Silverado 1500 3:73 - vs- 4:10 gear ratio
I am looking at two Chevy Silverado 1500 3dr ext.
cabs. Both have the 5.3,4spd auto trans,autotrac
4wd, P265/75R16 tires. The only difference is the
rear gear ratios 3:73 vs 4.10. Does any one have
any back on the gas mileage for the above
configurations. GM states their is only a 1 mpg
difference. Most of my driving is in the city but
when I get on the open road I like to move along at
75+
Ray
See Also
2015 Chevrolet Silverado 1500 - MPG
75+
Ray
See Also
Peter
Dean
- Tim
sorry
- Tim
The 5.3 with 3.73 in the rear should run at around 1650 rpms at 60 mph. The 4.10 around 1800 rpms at the same speed.
Just my two cents worth!
rcoos
Rcoos - the 2500's and 1500's w/manual trans have a different OD than the 1500 w/auto. Both my trucks run 3.73 and 1800 rpm at 60mph. And I'd guess you have the 265 tires which also slows down the engine a bit.
Mike L
When I bought my truck the 4.1 was a no cost option - I saw somewhere that GM was going to start charging a few hundred $$ for the lower rear end, but can't say for sure.
If you're into stop light racing and/or heavy towing the 4.11 would be best. With my 3.73 if I have to tow I can always lock it out of overdrive or in extremes pull it down a gear.
Rich
the dealer has added a bedliner,mud flaps, and bug deflector. I can get the GMC for $600 cheaper than the Chevy with the 5.3 - 3:73 set up. The question is. Although I truly want the 5.3 -3:73 set up, is the difference in MPG worth $600.
Ray
The difference is very minor ~ 200rpm at 65mph. No real difference in fuel economy, but 10% more pulling power with the 4.10.
If it is the truck you want otherwise, don't let the 4.10's bother you. Obviously it is a 4wd, you'll like the lower ratio when in 4wd lo range creeping down some hill.
Mike L
I have to agree with vince4. You want the 3.73. You'll be happy with the 3.73. If you get the 4.10 you'll be riding around for 3-5 years saying to yourself, "I should have gotten that 3.73!"
Be sure to tell the Chevy dealer that you can get the GMC for $500 less AND that the GMC dealer has tossed in a bed liner to make the deal. So, Chevy dealer what are you going to do?
Rich
with O.D.....it's silly not to...
My 3 cents
- Tim
Anytime you buy a GM truck, better get the lowest gearing possible to compensate for the GM engine's lack of power. GM highly over-rates their powertrain specs for marketing.
ahhhhh...the baby who is afraid to come to the site where we can have real talks...
- Tim
Ping...ping....ping ping ping! LOL!
- Tim
its the only person he's smart enough to argue with...so just let him.
Kinda like one of those little kiddy toys, we get to shake him up every once in a while and see what happens:
Crap falls to the bottom everytime...
LOL
- Tim
So where's your brother dodgeram7? Out playing with the other crazies in your ward? Hehehe....
Justice has a swift hand when dealing with the likes of you. I'll bet your time here is actually shorter than you think....LMFAO!!
Good luck on this one now!!
obyone
this topic is being "frozen." It will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
