $10 and a tire pressure gauge. First fill your fuel tanks. Then put everything in the truck that you normally carry, including yourself. Then go to your friendly public scales and get the truck weighed.
(If asked, just say that you're putting a camper in the bed and need to know your weights. There's something about the legal use for the weight ticket that I don't understand.)
You should get a sheet with three weights on it, front axle, rear axle and gross. Divide the axle weights in half and save these weights. (In pounds.) Now the hard part. Go to the brand of tire dealer that matches the tires on your truck. Ask to see the tire loading charts for your particular tire model and size. Ninety percent of the time you'll get a blank stare from the kid behind the counter. (You USAF types will also recognize the 'WTF? Over.' that follows.) What you're looking for is a chart for your particular tire type that has load carrying pounds and the required PSI inflation pressure. Write all the load vs PSI down as you'll need them when you change the normal load. Inflate your tires, cold, as specified by the chart.
A few words of caution. If you add more weight to the truck, adjust the tire inflation pressures accordingly. The tire inflation pressures on the door sticker are assuming the MAXIMUM loading possible and not exceding the truck's GVWR. Also do NOT inflate the tires outside the range specified by the tire manufacturer. (I tend to avoid the lowest PSI inflation in the range, regardless of the axle weight.)
For another couple of bucks you could invest in a tread depth guage. (Remember I said I'm anal.) Measure the tread depth regularly (Oil change time.) and record for each tire. (Three readings for each tire, inside, outside and center should be sufficient.)
Rich
Dean
BTW: The new trade-in value for the 255/70R16 OWL General tires was $64.00 per tire. The Michelins were about $40.00 per tire more and well worth it to me. Lifetime balance on the tires was an additional $11 per tire and was not covered under the bumper-to-bumper warranty.
The last time I went bowling in a league it was 13 degrees below zero. I was so irritated with the game that evening that I walked the mile and a half home. I havent touched a bowling ball in 25 years. So I guess that I don't have to worry about adjusting the tire pressures to carry a bowling ball
Rich
Dean
Harry
Dean
My personal opinion on tire rankings at this time is:
1. Michelin, Uniroyal/Goodrich
2. Goodyear, Kellyspringfield
3. Bridgestone/Firestone (With reservations)
4. Continental/General
Harry
Dean
Harry
I was wondering if anyone has had problems
with the stock General tires or Gen Seal tires? I bought a '97 Venture Ext. new in August of 1997, and the tires that came with it were the General XP 200 GT Gen Seal Self-Sealant tires. Come to find out, that "goop" that they put inside the tire, will settle into one spot on a really hot day. Also, if you pick up a nail, the self-sealant doesn't always work, and tire repair shops do not like to mess with these tires because of the "goop"! With the "goop" settling into one spot, it makes for a someone bumpy or uneven ride. I was wondering if anyone else has had that problem, or has seen something like this posted in the various sites. This was a $210 option when I bought it new (Safety & Security System w/ Anti Theft and Self-Sealant feature). The darn tires are rated for 80,000 miles, but I don't know if I can take it that long, since I've only got 36,600 in three years of ownership!
Barry
Dean
Randy
and join a Dakota topic already in progress. Thanks!
Front Porch Philosopher
