Lexus ES 350
As for rear reading lights, they are already in the 2007 model. It took me 10 months to find them, but the tiny LED lamps above the front console (the ones with a "doors" button on one side and an "on" button on the other) are aimed at the rear passengers and make it quite bright back there. The only disadvantage is that the rear passengers have to ask the front passengers to turn them off and on.
Also, the rear door metal trim piece had same issues on new cars(all colors). The trim on the bottom side of the window does not align with the trim piece of the front door as the clip to hold the trim piece is placed at 5" from the end which will make the trim piece to pop 1/4"(max). Had them re-placed twice and also Lexus tech looked at it and gave the same report as mentioned above.
As far as rattle is concerned, I have driven 4 news cars with service consultants at two dealers and all had some kind of rattle either in front or back, with AC and sound system turned off. The rattle and engine noise when starting in winter is not new for this forum. You can check for both these issues yourself if you don't find one than I'm unlucky to have these issues.
http://www.autoblog.com/2007/08/02/lexus-facing-lawsuit-over-es350-airbags/
Good luck...
http://www.lexus.com/models/ES/
MODERATOR /ADMINISTRATOR
Need help navigating? [email protected] - or send a private message by clicking on my name.
Share your vehicle reviews
of trying to get Lexus or the dealer to buy back the car, they want to put a 3rd transmission in the car! I filed a claim with Lexus and am trying to get my money back. :sick:
I'd dump this clunker at any cost.
blind spot detection systems
for the es350?
Atomic Dog
http://wbztv.com/topstories/topstories_story_269131643.html
For my last 10k service, the invoice says they did all those checks, but for $132, they didn't top off windshield fluid, didn't adjust tire pressure to specs, and didn't install engine cover bolts back properly. Obviously I don't plan to use this dealer again. For cross- reference, my Acura dealer charges $32 for an oil change on my MDX, that also includes a car wash, top-off all fluids, inflate tire pressure and check CV boots and battery. Lexus dealers are quite bit more expensive than Acura's.
This is just my humble opinion. If your car drives normally, there is need for these checks every 5k/6m. So I would just do oil change and tire rotation at Toyota dealer. Or you could go to Lexus dealer but request only this simple service. 15k is a close call. Go to a Lexus dealer if it makes you feel better that the technician performs these checks (assume he actually does do them). I would go to a Lexus dealer for 30k service (if not for anything else, to maintain a relationship with a dealer).
BTW, Toyota dealers can also do 15l/30k services. The only things they can not do are warranty work.
Also I do not have a Lexus dealership in my town. Can I get my 5k, 10k check ups at the local Toyota dealership?
One last thing - sometimes when I shift into reverse it seems very hard (can't think of a better word) and it is loud - like a clunk. I thought it may be the doors locking that made it seem loud. Anyone else have this problem? Does it sound like the transmission?
Disspite the problems, with fingers crossed, my wife and I will still consider this model and hope that all concerns have been worked out in the spring of next year.
Check out this link for good information on changing oil on an ES350. I have done one oil change on my 350 without problems and without raising the front end. It would be easier to raise the front, but it is not necessary. This link also shows a homemade ramp, that I will probably make before my next oil change. BTW, I did have a little problem sticking the plastic hose adapter into the filter - you've got to push hard and that is difficult with the hose attached.
http://members.cox.net/n0v8or/avalon_oil_change.pdf
Thanks for the info and the link.
Art
