I'd say it's doable but you not only have the physical swap, since you are going to a FI car, you'll need to build a wiring harness for the 77 olds to accomodate the Impala engine.
-mike
My quick search online found quite a bit of info on similar swaps at dedicated toyota message boards. Start by googling 3sgte toyota paseo. Sorry I can't be of further help without doing alot of research.
It's not easy and you really need to love your Isuzu to do it but it can be done.
-mike
Motorsports and Modifications Host
I mean, the first used engine was a stretch, but once that head cracked, I would have sent it packing. It is time to cut your losses and buy something else.
-mike
-mike
Good thing is, the '85 engine shouldn't be so overly controlled by electronics that you can't swap it all into the '92. I'm just not sure what any other consequences would be.
-mike
I say stay with ford only cause you may be able to use the harness or adapt the wiring harness easier sticking with the same manufacturer.
-mike
My guess would be you'd want to stick with a Ford Motor. You'd likely need a new ECU, possibly wiring harness, and possibly a transmission as well.
-mike
Any help is appreciated. :
i would appreciate any helpful info.
to make the question more simple, is there a guide somewhere about swapping engines in general or from 1 golf to another?
all help is greatly apprecciated
-mike
Later.
Anyway my question is, would it be possible to put a fuel injected 5.0 from an '86 Grand Marquis (actually I put this motor in & the guy I bought it from said it was out of a T-Bird or a Mustang) and put that motor in a '86 T-Bird with a throttle body injected 3.8?
What do ya think????
wireing harnace will work one has the coil packs no each plugs and the other has coilpacks on top of engine what kind of problems am i faceing .
please help jc
Don't know if this is the right place for info, but here goes:
I have a 4.2 l (I-6) Envoy motor that I will be fitting into a 1/2T GMC pick-up. The problem I have run into is that the Envoy 6 cyl motor has a unique 8 bolt pattern to connect the flex plate to the flywheel. Normally, this would be no problem except I want to put in a standard transmission. I want/need some transmission speed sensors to keep the computer happy and I really want a transmission whose case will closely bolt up to the 4.2 motor. I have narrowed it down to an Aisin 5 speed from a Canyon or Colorado. Hopefully, the flywheel will interchange and the trans case will bolt up. I know that this transmission is a bit light on the torque requirements, but I am a fairly modest driver.
Can any of you offer me any help on this project? I am committed to do this, so please don't give me any "can't be done" replies. Thanks for your help.
Jeff
302 in it.Im running into clearace issues putting the engine in.I bought different motor mounts for a mustang cov.
I also have the double sump oil pan off a mustang.Im using the mountaineer tranny with transfer case.
I origanally wanted to use the transfer case that I took off but it uses 5 bolts to bolt to the tranny.
so i had to use the mountaineer transfer case that is four wheel drive all the time .Im still not having sucsess
matching the engine with the motor mounts i bought.Any feedback is appreciated
I feel for you since my inline-4 trooper is dog slow also. I'm thinking about an engine rebuild and new carburetor to pep it up.
And what about the trans? I'm assuming the bell housing's are different.
Anyone got any nuggets of wisdom for me?
TIA-
Thanks-
