The Future Of The Manual Transmission
15253555758205
    Yes, I was not implying that automatics can't and don't beat EPA as many do (especially cars like the Accord with tall gearing, relatively powerful engines and light weight), Just that it is rare for a MT car not to be able to beat EPA. Ony car I had that had trouble with EPA numbers was an automatic Taurus. A dozen other cars have all beaten EPA by a large margin (all sticks except for a 96 Odyssey and a 2006 Sienna)
    I also wish car makers would add a real 6th gear (that is taller than the current 5th) to manual tranny cars so they can have a tall cruising gear.
    VW used to do this with 5 speeds giving them two overdrive gears - had a 5 speed quantum that did 96 mph in 3rd gear, and had two overdrives after that. It pulled just over 2000 rpm in 5th gear at 60 mph with only 74 hp. It did fine on the highway. Yes downshifts were occasionally needed, but so what.
    This was in 1983 when gas was more expensive than it is now (adjusted for inflation).
    Actually, on the highway, the gear ratios are such that the automatics rev lower at the same speed than the manuals.
    Yep, that is one of my reasons for switching. In the case of my car it is about a 25% difference.
  • tallman1tallman1 Member Posts: 1,874
    However, there is that city mileage, where the manual easily beats the automatic. I'm afraid I'm one of those big stick fans! :shades:
    I am a member of the 40 mpg club we have in the Accord mileage thread. There are some automatic drivers out there who can't beat my manual yet.
  • plektoplekto Member Posts: 3,738
    "A bit harsh, no? I mean, when was the clutch invented? If you're going by age the clutch is far older...They are far from perfect, but they are also far from 1970s 3 speed automatics."
    No, I meant EXACTLY what I said. Same miserable 1970s technology. GM? Same 3 speed automatic with an overdrive gear added. Ford? Same crud. Chrysler? Okay - Chrysler is making WORSE automatics than in the 70s. And when we get to foreign cars... Mercedes? BMW? VW? All junk because in Germany, if you drive automatics, you have a special "automatic only" license that is laughed at like a Moped license is here in the U.S. 95%+ of all Germans get the manual REAL license.
    So is is any wonder that the manuals are built well and the automatics are cheap crud they send to the rental fleets?(and us by extension).
    Now, Japan is the best among the worst I guess, but their penchant for sedate rides and mile high gearing - well, they essentially make a more "Buick" ride than GM does. Not surprizingly, most of Japan also drives manuals.
    "Not surprizingly, most of Japan also drives manuals"
    Actually, per numbers posted on this thread a long way back, it is not a majority. Less than half of Japanese drivers drive a stick. :-(
  • piredonpiredon Member Posts: 50
    That's the main issue I have with my legacy, at 70 mph in 5th gear, it's turning at 3000 rpm. A taller 6th gear that turned around 2250 or 2300 rpm at 70 mph would probably get another 2 mpg on the highway.
    Anyone have any experience with SMG / DSG type transmissions as it relates to fuel economy? I would think they would get mileage somewhere between an MT and an AT, given the fact that no power and efficiency are lost like they are with a torque converter, but you are still automating a process, which always takes some power. You could also short-shift, and tool around in the highest gear, to save fuel, like you can with an MT.
  • seminole_kevseminole_kev Member Posts: 1,696
    My daily driver is a DSG. However not driving the same model with a stick or true automatic makes it tough to compare what I might get with a regular stick or a slushbox compared to the DSG.
    There are two modes (if not making the gear changes yourself) regular and Sport. Sport will definetly impact the economy as you'll spend more time in the lower gears and higher in the RPMs of course.
    I can just dump it up to a higher gear though if I want to piddle around, but normally in regular (non-sport) mode it has a nice blend of upshifting when just tooling around and staying in the gear I want when needed for a bit of zip.
  • habitat1habitat1 Member Posts: 4,282
    "You could also short-shift, and tool around in the highest gear, to save fuel, like you can with an MT."
    I know that $3.50 per gallon gas has people thinking about all sorts of ways to save money at the pump, sometimes without thinking about other consequences. For example, on a regular basis over in the Acura forums I frequent, somebody inevitably asks "do I really need to put premium gas at an extra 20 cents per gallon in my $35,000 TL-S or $45,000 MDX?"
