Toyota Prius MPG-Real World Numbers
17810121320
    carbotcarbot Member Posts: 14
    When I first got my '04, I did a series of tests to determine the fuel tank reserve. I first drove 25 miles after the light started blinking and noted how much it took to fill it. Then the next tank 50, next tank 75, etc.. I ran out of gas at 94 miles after the blinking light started. Now, routinely, I zero my trip odometer when the light starts blinking and when it hits 50, I start looking for gas. Since I drive over 3000 miles a month, it didn't take long to do this test.
    paul34bpaul34b Member Posts: 33
    Its funny you make a joke of the non-hybrid version. The following is a true story. About 6 months ago I received a call from my local dealership from, what I believe was a new salesperson. He first wanted to know how my current Toyota Prius was handling. But second was I aware that Toyota now came out with the hybrid version of the Prius? Wow that surprised me. I didn't realize that there was a non-hybird version (of course I know that). As soon as I started educating him, he got a bit nervous and end the call quickly.
    carz89carz89 Member Posts: 16
    Hilarious! Yes, some car salespeople are just like telemarketers in one respect ... as soon as you engage in conversation about something their job requires them to be knowledgeable about, you soon realize how ignorant they are!
    The salesperson I bought my Prius and HH from knew absolutely nothing about the cars he sold me, but at least he was very aware of his own shortcomings and didn't BS me. Some salespeople are so proud that they will fabricate information on the spot if they don't know it.
    I did come across some extremely knowledgeable salespeople when shopping for my hybrids, but did not end up purchasing from them because they couldn't offer me the best price.
    bonniejerrybonniejerry Member Posts: 2
    I'm on my second Prius ('04, 06) and also own a 400h hybid. I have attempted to fill the tank to capacity, but super conservative Toyota really puts a margin on the overflow valve.
    My record is THIRTY clicks after the pump clicks off and I have NEVER overflowed the tank one drop.
    Weird.....
    rockpsl76rockpsl76 Member Posts: 6
    Do you know how many gallons you needed for a full tank a -94 and -50 miles? Or right at empty for that matter. Those would be a more valuable number to me. I find it hard to beleive the Prius needs a 2.5 gallon fuel reserve.... I used to run my Malibu down to half a tank on a regular bases and I never once "ran out of gas". What good is a fuel gauge if it isn't acurate :(
    vanderhorstgvanderhorstg Member Posts: 17
    Our state/county (Oregon/Lane) is moving toward a requirement for all gasoline stations to sell at least a 10% mix of Ethanol. I thought I read that the Prius engine cannot use biodiesel; is this E-10 fuel a problem for my Prius? I own a 2006 and I LOVE IT! I'm currently averaging about 45 mpg - with a combination of in town & freeway driving.
    pathstar1pathstar1 Member Posts: 1,015
    In the owners manual Toyota says you can use "up to 15% ethanol fuel". With 10% you will loose about 2 MPG (ethyl alcohol contains less energy than "gasoline"). The engine will run cleaner, however (less soot deposits in the engine). So yes, E10 will be fine (I have been using it for the last 8 months).
    I think you're a little confused. You don't have a diesel engine, so no, you can't use diesel or biodiesel. You can use gasoline and gasoline containing up to 15% ethanol, or E15. Regular grade gas is best, but be aware also in the manual Toyota states "recommended use of Premium grade gasoline". They are referring to the "enhanced" gasoline that several auto companies and oil companies have come out with - see Shell commercials for info on this. They are not referring to the octane rating. 85 or 87 octane fuel is just fine in the Prius.
    Thanks for the clarification. Yes, I was confused about the difference between Ethanol and Biodiesel. I also read somewhere that the higher ethanol fuel can make it necessary to replace the fuel filter more often - have you any experience with that?
    I know the ethanol change is better for the environment etc., but it's too bad it has to come at the expense of the better gas mileage that the Prius can produce on regular gasoline.
    There are reports of fuel stations having problems with ethanol fuel. They are in the minority. Here in Canada Mohawk Oil was the first to add ethyl alcohol to the fuel. This was about 15 years ago. They went through a lot of underground tanks until they learned to put in better quality ones, and look after them properly. Other companies will be on this learning curve now, but I presume they will benefit from Mohawk's experiences.
    What happens is ethyl alcohol can absorb water, either liquid or water vapour from the air. This allows the water to "dissolve" in the gasoline.
