dodge trannies
i am thinking about buying a 98 dulley with a
diesel but hear lots of bad news about the
transmission being very weak and therefore at about
100 to 125000 miles get ready for severe trannie
problems so if any body can shed some light please
respond
respond
A friend of mine had a Dodge 360 3/4 ton extended cab long bed. Went through brake pads about every 10k miles. Dodge replaced all but a few sets under warranty till he finally traded for a Powerstroke Ford, but it was still a hassle for him.
current truck is about 2,000 lbs heaveier. Front brakes are getting close with 55,000 miles on them. Not as long lasting as my half ton, but all GMs get long life.
how does this explain Dodges super short break life, obviously they aren't the same. Delco special design just for Dodge?
Delco must have a special variation of the GM brakes that they are making for Dodge.
My mom had a suburban, same year as my truck. she only got half the miles out of her brakes..i like to think I am easy on them the way I drive... I know she wasn't.
My wife has had to have the brakes on her '91 Honda Accord done at 33,000.
Rich
Here's the general consensus with a large group of Ram owners to which I belong:
The current auto transmissions behind the gas engines work great and last a long time if serviced regularly and not abused. A small group has experienced problems with the Auto (47RE) behind the diesel, and the speculation is that the Cummins puts out too much torque at low RPMs before the tranny builds up adequate pressure. So it's best to let the pressure build up with a diesel prior to punching it. Better yet, get one of the manual transmissions. The proven NV4500 is absolutely the best manual transmission in any truck in this country. Look in 4WD magazines and you see countless adds for them to improve on older 4X4s. The new Allison 6-speed is supposed to be even better, but it hasn't been around as long.
As for the brakes: in the 95 to 99's--they suck! Dodge finally got around to doing something about the complains with the new 00 or 01 models. I think the 2500 and 3500s are the ones that now have the new dual-piston brakes in front. Wish I had these on mine! Dodge has also had plenty of problems with increased pad wear in the front. They tried to correct this by adjusting the bed-load sensor in the rear, as well as trying different pads. All these are iffy in effectiveness. The biggest factor in improving pad life is how you drive the truck--as a girl, grandmother, repressed red-haired adopted iguana, or however you want to describe it. Bottom line--Dodge brakes have not been very good, but they should be better now.
this topic is being "frozen". It will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