    FWIW, the advice I was given very early in my manual driving career (30+ years ago) was to error on the side of shifting high, rather than shifting low and lugging the engine. As such, the idea of "short shifting" or "tooling around in the highest gear" is against what I believe is the best way to treat an engine, long term.
    My 1995 Nissan Maxima SE 5-speed has logged 155k miles at an average MPG of 24.02. It averages 28-29 on the highway and 21-22 in the city. (EPA ratings 22/27). Could I have gotten an extra 0.2 or 0.3 mpg by short shifting or lugging around in 5th gear at 40 mph. Perhaps. But according to my Nissan service manager that I've been taking the car to for 13 years, I would not have made it to 155k miles with virtually no carbon deposit build up and a compression test that showed all 6 cylinders within 3-5% of a new car tolerance. The car runs like new.
    Short shifting is, IMO (and the opinion of the experts I've polled) short sighted. That isn't to say that you should drive like a maniac and redline the engine at every shift. But, especially with higher perfromance cars with redlines in the 7,000+ range, shifting to early or allowing the engine to lug below 2,000-2,500 rpm is penny wise and pound foolish.
    Obviously, every car is different. At 75 mph, my former 9,000 rpm Honda S2000 was cruising along at a lofty 4,000 rpm in 6th gear - and getting 30+ mpg in spite of a 26 mpg EPA rating. A friends E320 CDI would blow up at about 4,500 rpm. But if I were in the market for a pre-owned 911, I'd rather buy one from someone that made every shift at 4,500+ rpm rather than someone who lugged it around at 1,500 rpm in 6th gear around town to save a nickel in gas.
    You can short shift without lugging the engine. I usually shift at 2,500 or a little less. My Integra has 230,000 miles of this "abuse" and the engine is also like new internally. ;)
    A steady diet of Mobil 1 helps too.
    Obviously you'd never want to accelerate from 35 mph in 5th gear, but for keeping a constant speed on relatively flat road surfaces, is that really all that hard on an engine?
    I think you were enamored with the car
    Perhaps, but my comments apply to the Boxster's transmission specifically.
    I'm sure the rear-engined 911 uses a completely different gear box than the mid-engined Boxster.
    The Tip on the Boxster holds a gear in a turn, blips the throttle to match revs perfectly before a downshift, and lets you use engine braking on a down hill, it basically did what I would have done (or tried to) if I had a manual.
    Like I said, I'd still prefer the manual, but the Tip doesn't spoil the car by any means.
    There may be a slight difference in gearing ratios, but the 5-speed Tiptronic in the Boxster and 911 are essentially identical from a mechanical perspective, and cost an identical $3,440.
    Well, not if throwing away $10,000+ and getting lower gas mileage isn't a "spoiler" for you. It would be for me.
    Base Boxster Manual: MSRP $45,600; 0-60 5.8 seconds; EPA 23/32 mpg.
    Base Boxster Tiptronic: MSRP $49,040; 0-60 6.7 seconds; EPA 21/28.
    Boxster S Manual: MSRP $55,500; 0-60 5.2 seconds; EPA 20/28.
    Boxster S Tiptronic: MSRP $58,940; 0-60 5.8 seconds; EPA 20/27.
    As you can see, you could get a base Boxster with manual transmission that would be as quick as your friend's Boxster S Tiptronic for $13,000 less - and get 15%+ better gas mileage to boot.
    Mind me asking - why did your friend get a Tiptronic instead of 6-speed manual? Unless he is physically disabled, I cannot for the life of me figure out why someone would get a high end 2 seat sports car, pay $9k extra for the more powerful "S" model, and then castrate that addiditonal power with a $3.5k slushbox. And, good as it may be, make no mistake - the Tiptronic is a torque-converter slushbox, not a DSG or SMG.
    The only person I know that had considered a Tiptronic 911 was talked out of it by the dealer who enrolled him and his wife a deal to go to the Porsche performance driving school together for the same total price as the Tiptronic would have been. They both couldn't be happier and, as he says, it saved him the cost of a divorce as well. ;)
    That sums it up in a nutshell. It is typical for a smaller (or less powerfull) engine with a stick to perform near or equal to the larger engine with the auto.
    Great example - who would pay so much more for so much less?
    That oversimplifies things a bit too much - the S model comes with more than just the bigger engine. It has more standard features and I believe a different suspension.