    The good part of this is it allows the car to "burn" any water that gets into the tank (reasonable quantities of course). It also acts like "gas line antifreeze", which is usually isopropyl alcohol.
    The bad part of this is the water can contain oxygen, which can corrode the underground fuel tank. This takes years. BUT, if the underground fuel tank was already perforated by corrosion, then groundwater can get into the tank. A lot of it. This "extra" water promotes the growth of bacteria that make a living of turning iron into iron oxide. So you get fuel with rust dust, chunks of rusted iron, and water in it. Lots of people blame this on the ethanol. It's really the fault of the cheap fuel station owner, not properly maintaining the underground tank system. They will put off replacing the tank, thinking the fuel floats on top of the water, so there's no problem. Then they get caught when the fuel leaks into the ground.
    So yes, if you fuel up from one of these effected tanks, you will be changing fuel line filters. But you would also even if you were using "normal" non-ethanol fuel. It just takes a few months longer for those underground tanks to fail.
    I fuel up from newer stations only. Ones that get a lot of traffic. That usually ensures the fuel is clean.
    Ok. I've only put about 600 miles on the car so far, so maybe this will improve, but I'm currently getting about 55 MPG on the highway and at best 30 MPG in the city (if I really really baby it to the sound of blaring horns for my whole trip). The problem is my work commute is about 10 miles and 10 stop lights, so I'm spending a lot of time stopped. Anyone know of any ways to improve my mileage in city driving? I'm currently only getting about 300 miles a tank which is pretty pathetic... I had better range with my old gas guzzler :(
    When I am at a stop light is it better to depress the break fully (so no energy is flowing, or leave it only partly pressed down (so that energy still flows from the electric engine although the car is not moving)? I have been depressing the break fully, and I was wondering if it would ease the initial acceleration from 0 (which I always do super slowly and get a few honks) which takes a lot of gas. Range was one of my motiviating factors for buying a Prius, and thus far its been an utter disappointment :(
    You didn't mention where you are, but the cold of winter really gives the Prius a mileage hit. Once it warms up the mileage is really good. I'm probably in a colder place than you and I'm getting 6.5 l/100 km or 36 MPG US. Similar trip lengths. In warmer weather (spring, summer, and fall) I get 4.4 l/100 km or 53 MPG.
    Use full brake when stopped. There is only about 2 Amps fed from the battery if you don't press fully, but it's still wasted energy. Also, use "D", not "B".
    Accelerate normally from lights. It's the slowing down where you can save fuel. Try to anticipate the light and slow a long way before you get there. Don't worry about the nuts who will pull around you so they can wait at the light before you get there. Just keep telling yourself they will be the first at the accident! ;) Once you get up to speed try to "feather" the throttle to just maintain your speed. That will allow the car to save you some fuel (it may even shut down the engine from time to time once it has reached full warmup).
    Make sure you have lots of air in your tires. Most of us put in more than the door sticker calls for. I use 40 PSI front and 38 PSI rear. This actually also improves the tire to road traction, yet decreases drag. Check the tires at least once a month.
    Be patient. It takes most people a few months to learn how to drive economically. Use your MFD (multifunction display) to help you to learn what actions save fuel.
    Yeah, I've been doing all those driving techniques you mentioned, including the coasting and gliding. Thats how I am managing 55 MPG on the highway at least. Unfortunately 85% of my driving is in the city :( I live in the Boston area.
    Thanks for confirming my thoughts on the stop light braking. I guess I'll just have to wait until it warms up a bit before I'll see decent mileage on my commute.
    Its good to know you are getting a 50% boost in MPG during the summer. Gives me hope I might get a little better mileage in the summer at least. Where do they get 48 city / 45 highway from anyhow? I can't comprehend how anyone could be getting better mileage in the city given the disparity I'm seeing?
    BTW, how well does the MFD display really work? When I first start driving, its all downhill, so my display shows just blue arrows feeding the battery, but my MPG is showing like 9...? How can I be getting 9 MPG if my gas engine isn't even producing any energy?
    scottc3scottc3 Member Posts: 137
    I think going downhill you MPG should be 99.9 mpg.. not 9. If it's not showing this, does it ever show 99.9? or in the high 90's? If not, you may have a problem wtih the display. Don't panic here, just have it checked or compare to others. Are you accelerating going down hill? If so, try coasting - foot not on the gas, and see what it reads.
    sc
    The mileage is low going down the hill because the engine is running on a warmup cycle, using enriched fuel mix. It only runs at 1280 RPM, but it still burns fuel. This is the big hit on mileage in winter. Once my car warms up it seems to get almost the same mileage as it does in summer, so you can see how big a hit the warmup cycle is. You have to get the coolant up past 60C before the car will go to "stage 4", so it will shutdown the ICE when it isn't using it. Idling will not do this, I have to drive perhaps a mile before I see this coolant temp (I'm using a "Scangauge II" - an OBDII reader, to monitor the temp, battery voltage -12V, and two other parameters). If you only drove longer commutes you would see better average mileage, as the poor warmup mileage would be spread over more good warm running mileage numbers.
