Mazda Miata Problems and Solutions
With those brakes, could the calipers be seizing up? Do you feel any resistance when you hear the noise? If so I'd replace the calipers ASAP.
-juice
Ask aviboy, he's in the CX7 threads and works in a dealership.
-juice
-juice
Here are the TSB's on it.
http://www.miata.net/garage/tsb/tip_6_99.html
http://www.miata.net/garage/tsb/tsb014_00r.gif
You'll have to prove to Mazda that it was a thrust bearing failure. They might replace the engine. They have done some out of warranty. I wouldn't count on it though, with a 99 and 50+k. Have a good mechanic who will testify on your behalf check it out, or have the dealer check it out and see if they will get Mazda to cover it. My guess is that the service writer didn't know about the TSB.
here's some more info on thrust bearing failure and how it manifests itself:
http://www.aa1car.com/library/2003/eb50331.htm
I have recently moved from North to South and my 94 Miata (120 000 miles) seems to keep up just fine, except that I am now hearing a noise, pretty much all the time while driving, like an airplane. Kind of a howling or like the noise I heard, when a big truck is passing me on the highway. I had my oil changed and switched to high mileage oil as recommended by Jiffy Lupe. Could this maybe be a reason? Or what else could the noise indicate is broken or going to break? :mad:
Also, now that I will be living in the Florida for the summer I would also need to have my A/C repaired I guess it’s broken, never really used it before is this an expensive matter?
Thanks for everyone’s time and thanks to the brains behind this website, its been a great help.
What about when you are parked, idling? If so, you could ask someone to pop the hood and try to trace it to the source. Could be a loose intake or something simple like that.
-juice
Basically when I get on the gas, I feel a slight stutter/hesitation, it tends to happen at low rpm, only when I'm accelerating. It's fine coasting or at high rpm.
Our 626 did this and it was a dirty fuel system, time to pony up for the same thing on my Miata? Opinions please?
-juice
Guess I should do the full 60k service, first, and see if that addresses it. If not I'll do the fuel system.
-juice
When speeding, the sound pitch gets a little higher and faster... if this makes sense? When the car is parked I do not hear the noise, but will have someone listen this weekend, if the noise is existing when pressing the gas pedal. Tx.
-juice
I wonder if he checked for those mysterious black helicopters? :P
Though have figured that the noise is related to speed, but not to hitting the gas pedal...
I want to thank you, for being generous with your time and knowledge and helping me to narrow this down... hopefully I can drive the car many years to come, even though FL has been quite rough on it in the few month I have been here.
* new plugs
* new plug wires (30k miles on the old set)
* new air filter
* new PCV valve
* new fuel filter
* new coolant
The oil and filter were already fresh. I still have to do the gear oil in the gearbox and in the rear diff, but that'll be another day.
Boy, the fuel filter is a PAIN IN THE :mad: ! Took longer than all the other stuff combined. It's underneath the car, so you have to jack it up, crawl under, remove a dust shield, a clamp for the filter, two screws that hold the clamp in place, and then remove and reconnect two fuel lines which are incredibly hard to get off. Yikes, I made a mess of myself and am sore a day later.
I did it once before, but I guess I blocked the trauma from my memory. I said I'd never do it again, yet I did, and now I'll say I'll never do it again one more time!
Only drove it a short distance, but I'll take a longer drive to see if the stuttering/hesitation goes away.
-juice
One of the wheels has lost some of its paint, so I want to touch it up. Problem is, I don't know what aftermarket silver spray paint brand/color most accurately matches the color, and would rather avoid the trial and error method.
Any thoughts?
This may or may not be the issue but I had something similar happen to my '93. At the time it happened I had already eaten through several spark plug wires so was befuddled. I believe what you described were my symptoms also.
It turned out to be the airflow meter. Dealership wanted an arm and a leg to replace but I ended up getting a refurbished one from a local mechanic.
Anyhow, just something to check if the problem doesn't go away.
As long as I get 30k, I'm happy, but if they start to act up again before 90k miles I'll replace the airflow meter.
Thanks for the tip.
-juice
Just wondering what the significance of it was if anyone has ever heard of it. Thanks.
-juice
-juice
Mine was mounted on an elaborate Z-shaped bracket, and stuck out in front of the bumper. If any thing even tapped it, it would bump up against the bumper and create two dimples.
Oddly enough, I reversed it, hammered one section flat, and now I mounted it pointing down instead of pointing up. I flipped the plate upside down, of course, but now if it gets pushed in, it goes down and under the bumper instead of up and against it. It works as a curb feeler, too.
Doesn't help you much, I guess, but I just wanted to share. Some times a crafty and creative solution is the way to go.
-juice
http://www.miata.net/garage/swingplate.html
The NB (99-05) seem to be undervalued, while the NA (90-97) are maintaining their value. I guess it's supply and demand. Fewer of the older ones around, and still a good supply of the newer ones.
My '93 is fine, the hesitation/stutter is gone after I put in new wires and plugs.
Neat little license plate idea. I'm not sure I'd want mine to swing like that, but still.
-juice
-juice
my new MX5 GT is looking quite dirty after a few week-end trips in the mountain, and I was wondering what kind of Car Wash experience you guys may have had with your convertible. The manual specifically recommends not using automatic car wash, and I also don't want my leather seats ruined by a cheap shop employee. Also, is car waxing needed, and how often ?
I am in the LA coastal region.
Thanks in advance.
TNB
-juice
http://www.carcareonline.com/viewarticle.aspx?art=8
-juice
Bought a 2006 MX-5 in Texas and now moving back to Canada. I am aware of to significant requirements in order to be able to import the MX-5 into Canada . These requirements are from the RIV:
1) Daytime Running Light: The MX-5 does not come with DRL in US and must be adapted. I am not sure what the solution is, I believe a module is sold to fix that.
2) Bumber 8km/h requirement: The law in Canada requires a 8km/h no damage to the bumper requirement. I have asked the dealer in the U.S. and they believe it is already compliant with the 5 miles per hour requirement. However, the RIV list the 2006 Miata as requiring changes to the bumper to meet the requirement. And that's where I am, I am not sure what is needed and what the cost would be involved.
Anybody out there can help?