    Besides, Porsche owners don't think like that. They're not bargain hunters looking for the lowest price. If you have to ask, you can't afford it. :D
    I'm not sure if my friend even knows how to drive stick. Probably because he commutes from Fairfax VA to DC every day. Tell you what, I'd take the auto in that sort of traffic any day!
  • kyfdxkyfdx Moderator Posts: 270,468
    Really.... the only Porsche buyers that get the Tiptronic are those that don't want a manual..
    No other Boxster shopper is going to try the Tiptronic, and then say, "Gee, I have to have that transmission!". Who needs a stick!
    Of course, that goes for just about every other car, now that I think about it. :)
    Commuting in this:
    May influence a few buyers. ;)
  • daysailerdaysailer Member Posts: 720
    Yes, it reaffirms my preference for a MT.
    It might influence them to not buy a Boxster for their commute.. :surprise:
    But, it isn't going to make them want to buy an automatic Boxster.
    It is beyond me why anybody would willingly subject themselves to traffic like that - regardless of transmission type. :cry:
    To stay slightly on topic - I do prefer a manual in heavy traffic. Or did until I escaped from the DC area to SD.
    I actually had to sit through a light for more than one cycle a few weeks ago (first time in years). Maybe it is time to move again. ;)
    Commuting in this:
    Gosh - I leave it in 2nd gear the entire time. If I need to scoot into a spot or get over a lane, it happens instantly with no lag. 2nd gear on most cars covers 5mph-30mph just fine.
    These are the conditions where a manual shines. Despite what you hear from people all the time who either don't know how to drive manual correctly - if at all.
    Oh - and I don't have to hit the brakes more than a few times, either.
  • boaz47boaz47 Member Posts: 2,747
    Thank goodness they have a Car Pool lane. Without one that is nothing like the 405 at the northern split. The uphill climb with a manual in bumper to bumper traffic is hard at best. The dance in a manual is quite simple. Sit for a minute, traffic starts to move. Try to give yourself enough space to creep along in first without having to stop again. You left too much space? You get cut off. Next dance is stay closer to the car in front so you don't get cut off. Traffic starts, you leave less than a car between you and the car in front so you don't get cut off. Speed picks up till you have to hit second and just as soon as you do they all stop again. The person in the car next to you looks over as they sip their Starbucks and listen to their sound system and the simply allow the car to creep forward with the lifting of one foot or stop with the depressing of one foot. No doubt it takes more skill to commute with a manual but for as many days as one might have to do that in LA the skill simply isn't worth it. Once I moved to the mountains it was worth it again. But constant stop and go on a long uphill climb with hundreds of other people is a pain at best and I can promise you that is one reason 90 percent of the buying public is driving automatics. Skill or not there is no joy in several hundred shifts or clutch depressions every morning. Get a passenger and hit the car pool lane. No shifting required once you get going, with or without a manual.
    Somewhat true, but not much. About 70% of the price differential between a Boxster and Boxster S goes straight to the engine.
    That's exactly what some Porsche dealers would like you to think. I "asked" around and found a dealer willing to give me a $10,000 discount on a 997 model 911S Cab when several other dealers acted like a $2,000 discount was a big personal favor. I don't think being able to afford a Porsche means one should throw their financial prudence in the trash.
    We live in DC. Fortunately I don't have a daily rush hour commute, but I have to deal with enough Beltway traffic as it is. Not only did that never make me think twice about getting a stick, my wife now wants to test drive the new Cayenne V6 6-speed. She likes our MDX, but hates the slushbox (it was her first automatic in 30 years). As many posters here have said many times before, replacing a crisp 6-speed manual with a slushbox doesn't necessarily make traffic jams any less frustrating.
    As far as your friend possibly not knowing how to drive a stick, don't tell him I said so, but that's probably a good indication he doesn't know how to drive a Porsche, either. I myself am thinking of taking the Porsche performance driving school - but at least I meet the pre-requisite of knowing how to drive a stick. Porsche doesn't use any Tiptronics in any of their classes.