    As for MFD accuracy, each car seems to be a little different. My car seems to read a little low on mileage most of the time. However, it's difficult to tell because you can't consistently fill the fuel tank each time, so your checks on mileage are not consistent. Others have reported the MFD reading to be about 10% optimistic. Isn't that why they say "YMMV"? ;)
    Thanks for the reply. I figured it had something to do with the engine warm-up... I guess my short commute (about 7.5 miles) through a myriad of stop lights means I'm not going to get the same benefit from a Prius the average person would. Especially in the winter time :( Ah well, 30 MPG is still better then what I used to get. Now if I could just use more then 10 gallons of that 12 gallon tank, I might actually be able to get a reasonable range ;)
    I also noted that the engine will frequently turn on (after engine warm-up) while I'm going down hill with the break applied for the soul purpose of charging the battery once it reaches blue. This happens at around 60-70% of total battery capacity. Is this just Toyota being obnoxiously conservative again? I mean, I'd rather let the battery use a bit more energy. If I do hit the highway it ramps up for full green pretty quick anyhow. Once it hits blue, it doesn't matter how I drive or at what speed, the gas engine turns on an frequently does nothing more then charge the battery...
    newpriusownernewpriusowner Member Posts: 3
    Hello everyone,
    I just bought a Prius two weeks ago. I have to say I've been disappointed with the mileage so far. But I like the car. By my own calculations (first tank) I'm averaging about 33. I live in Dallas. In the morning's it's a bit cold now so I have noticed gas mileage is lower than in the evening, where I come out from an underground garage at work (usually close to 60 degrees). So now I know. My commute is 15 miles, 1st mile local, next 12 highway, next 2 local.
    pathstar1:
    1) My engine charges when it is high blue also. Hate it.
    2) Never have hit full green yet
    3) I have confirmed coasting always helps, even when the engine is cold. When the engine is warm 99.9 on the display is very possible (I turned the display off after realizing the readings were not accurate. Also too distracting.)
    4) I do need to check my air pressure (thanks to someone who mentioned it above) and I will hold the brake down at lights from now on.
    5) Today after going to 1 bar I added 3.3 gallons ($10) and the bars suddenly jumped to 6. Still very puzzled by the display.
    6) I did accelerate suddenly for a bit, re-read the manual said it was a no-no. Stopped that.
    7) My MFD is telling me 41.5, but it did get reset 20 miles ago. Currently I'm at 380 miles. Will let everyone know what I average when I fill up later this evening.
    Nice forum. Thanks for the advice.
    newpriusowner
    ces1938ces1938 Member Posts: 61
    Hey guys, relax... if there is anything that I have learned in my 70 years and after many new cars of all kinds, you may as well accept what your car is getting and that is it... the fuel estimates are just that, some where in the ball park and usually way below... they are just lying about it and they get away with... really that simple sorry but that is the way it is... if you accept it than you wont be so frustrated.... in the 50 years I have many new cars and not one ever come close to what the gas mileage predicted... so buy what you want and enjoy it and don't even pay anything to gas mileage and you will be happy... One thing I have learned it does not matter a whole lot of what you buy they all use a lot of gas, so get one that is fun to drive and let it go at that.... good luck folks... :) :shades:
    So I filled up the tank. I was able to add 5.2 gallons before the gas pump stopped. So I've added 8.5 gallons so far. I restarted the mileage at 390 miles. We'll see how far it goes.
    ces, good advice. I'm not old enough to know that (this is my first car) so I want to enjoy every aspect of it.
    newpriusowner
    There are a few mis-conceptions floating around about exactly -why- the Prius engine is running. Note that the "engine" is the gasoline powered device, and the "motors" are the electric "motor/generators".
    1. The engine runs to warm up the cat. or to keep the cat warm, which must be kept quite warm to function properly. This is "job 1" for a Prius - keep emissions very low.
