Need help choosing tow vehicle
We're a family of 5 and will need an extended cab
vehicle to tow a 5th wheel (not yet purchased) for
a year-long trip. All children are under 45lb and
car seats will be used (thus the extended cab).
I'd like shoulder belts in 4 out of 5 seats and
anchor bolts for carseat tethers. The 5th wheel
will most likely be a 26' older (heavier) 90's
model (92, 93, 94, 95). I'm thinking 3/4 ton
diesel? Brand? Advice? Any reason not to buy a
used truck? The truck will be used mainly for
towing - occasionally for going out and about where
we couldn't tow the trailer (or wouldn't care to
tow the trailer). When we come back home, we'll
sell the truck and trailer.
The truck options seem so overhelming it is
incredible. Any help or pointers will be
appreciated.
appreciated.
Im sure someone could tell you about the F-250 and its features and such good truck also.
These 2 trucks are the probably only ones you will want to consider
Ryan
Ryan
and just in case you have never done this before....get an 8 foot box....to make life easier.
- Tim
I was thinking a diesel for fuel economy (we'll be on the road a YEAR) and resale value.
We're not leaving until May-June of next year (but that shouldn't matter since we're looking at used vehicles, right?).
Thanks to arkie for all the English
And a side question - can someone tell me what an Allison is?
From what I can gather, a Dmax is an engine type?
Now, treat me like a 2yo - what do the ratios mean (something to do with axles?) 3.73? and why wouldn't everyone want a diesel (for fuel economy) and a bigger engine (6.0L vs 4.9L) means more power, right? Now for the really stupid question - what does the tonnage of a truck (1/2 ton, 3/4 ton) have to do with anything? WHat does it refer to? Isn't the engine size (power - to tow) the most important? And I'm sure that there is something about axles in there too - since they're bearing the weight load...
Thanks so much for the time you're taking to answer these questions!
Allison = Tranmission
1/2 vs 3/4 vs 1 ton
The higher the number the more it can tow and haul. The heavier duty so to speak it is.
Ryan
4:10 means that every 1 rotation of the tires...the driveshaft turns 4.10 times....meaning the engine can haul more due to the "momentum" it can gain....if it was 1 to 1...the engine would strain...2 to 1...makes it easier...etc...4:10 does mean that the engine will be at a higher RPM for commuting....I have the 4:10 and it's been great...3:73 is the lowest I'd go for towing...but a 5th wheel?...hell no...4:10 would be minimal..
the 8 foot box is the long box...a short box is 6.5 feet...and would cause problems when turning as the trailer would hit the cab...they make adjustable hitches that slide back...but I don't know enough about them
Good Luck
- Tim
In general the bigger the engine size, the more torque it will put out, which is what is most important when towing. And when comparing engine sizes, compare gasoline-to-gasoline and diesel-to-diesel not gasoline-to-diesel. Diesel engines will typically put out much more torque for a given cubic inch size. While diesels will get better fuel economy when loaded and fetch a better price when you get ready to sell, they have their downsides such as being noisy, smelly, heavy, harder to start in very cold weather, and have somewhat higher maintenance costs.
Regarding rear axle gear ratio, it depends. If you've got a gasoline engine which revs higher than a diesel then I would recommend 4.10 rear end or no less than 3.73 (the 4.10 is considered lower geared than the 3.73, 3.55, etc.). With a diesel engine that typically operates at a lower RPM and has a lower redline, I would recommend the 3.73 or your top speed will be limited on the interstate with lower gears such as 4.10 or 4.30.
Regarding the Duramax and Allison combo, that is the new Isuzu Diesel engine and Allison transmission to be available in the 2001 GM heavy duty trucks. It may be a good package, but you can bet it will cost $35K+ for the truck with those options.
- Tim
heehhehee
- Tim
Ryan
actually a loaded LS is more than an LT...the LT gives you a discount when you buy the 8K or so of options....
I see many loaded LS's....almost same price as LT's...why get an LS then?....I know... I know..
"Cuz I don't like leather".......I love it..and the Cow tastes good too!..good old red meat and leather seats....ahhhhh
- Tim
(How DO people live on veggies alone??)
I am very happy with it. The rich thing was just a joke.
Ryan
Thanks again!!
Anyway, back to your point - what specifically would you suggest?
Very well said.
Rich
A used vehicle would be fine. There are plenty to choose from. I/we are looking at Ford F250, diesel, with an auto transmission, with no more than 40K miles. The dodges are too loud and, in my opinion, you can't rely on their transmissions. The F250 (3/4 ton vs. the F350 1 ton) will ride better unloaded. I have two children (a just turned 4 yr old and an almost 2 yr old). The supercab is fine for us with both in car seats. We also carry our dog in the cab with us.
As for the 6 1/2'to 7'(short bed) jack-knifing when you back up, I wouldn't worry about too much. If you can't see your trailer about to hit your you don't need to be driving it anyway.
The thing about keeping it one year and then selling...I speculate that it will be easier to sell a short bed(my opinion). I would also like to find a truck not set up to tow heavy loads. If it is set up already then it has probably been doing it already.
Sorry for being long winded....Good Luck.
With that info , I am going to get a 2001 Silverado Ext.cab SB 1500 LT.
Questions : engine size
locking Diff.
ride control
3.42 0r 3.73 rear end
Any body answer these questions ?
Thanx - Ken-o
One quick thought, are you SURE you're not going to get a bigger camper in a few years? If you are you might want to think about F250. Oops I mean the 2500 series. If not no worries.
My father-in-law and my brother have the 2000 1500 Silverado and Siera respectively, with the 6.0. They tow a 25' and/or 27' TT's at a little bit higher weight than yours but not much. They would not want to tow any more at all. Knowing you don't have to work the truck to death when you go through the mountains(even the small ones in North Ga.) is a good thing. I'm sure my brother has the 3.73 gears probably my father-in-law too. That would be the way to go.
As for locking diff./limited slip/posi trac whichever it is called, DON'T buy without it. You will need it. Almost all campgrounds and I would say every state park has some dirt, rocks, wet leaves that will give you fits. Especially when you have to back onto a board to level you camper.
Happy Camping.
KO
Rear end: 3.73
Also what is it 2wd or 4wd???
If its a 2wd definitly go with the locking diff. I have a 4wd with the locking rear and i like it glad i got it.
Mine is a 5.3 with the 3.73.
If you get a 4wd and do alot of towing id opt for the 4.10 rear end.
Ryan
Have had no problems but do have new truck fever and am trying to figure , do I really need a 3.73 or should I go to a 3.42 and a 5300 Vortex?
also no way would I go back to
(F)ix (O)r (R)epair (D)aily
Ken-o
Ryan
I think I prefer (from given choices) the 5300 Vortex with a 3.42 and auto.Just 1 more question.
Will it be slower on take off with the 3.42 ?
Ken-o
Ken-o
Ryan
Ken
opps sorry bout the caps
a 4.10 will be more powerful than a 3.73.
These new GM engines don't seem to care what rpm they run at. Even the trucks with 4.10 gears are getting pretty dern good mileage.
Ken-o
By the way I spell it
F(irst) O(n) R(ace) D(ay).
(F)ound (O)n (R)oad (D)ead
Ken-o
this topic is being "frozen." It will be archived or deleted in the next 10 days or so. Thanks!
Front Porch Philosopher