    P.S. I'm not trying to go [non-permissible content removed] for tat with you. I know that you said you would probably personally prefer a manual. I just wanted to offer my counter-opinion that the 6-speed manual in the Boxster and 911 is so good, that the going with a Tiptronic is even more difficult to justify, not less. :)
  • nwngnwng Member Posts: 663
    I've been doing this for 11 yrs in a stick, not big of a deal, really.
    even if it makes the stop and go commute easier (a notion that I would contend is not the case), the automatic makes all the REST of the driving worse!
    Unless you have the most gutless car on the planet and miserable gearing, you stay OUT of first. Always. You keep it in second gear and keep it rolling a tiny bit. There's a real technique to doing this, but it's very effective. No brakes needed, either. You do leave some space, but since most decent manuals can start in 2nd gear, we're literally talking about 1-2mph to stay out of first gear. Then you don't need to shift out of second.
    I do that sort of commute every day on my way home for 4-5 miles before I switch freeways. And it's never a problem as long as I avoid first gear like the plague.
    you do that uphill from a dead stop without excess slipping of the clutch? Not a problem on the flat or down hill but it can be a real bear uphill in second. Still I contend that heavy traffic has been one of the greatest boons to automatics there is.
  • redsoxgirlredsoxgirl Member Posts: 67
    "Still I contend that heavy traffic has been one of the greatest boons to automatics there is."
    Replace "boon" with "bogus excuse". IMO, the biggest boons to automatics are (1) laziness, (2) ignorance and (3) apathy.
    I think it is ignorance more than laziness. I really don't feel like its any more effort for me to drive a manual transmission. I have been driving one for about 15 years, I don't think about it, unless I am in a low traction situation or something, where I am happy to have the additional control.
    You forgot distractions, which I believe trumps all the other reasons. People have way too many things to do in their cars these days to also manage the powertrain as they drive along. There are 40 different audio and video options, heck live streaming TV too! There's make-up and talking on the phone. There's certainly eating, reading maps, reading the NAV system, heck reading the newspaper if they are in traffic. There's drinking, spilling drink, trying to mop up spill. There's hand-held video games!
    All that stuff leaves the driver no time or attention to keep the car in the right gear, or even in the lane at least half the time.
    Hence why my car has automatic *nothing*. Okay, it has automatic windows and door locks. And that's it. So I pay attention and drive. Talking and stuff can come later.
  • bristol2bristol2 Member Posts: 736
    Personally I like to do the congestion in 1st with one foot on the clutch only while sending some emails. ;)
    "Replace "boon" with "bogus excuse". IMO, the biggest boons to automatics are (1) laziness, (2) ignorance and (3) apathy."
    I'll add a fourth. (4) lazy, ignorant and/or apethetic parents that set a bad example and don't teach their kids how to drive a stick.
    According to one of our teacher friends who used to instruct at a defensive driving school in the summer, kids that learned how to drive a stick early, consistently did better at accident avoidence maneauvers they taught at the school. At one point they wanted to switch to manuals for the course, but, because the parents are given the test at the beginning of the class, too many didn't know how to drive a stick themselves. His position is that anyone - parent or child - that finds driving a stick too challenging or requiring too much coordination is a disaster waiting to happen on the Washington Beltway and they shouldn't be issued a drivers license.
    P.S. When one of my wife's friends questioned him on that position a couple of years ago and climed she was a "great" driver (she can't parallel park without tying up traffic for 5 minutes), he invited her to take the test. In front of several parents and students, she came in dead last and hit more cones than she missed. She was subsequently banished from carpooling for school field trips. Her car (Mercedes E320) looks like it's been parked in Bagdad for a year. There isn't a panel without a dent somewhere. I don't think she's safe driving a golf cart. If the ability to drive a manual as a pre-requisite for getting a driver's license, she'd definitely be walking and the world would be safer.
    i like the fact that a manual keeps you more engaged actively and pleasureably in the task of driving and managing the control of the vehicle. it just makes sense from a humans factors perspective.
    a manual also gets better fuel economy and provides better control / options under adverse weather conditions.
    a manual generally is more reliable and less prone to fail / wear.
    manuals are typically cheaper vehicles to purchase and maintain. ;)
    You pretty much described what I do in my Miata, and a smooth clutch really helps. But I was stuck in gridlock on the NJ Turnpike one time and my left knee was ready to pop out of its socket after a while.
    With an auto you're only using one foot. With a manual you need two.
    Fortunately, most of us have two.