    2. The engine runs to keep itself warm, so it can stay in the "stage 4" mode, where it can shut off the engine if it doesn't need it. It sounds funny that it has to run the ICE so it can shut it off, but there it is. In the summer this is not an issue.
    3. The engine will run if the coolant drops below about 63C if you have the heater on.
    4. -IF- the traction battery gets low in charge (below 40%) the engine runs to charge it back up to around 60% charge. The battery is run from an absolute low of about 30%, but usually 40%, to a high of 80% charge. This is to ensure the battery will last a long time. Taking the battery below or above these "setpoints" will increase the chances of fully draining or over charging individual cells, which would damage them. Note that these percentages are not the full green bar/empty red bar indications of the SOC indicator. Those take the set points into account, so full green is actually about 80% charge, and one or no red bars is actually 30-40% charge.
    Also keep in mind -you- don't actually control this, the car does. You CAN "influence" the SOC as well as when the engine runs. If you use "Climate control" and leave it in "auto", when you want the engine to not run turn it off on the steering wheel. Then, if you take off from a light turn it back on again. I personally don't bother, but you can slightly improve your mileage by doing this. I'd rather have non-misted windows and be nice and warm. :)
    pathstar1,
    Thanks for the info. :)
    I definitely didn't know the battery stays in a range of 40-80%. This makes sense from an engineering standpoint. I don't leave my climate control on auto usually.
    What's SOC stand for by the way? Also what are the 4 stages the Prius goes through? Which stage is the best?
    Learning and confused newpriusowner
    kdhspyderkdhspyder Member Posts: 7,160
    ONe of the biggest drains on all vehicles, hybrid or not, is having to accelerate from a dead stop. Overcoming the inertia of standing still is a HUGE waste of fuel. There is no way to obviate Newton's Laws.
    I did a similar test on the streets of NYC where I used to live and work. Going across town from stop light to stop light to stop light I was only able to achieve about 35-40 mpg, this with a fully warmed up vehicle. However going south along one of the major Avenues at a constant 25 mph I was able to achieve 70-80 mpg!!!!!! Same trip, same vehicle, same city, same everything excluding the stops.
    This is one of the few unknown limitations on driving no matter the vehicle. A good solution would be to replan your route if possible to avoid the stops.
    ***65,000 mi on my 2005 ( nowhere near carbot's 2004 ) with a calculated fuel economy of 47.9 mpg ( 2.09 gpc ) as per GH database.
    Regarding the fuel capacity questions, dont worry. I'm pretty sure that no one explained to you that you have two gas tanks in your Prius???? Huh?
    Actually in order to reduce/eliminate evaporative emissions there is a fuel bladder inside your tank. When the vehicle is new the bladder is still stiff and not expanded to its full capacity. This is doubly true during cold weather when the bladder might be stiffer than normal in the cold AMs. As the weater warms up and the bladder breaks in you will find that as you get down to one bar you will put in about 9.0-9.5 gal when the last bar begins flashing. This is intentional, not only with the Prius but with all Toyota's ( e.g. the light on the Camry will come on when you've used about 16 o/o 18.5 gal ).
    As carbot noted you can drive a good 50 mi safely before you must refill.
    SOC is "state of charge". It's calculated by the cars computers (power in - power out) not assumed by looking at the voltage.
    Funny, I looked up -again- the document on the warm up stages, and it appears there are actually five. It's complex and appears at:
    http://www.techno-fandom.org/~hobbit/cars/five-stages.txt
    These are enthusiast named states of operation. I don't believe Toyota uses this description.
    Note that the "EV" (electric vehicle) switch is not installed in the North American models, though the programming to operate the car using it is. If you do want to install this switch, you can purchase a "stock" Japanese one. You will void your battery warranty though. What this switch does is extend the parameters for electric only operation. The car will still start the engine and use it if it needs to.
    Stage 4 is the preferred one to be in, as the car is fully warmed up and will have the best chance of getting good mileage.
    Today I hit 1 bar left on the gas gauge. Not wanting to push this, and to check how much gas I had left, I filled up. I put n 8.756 gallons and drove 430 miles. This equates to 49.1 mpg with just over 3 gallons left in the tank. Now I know I can easily drive 100 miles when I hit 1 bar and was pleased with the 49 mpg for the 1st tank.
    sc
    You're making a dangerous assumption. The fuel tank capacity changes due to the bladder being more or less "streatchy". This is one of the reasons Prius owners run out of gas more than -any-other-car-! I've seen reports from owners who have only gone 40 mi. on the last pip.
