Mazda MX-5 Miata Gas Mileage Reports
This discussion is for owners to post their actual Miata MPG.
"Real World" Fuel Economy vs. EPA Estimates
Just a sidenote, but I'll be installing a new ecu to boost the turbo a bit and also adding an exhaust so we'll see what that does to for economy.
Can the Miata use Regular gasoline (87 octaine)?
Summer: 27 MPG city, 34-36 MPG highway
Winter: 22 MPG city, 27-29 MPG highway
Mods and effects:
Lowered suspension: this should improve gas mileage just a little bit
Cone-type intake: less restriction, should help a little
Custom (cannot be bought!) cat back: less restriction, should help a bit
Racing radiator and motor oil cooler: helps in the summer by extracting heat more efficiently, hurts in the winter (for short trips) because it takes longer to warm up
It makes a great 2nd car, IMO. Can you get a winter beater, such as an old Subaru or something? Those would complement each other nicely.
You can get snow tires, but I still don't want other overconfident drivers in heavier SUVs bumping in to my tiny little Miata.
Will have to wait until next winter to see how my 08 does, but would be greatly surprised if it was any better.
as to mileage - my 2000 with 45k on it could get from 23 to 33 mpg, depending on how hard I pushed it. Any reports in on the new model?
first tank was 26.5mpg, second was 30!
however, got suspicious - checked tire pressure (obviously no one at the dealership did) - they were running at 45 psi!!!
dropped em down to 36 (still likely too much) - will see what that does. hitting the road tonite, so will have another 500 freeway miles on it by this time tomorrow.
On my 93 it's only 26psi IIRC. I run 28. Any more and the ride gets harsh.
I'm sure it's different for yours, but it would be on the door jamb.
as for mileage - next tankfull at lowered tire pressure was 32mpg. Virtually all freeway, but hovering from 65 to 80mph. About 100 miles top down, the other 175 top up. Can't complain about that.
Tho high speed does seem to matter. Just might have driven the last 50 miles home between 90 and 110; already down a quarter on the gas gage. Ouch.
I have not refueled yet but will post the mileage when I do on my 2008 GT manual transmission.
The one stint of highway driving I did this summer got me in the upper 20s. Bah, what's the fun in that?
This is mostly commuting from suburb to city and back.
1992 5 speed-no mods.
Less than 29, I'd suspect a problem...
I had a 93 and in my mostly city commute got mid-high 20s, which is still good.
My new 08 is getting 27-28mpg, maybe even a touch better than my 93. Not bad.
Next 5905 miles on a long vacation, overall gas mileage was 35.6 mpg, with highs of over 41 on two consecutive tankfuls in the mountains of Colorado, and lows of 32.5 over two consecutive tanks at 70/75 mph heading home through the desert.
(All mileages carefully measured/calculated by a certified math nerd.)
I think it would take evil intent and/or devious planning to get less than 30 mph with this car.
A lot depends on where you drive, DC traffic stinks.