    Walking also requires two feet. Maybe hopping would be better so one foot stays rested. ;)
    Reminds me of an old episode where Archie and Meathead argue about how to put on shoes and socks... One sock and one shoe, then the other foot.. Or, both socks, then both shoes.. :)
    exzur2071, no, a car travelling at 1000 rpm does not necessarily use less fuel than when tach reads 2000 rpm. too many other variables. 1000 rpm is too low an rpm for the "zero fuel" mode anyway. there will probably always be some fuel burned at that low rpm. but at 2000 rpm, there can be zero fuel burned for an infinite time downhill, as long as the hill is infinitely long and steep enough.
    your coasting-down-hill question is the best way to understand this. it is not the battery driving the engine, it is the potential energy from gravity doing it - by being converted to kinetic energy.
    As mentioned earlier, a rule of thumb is that you get about 4 times your speed for your mpg when coasting. This is a rough guide, that my scangauge bears out.
    ie: coasting downhill at 30 mph give about 120 mpg. These mpg numbers for coasting are so high that shutting off the fuel (while it does provide a benefit) is not enought to offset the extra coasting that may be gained.
    A combination is probably the best. If you are coasting so fast that you need to use the brakes, then you should be in gear. On the otherhand if the light just turned red 400 yards away coasting in gear will mean you stop fairly quickly, while popping into neutral will get you to the light while using hardly any gas.
    Keep in mind that coasting may have an adverse effect on you windows guides - right Blufz. ;)
    is that WalMart intersection thing still causing traffic accidents in Pierre? Or did they put up a light to let people turn left coming out of the WalMart parking lot, the south exit?
    I remember it being a growing problem there in Pierre when we left in late 2005.
    They just put a light at Harrison a few weeks ago. It helps - don't think they plan on putting one at Walmart.
    How does traffic in AZ compare? ;)
    You are probably a little closer to a Kia dealer now.
    yeah, I live in a town of around 3,700 people located about 80 miles SE of Tucson. So, my commute is about a 1/2 mile and traffic can sometimes grow near McDonald's, Safeway, Autozone, etc., on a main Willcox street named Rex Allen Avenue. Rex Allen was from Willcox and was the "Singing Cowboy" in several Hollywood movies.
    So driving is nice and mellow here. Driving over in Tucson can be a challenge. It's the city where sudden U-turns can surprise you as you take right hand turns. One guy screamed in to a U-turn one day just as I was taking a right turn after a stop. Talk about heart attack city! Tucson's up to a million people now so we definitely have a big city fairly close by. Phoenix is closing on 3,000,000 people and is about 200 miles NW of us. One does need to pay attention while driving in Arizona but I find it better than Washington state driving. Not nearly as frenetic as Seattle driving, and not nearly as bottle-necked on the freeway with stop-n-go driving, now the norm in Seattle.
    I've traded my '01 Kia Sportage 4X4 in on a 2008 Mitsubishi Lancer GTS. I love this new Lancer GTS but would entertain a Kia purchase again in the future sometime. Love their value and fun.
    And you can't rest either one in stop-n-go traffic with a manual. With an auto you can at least rest one of them.
    true, but it's always the same one. better to keep both in use. ;)
    You could left foot brake if you really wanted to. ;)
    been there done that. when first transitioning to an automatic, an unexpected situation happened in front of me, and my first reaction was to step on the brake and clutch simultaneously. if i remember correctly i was giving it gas and braking at the same time. :sick:
    Excluding physical disabilities, anyone that finds it tiring to use both their left and right foot while driving a passenger car in stop and go driving is in pretty horrific physical shape.
    I thought I might have been more sympathetic after having ACL replacement surgery last fall. But even though I needed to use crutches to handle steps for a 10 days after the surgery, I was able to drive a stick after 72 hours, brace and all. As such, the "rest one leg in traffic" will always be a sorry [non-permissible content removed] excuse for buying an automatic, in my book. And it's often used by people that could use more exercise, not less.
    When people say "tiring" what I think they mean is annoying.
    Stepping on a clutch a few times a day does not constitute "exercise", I hope you did not mean to imply that it does. In order to get exercise one has to actually get out of the car. With regard to the topic, telling people that they will be getting exercise by playing with a clutch is not going to save the manual transmission either :P .