    So don't get mad at anyone but yourself if you run out. The car gives you lots of warning.
    I must be of Swiss heritage. I fill up after the car gets below 1/2 tank on the gauge. ;)
    LOL.. I'm in that group but I'm aware of my personal predilictions. I tend to push that last bar....but I've been rewarded with the 'triangle of death' 4 times.
    fluid_dudefluid_dude Member Posts: 2
    I am a new Prius owner. Purchased a 08 package #6 last Tuesday. I typically drive 40-50k miles per yr and spend most of that time on a highway. in just 4 days I have put almost 800 miles on it. Live in MN and dealer tank gave me about 34 mpg, second tank gave me 43.8 mpg. Currently on third tank and reading about 38mpg (but it is also currently -15F temps).
    Could you please explain to me what the various stages of the ICE are? You mentioned Stage 4 mode to shut the engine off if not required.
    Also, should you normally be able to show a battery full charge (all bars)? I haven't seen that happen even once on mine. The best I can get is 1 bar away and only for about 2-3 minutes. However,I do need to bring it back to the dealer as when I'm coasting the blue arrows go from the tires to the motor to the battery, but it doesn't change color when braking. (I test drove another one that does change color under braking and talking to the dealer on the phone they said the other 08's change color also.)
    Anyone out there that does alot of highway driving (70% at 70-75mph) that could tell me what kind of MPG they are getting would be much appreciated.
    Thank you all.
    I don't do as much as you do but I put about 35K on mine annually. It too is about 70% highway but the max speed I'm allowed is aobut 65 most of the time.
    Lifetime over 65000 miles I'm at 47.9 mpg....but here are the caveats....from a post that I made in the Camry hybrid forum last year here
    Factors affecting your FE ( and everyone else's also, btw ) in decending order of importance...
    1) Towing anything is a huge penalty possibly as much as a 50% reduction in FE
    2) Lots of weight in the vehicle, passengers cargo etc. ( EPA tests are done empty ) deduct up to 20% from your 'Norm'
    3) Short trips under 10 min - deduct 20% from your 'Norm'
    4) Snow, Rain, sleet - deduct 15%
    5) Strong head wind - deduct 10%
    6) Cold weather - deduct 5 - 10%
    7) High speed driving 0ver 70 mph - deduct 5 - 10%
    8) Many starts from a dead stop ( going from stop sign to stop sign to stop sign ) - deduct 5 - 10%
    9) Terrain - fortunately 'what goes up..' usually this balances out on a RT
    10) Winter fuel - deduct 2 - 5%
    11) Low tire pressure - ? How low
    In your type of driving you probably won't run into a lot of these like many starts and stops and towing and short trips. But cold weather, wind and slippery surfaces will have a huge cumulative effect of as much as maybe 10-25% reduction from your best results. Pathstar1 who lives in CA would be able to give you a better perspective on these factors.
    Afriend who posts here also is at 175,000+ in just over 4 yrs but in the Middle Atlantic region where it's milder. I believe that lifetime he's around 47 mpg also.
    I posted the URL for the "stages" in post 483 of this discussion.
    Many Prius owners have posted they have only seen green bars after a few months. It -may- take the car that long to be sure of the full capacity of the battery, self calibration so to speak, or it -may- be (my choice) that the NiMH battery needs some charge/discharge before it begins to work fully. At any rate, I didn't see -any- green bars until 2 months after purchase. Usually you won't reach full green unless you descend a long hill, such as a mountain pass, though it is possible if you are really economical in the city. You won't see green on level highway, or at least I don't. The car tries to keep the SOC (state of charge) at about 60%, blue bars. I doubt there is anything wrong with your car.
    Once the car is nice and warm, you can get up to 50 MPG on the highway, but that's a summer figure. The faster you go, the worse the mileage. You probably loose 2 MPG to the ethanol in the fuel, another 2 MPG to winter added friction (oil viscosity and stiffer tires). Then there is added loss from heavy winter winds, and snow pushing. Be aware there is a breakin period during which you will not achieve the good mileage figures. This includes breaking in the tires. It seems to take 2000 - 5000 mi. You should be able to achieve 45 MPG in the summer and 40 MPG in the winter with no problem, once broken in. Many do better with practice. The winter warm-up cycle is very hard on mileage. I notice that once my car is fully warm, in winter, it starts to get nearly the same mileage as it did in the summer, but the average really suffers. My summer average, once I learned and the car was broken in was getting up around 53 MPG US. Right now it's averaging around 40 MPG! City only in winter.
