Chevy Silverado - Continued XV
On the break-in period deal, I damn sure didn't mean to open up that can of worms again!! Lots of folks have cited the fact that Corvettes, Porsches, Jaguars, etc. all come factory filled with synthetic oil, so it must be OK to use synthetic from the get-go. Me, I would just rather wait a while to be sure. My dealer said it was OK to switch at 1,000 miles if I wanted to, but recommended I wait until the engine quit using oil, so that's what I did.
I forgot about using grease in the wheel bearings. Are we supposed to do that on the newer vehicles? Remember doing it on the older 70's and 80's vehicles but not on the newer ones.
There was a guy in England trying to make a completely new motorcycle called an FF for Feet Forward. He had center hub steering and complex linkage for the steering. He couldn't find a grease that wouldn't wash out of the linkage. Just driving in the rain washed all the grease out and the steering got unpredictable. Until he tried Mobil 1 grease that is. The Mobil 1 was unaffected by water, rain, road wash, etc.
That is when I started to use it. Admittedly, we have rubber shields on all the tie rod ends, etc. But, it isn't hard to imagine one getting torn on a thorn when off road, and getting exposed to water and wash out. Just like the oil, it is cheap insurance for a vehicle I want to keep a long, long time. It probably isn't needed, but it isn't much money, it can't hurt and it might help.
$1.00 - .98
Mike L
took 30 minutes
Only bad thing dropped the filter in pan and made a huge splash
Ryan
Well at least its done...now on to bigger and better things. Ever thought of trying to change a cam or pistons? (just joking)!!
Dean
Xring,
I changed the factory oil at about 1000...then put regular oil in for 3000...then M15-30 at about 4K. My 6.0 has 21K miles and runs fine...
- Tim
Buck
born in the 60's.....
Ryan, did you prefill the oil filter?
Dean
Our local guys refused to budge by the $500 extra we needed to feel good, so 4 calls later the guy in the next town over met our price. $4k off from the dealer puts him right at invoice and, after the rebate puts us $1k below.
Headed over to make a shake down test drive and then drive of in our indigo blue Z71. I sure hope we don't walk into a bait 7 switch or some such, cause we're excited. I feel a little bad about the local guy, but he gambled.
Now we decide whether to go with the 3" lift...
...red
Thanks for the info. I'm in no hurry to change to M1, just currious when others did. Did you reset the message center when you changed oil at 1k and 4k?
Just wanta to make this engine last as long as my 5.7L did in my '86 Burb - drove that beast for 15 years and 195k miles - used Pennzoil 10W30 and fram filters - that was sweet beast. Yeah the engine was getting tired but I could still go 2000 miles on a quart of oil. Got a little puff of blue smoke on cold engine start, but didn't think that was too bad for its age. So, just wanna make the rado last as long with as little repair as the 5.7L.
ALWAYS prefill the filter when you change oil! Good advice guys!
P.S. - I hate to show my age, but I bet I've been changing oil longer than most of you have been alive - but don't call me OLD.
John
John
I only dropped the damn filter cause it got stuck on the skid plate. Also i used no jack stands at all. Truck just sat on the floor pretty easy to get under there.
Yes i did prefill the filter
I have helped my dad change oil but i actually did it myself he just sat back and watched to make sure i did it right.
Oh yea check out http://www.picturetrail.com
Type in ryanbab
I added some new pics. Closeups of the tail light guards, one with it next to my mom and dads blazer and one with the sticker you can actually see.
Ryan
Oil Light....I can only seem to re-set it when it goes off?....or at least it will only flash if it's gone off..
The light comes on at about 4200-4800 for me...and I usually go another 1000 or so after that before I change it....
- Tim
bco
Press gas pedal 5 times quickly
Oil light flashes 5 times
RESET
Oh yea i didnt mention and totally forgot last friday when i was drying my truck i had the ext cab window popped out. Well the little black latch broke. The window wasnt attatched to the truck. I just had to snap it back together and its been fine since.
IM OFF TO THE CUBS GAME!!!!!
GO CUBS GO!!! haha
They are gonna lose watch ill be right behind 1st base line so everyone watch for me.
Ryan
....unless you bring the ado with you in teh stands?
- Tim
Um i know what ill be in a blue cubs hat does that help???
Ryan
Oh, Ryan, thanks for all the info on your lining, I'm certainly getting one sprayed in before winter starts, which is usually mid-Nov around here. And yes, I've got the solid Indigo Blue with Black flares, dark tinted rear windows, etc. Our trucks look the same except mine's a year newer, but probably dirtier.
Don't wanna turn this into a PC forum, but Micron builds better PCs because the people here overall have a good work ethic, are very friendly and trusting, and the company treats the employees well. There's always exceptions but if you get a Micron PC you'll have a good experience and also be working with good people. I don't work for Micron PC but I know alot of people who do.
To fill it ahead of time takes out that "dry" run that will take place as the engine pumps the filter full...once full..then the oil can flow..
Now while this is not a life or death thing...(I never did it for years on various cars)...it most certainly helps...
- Tim
(Of course my wife uses Windows, so I do have to fix her's. Quite often).
Back on topic, I think I'll try that Zaino wax that some on the list like to use. Sounds like it gives quite a finish.
Is it available in local stores, or is it best just to order it on the web site?
Richard
www.zainobros.com
Good luck!!!
Carmine is for the old farts, I'm still young at heart.
That's the neat part of a truck - just pull it in the garage and drop the plug, no need to use ramps or anything. Even my boyish figure still fits under my 2500.
John
Dean
Cubs lost
7 hrs all by houston
Ryan
John
Mark
pacific-audio's site so some of yall I might know.
Anyways, here is a link to some pictures of my
truck: http://www.geocities.com/danielz71
I have a 99 Silverado with a 3 inch body lift and
33x12.50 tires and a whole lot more stuff.
Dean
Jerry
you? also, the ngk 55 plugs, did they make a
difference?
...red
falling off, "very interesting".
on the ngk's, did they also make a differenc
other than idle?
...red
cabin air filters
Called five dealers including both Chevy and GMC dealers. No one stocks them and had to special order. Seven days and counting.
Dean
Ryan
ordered one of about all system - that way
can see what use and how far each will go.
printed out form and sent snail mail.
With my vehicles and folks car different
formulas won't go to waste.
bco - the computer pics is getting
expensive. Got talked into upgrading to
a notebook laptop. Never say never - not
going to spend over $1000 -- its over $2000.
Probably more than need but friends
love to be helpful!!! - We haven't even
started on cameras - ouch!!! S@#* it doesn't
have a 3.5 floppy at the price but cheaper ones
did????. Better go by myself for the camera.
Silverado question - I've change my oil
twice myself, just pull around back and its
done. Been using the Delco filter but clerk
was recommending others. Has anyone found better
filters to use???. At least with trucks one
can still do a few thing - on car no way -
don't think can slide a pie plate underneath.
Randy
Used the Mobil 1 synthetic chasis grease for the first time - its a nice plum color, not black like the lithium based greases.
Change oil for the first time at 1901 miles and used 10W30 dino oil. Oil was dirtier than I expected! Noted that the drain plus has a little magnet "[non-permissible content removed]" on the end - anyone else notice this?
Took you guys advice - will wait before going to M1.
John
Type in KWERKING in the visit album to the left
Ryan
PS your welcome kyle
Thanks. You went to a lot of effort to post those pics. Appreciate your work!
John