    eprupiseprupis Member Posts: 30
    I filled my tank (8 gallons) with 10% ethanol for the first time. Here in the flat SC low country, I average 53 mpg consistently. This time I averaged 50.5mpg with no change in route or driving technique. I then made it my business to fill the next tank with pure gasoline and I immediately saw my mpg go back to 53. Although 10% ethanol produces a 4% mileage penalty, the price at the pump is no lower than stations without ethanol diluted fuel. Considering the effect of ethanol production on the cost of grains and meat, and the impact of its production on the environment, I think the promotion of ethanol is a huge mistake.
    You raise a good point. For me, the gas mileage is a sidebar to the cleaner emissions of the Prius, but use of ethanol shouldn't be pushed as good if it's more harmful in production!
    From an envoronmental perspective we're agreed.
    However the reason for the E10 addition has nothing to do with the enviornment it only has to do with stretching out the petro-fuel supply by 10%.
    bob104bob104 Member Posts: 94
    I think you've covered all the bases. Not to quibble but I wonder a bit about some of your estimated impacts. From memory . . .
    2) rule of thumb: each 100 pounds of added weight reduces impact by 1% (depends on car, of course). So a Prius at full capacity--850 pounds would get about 7% worse mileage than a Prius with a 150 pound driver alone. Ex: 46.5 mpg instead of 50 mpg.
    7) rule of thumb: each 10 mph faster costs 15% in mpg. This depends on the car. Some cars start paying the penalty at 35mph. Others at 55mph. From my experience my Prius going 55mph gets mid-50s mpg and going 70mph gets mid 40smpg--about 20% difference. Going 80mph will drop your mpg near 40.
    9) Hilly terrain will cost you in mpg compared to flat because there are inefficiencies as the transmission finds the sweet spot and due to braking (the regen brakes don't recover all the energy) and high revving (less efficient) on acceleration.
    The high-mpg tips:
    limit braking, as possible
    drive the speed limit
    mind the tire pressure
    limit short trips (combine errands)
    maintain steady speed, as possible
    don't tow (voids the warranty!)
    use car carriers judiciously (a Prius with a carrier still beats a minivan)
    winter in Florida
    I just had my Prius at the dealer today to check the coasting vs braking arrow colors and have them check the alignment. First off, my steering wheel was about 3-5 degrees left when tracking straight on the road and I wanted them to check the alignment/wheel position because I believe I should get what I pay for. The put it on the rack, noticed a slight toe in on one tire, fixed it, recentered the steering wheel and then ran full diagnostics on the computer system and checked the arrow colors. These guys ran through the system for 2 hours checking everything, setting customized settings for me (at no charge) and let me know that Toyota has 3 manufacturers for the touch screen system. depending on the package, there may be differences. For example, package 6 (mine) will not show a different color are from regen coasting to regen braking, other packages on the lot did and the other package 6's did not. They threw me the keys to other 08's to drive around the lot and see for myself without me asking. After all they went through they only charged $110.00 to warranty for the work. Great service.
    Talked to a very knowledgable service guy about the battery bars. As the car goes through break-in, it will find the high battery levels and then find the lower battery levels (no more worring about engine charging at 6 bars all the time). After about 10k miles, it should be going through the full programmed range for the battery (and FE will improve also). He also mentioned many of the same items to watch for FE changes as read on this sight. He has one customer that drives the same way, same route all the time and can get pretty close to knowing the outside temp based on his FE display. Also warned about a guy who ran out of gas on the blinking light issue and drove on battery to the gas station. He fully drained his batteries and wound up buying a new battery for about $5k. He also has a customer with 200k on the orignal brake pads.
    I did reach full 8 bars on the battery today (have 1260 miles on now) and am getting better mileage by being able to stay in Electric longer when coming of the highway.
    Just one side note: My 04 Explorer gets 18mpg avg in the summer and 15-16mpg avg in the winter driving the same routes (thats the same 10-15% drop as the Prius and all others). It's just more noticable when the numbers are larger.
    lilredpriuslilredprius Member Posts: 2
    this is my second Prius. I purchased one 3 years ago and stupidly sold it when I moved out of the area. Now I'm back
    Bought a bright red one last sunday - got the leather seats this time, which are nice.
    I'm averagine 53 mpg on my commute. Means one measley gallon of gas a day to go to work and back. I'm very happy. 300 miles this morning total, and it just hit the halfway empty on the tank.
    cheryl06priuscheryl06prius Member Posts: 50
    In the Buffalo area E10 is starting to crop up everywhere, although it is no cheaper per gallon than non-ethanol.My question is: in areas where E10 is widely available, is non-ethanol still available at the same gas station, or does a seperate gas station carry only non-ethanol. Has anyone noticed a price difference?
    rcinmdrcinmd Member Posts: 139
    Here in Maryland, E10 is now mandatory, so there is no option regarding the purchase of non-ethanol-laden fuel unfortunately. The pumps indicate "at least" 10% ethanol. I know there are advantages to E10, in terms of octane and its cleansing properties. But the mileage takes quite a hit. On my Touring I have seen a reduction from new on certain drives, dropping from the low 50s to the upper 40s. In addition, winter gasoline here is oxygenated, and that hurts mileage even more. This past summer I could eke out 47 or so mpg to and from work, about a 3 mile drive. During this relatively mild winter, I have been struggling to hold 40 mpg. It seems that if I use Virginia gasoline, even though E10, my gas mileage is significantly better than with the winterized Maryland gas.
    Thanks for your response. I spoke with someone from corporate hq at the Flying J Refinery and he stated they currently are not offering any E10 in NY or PA(I didn't ask about MD), It appears there is much uncertainty as just how much E10 will be sold in NY, but that conventional no lead will probably be around for the forseeable future, at least in NY. Paying more for E10 and getting less FE is a ripoff we can be thankful to the government for, both political parties share the blame for appeasing the farm lobbies.
    Perhaps you don't understand. E10 was mandated in most states by the feds for several reasons:
    1. It replaces MTBE and Techron, both toxic chemicals that were getting into the groundwater. Ethyl alcohol is a naturally occurring chemical that -can- get into the groundwater, but wouldn't be toxic unless at almost pure concentrations.
    2. It reduces the amount (in gallons) of petroleum fuel that will be needed (by 10%).
    3. It supports the farm community, which needs support!
    E10 will burn cleaner than fuel with other additives, resulting in longer engine life and less cleaning needed (decarboning engine fuel systems/intakes has become a big money maker for dealers and mechanics).
    E10 will reduce your mileage by about 3-4%. Not really significant compared to the benefits.
    E10 will negate the need in colder climates for "gasline antifreeze".
    It's not really a "ripoff", it's the lesser of several evils.
    cartoon1cartoon1 Member Posts: 2
    My spouse has been quite busy putting dents in my new Prius. After the first on, I found that I've never been able to achieve the same mpg. She just presented me with another one last night, on the roof. How much of an impact do small dents and changes to the skin shape have on the mpg I can expect? Anyone?
    south4south4 Member Posts: 32
    Don't have an answer, but I have found that Dent Wizard can pop almost any dent back out-good as new- for 30 to $50: larger jobs cost more .These services go by various names and are often advertised within the dealership service area.I have used them twice(after an estimate of $1500 by a body shop Dent Wizard fixed a door that wouldn't open after someone let go of a shopping cart and it hit my door fully loaded-cost for that was about $100 and no paint job was needed afterwards-a miracle result.). Good luck!
    It would take a VERY large dent to drop the mileage. Your mileage decrease is from other causes. For example:
    Winter will drop the mileage (lower temps force the engine to run longer to warm up and stay warm).
    Interior heater use will drop mileage as the engine will run to keep the heater core warm.
    A drop in tire pressures will drop your mileage. Tire pressure will drop with ambient temp drops (as in winter).
    Short trips will drop mileage a lot. The car will almost always be in "warmup" mode.
    Some places change the fuel in winter and that can drop the mileage a few MPG.
    Prius owners are very sensitive to mileage as they can see the results right away. It is, however, very difficult to attribute mileage drops to one thing specifically, and to track it accurately, as there are so many variables. Aerodynamic changes due to small dents will not result in mileage drops that you can measure. Now, if you added a huge wing to the rear, THAT would result in noticeable mileage drops! ;)
    Thanks for all that. It may be looking beat up, but I'll look elsewhere to increase the mileage. I do a lot of short hops. Might have a lot to do with it.
    railroadjamesrailroadjames Member Posts: 560
    Several months ago my wife & I took a trip from Valpo, Ind. to Des Moines, Iowa for a family reunion. On the way there we encounter severe head winds (approx 50-60 mph). Milage was, to be expected, very dissappointing...34-35 mpg's. Ah! But alas! On the way back, with a tail wind, I got a whirlwind surprise. Winds were 40-45 mph. at my back and... low and behold...54mpg's. This should come as no surprise really because there are so many varients when judging your milage. The many above prior testimonies atest to that. So...be patient and...reasonable when calculating MPG's. I have 73K miles on my '04 Prius and again have seen my milage vary from a low of 32 mpg's to a high of 53 mpg's (per tank). One last thing to remember. The Prius is so many things besides a great economy, green hybrid car. It has an amazing transmittion, brakes that seem to last forever and resale value that a Mercedes would envy. My '04 is valued @ $17-18 K average. I bought it for $22,365.00 out-the-door. Nice to know. Sounds like an investment to me.
    techman41973techman41973 Member Posts: 83
    I am on the road most of the time for business and I am considering a 2008 Toyota Pruis. Often my car becomes my office for up to a few hours a day. The engine must run to keep the car cool or warm, depending on the outdoor weather of the region I am in.
    My Accord burns about 4/10 of a gallon per hour. I would assume that the prius would burn far less since it would stop the engine periodically. Does anyone have any data on the idle fuel economy of the prius with the heater on on a cold day and/or with the air conditioning running on a hot day?
    johndjrjohndjr Member Posts: 80
    I have a new Prius, 3 weeks old. last fill up had 1644 miles on it.
    Is the on board computer at fault?
    First fill up was by the dealer, don't know how 'full' it was. My first to fill up was at 530 miles. I know it was full (up to visual on inside ring). MPG on computer was 49.5mpg.
    Next fill up was at 926 miles, took 9.3 gals to fill to ring, comp had 46.6 mpg, calculate to 42.6 mpg.
    Next fill up at 1327 miles, took 10.0 gals to fill to ring, computer had 45.3 mpg, calculate to 40.1 mpg.
    Last fill up at 1644 miles, took 7.6 gals to fill to the ring, comp had 49.4, calculates out to 41.7 mpg.
    Is the 'on board' computer normally this far off?
    Darned near 10 % average?
    Doesn't give me much in the way of confidence in the on board computer.
    I've read about the 'bladder' tank, but this much difference? I've had aircraft with bladder tanks and nothing like this.
    traffic_tomtraffic_tom Member Posts: 4
    I heard that there are upgrades available to the Prius from the manufacturer to boost the fuel economy. Now the numbers thrown around were up to 90MPG but that cant be right. Is there such a thing?
    traffic_tom
    carlt1carlt1 Member Posts: 6
    Great forum, so helpful
    On verge of buying a new car, but am troubled by the 20% hit on mpg on short trips in the Prius which is on my short list. As most of my driving comprises trips under 10 miles and I live in a cold climate, would I do better in a Focus (assuming mpg is only factor considered) ? Would I expect the Focus would pay less of a penalty in mpg, driving cold? This morning (temp 45) I test drove a Focus and got 35mpg on cold start over a 15 mile trip (Great grandmother driving style - airfoot).
    Thanks for any help,
    Carl
    tiff_ctiff_c Member Posts: 531
    No car does all that well in the cold with winter fuel and even worse on short trips. Your best bet is to drive right away and not warm the car up in the driveway. I fire up my Civic and I'm out the garage door in 20 seconds!
    It takes longer if where I am parked i have clear the windows of snow and ice.
    Ask yourself how much for the Prius versus the Ford or even a Honda fit or that sort of economical car $22-23K versus $15K That buys a lot of fuel.
    Also the battery in the prius doesn't like the cold weather. In fact no battery does that why so many cars need jump starts in the winter.
    There were several reasons I didn't buy a Prius, but I like the concept however I live in a hilly area and once the Prius traction control kicks in you aren't going anywhere in the snow. :sick:
    If you have no snow you will be ok, but mileage always suffers in the winter in the cold States.
    Lets not forget "other" facters while comparing any cars w/ the Prius. Resale is darn good w/ a Prius. Quality & Durability of a Prius is one of the best ( I can attest to that w/ 74K on an '04). I saw where roadability in snow was questioned...I live in N.W. Indiana with massive snows this yr. and simply put...NO PROBLEMS. Around Town driving I average 44-45 mpgs during winters and 48-51 in summers. One last note.....Take a test drive and check out the roominess and fit & finish of the Prius...You won't be dissappointed and I love the hatchback for obvious reasons.
