Dodge Ram Quad Cab
ford also starting specifying mercon V for some of its truck trannies to eliminate torque converter shudder...odd that the ford dealership would put chrysler spec tranny fluid in a ford!!
I didn't know about MERCON 5. I'll have to tell my daughter. Her Explorer has had a continual problem with shudder.
Dusty
My question should this be done in any case towing or not? If so then when your buy the towing package why don't they put this lub in at the factory?
Replacing 75W-90 with 75W-140 will probably provide an additional margin under conditions close to the extreme limit of the axle.
I assume this is the Chrysler 9 1/4 inch differential. Is yours a limited slip version?
Dusty
any ideas or suggestions would be appreciated
I'd ask your service manager for his opinion and see what he says.
Best regards,
Dusty
I have already changed the exhaust to a Ravin muffler with dual 18" chrome tips out the back.
When you installed your dual exhaust system, did you see any definite results?
Thanks in advance,
Dusty
Also, anyone have any suggestions about protecting the paint on Dodge pickups? The maroon paint on my 2001 Ram scratches easily. With only 23,000 on the odometer, my otherwise excellent Ram is already beginning to look a bit shabby due to the cheap paint.
First, was the Fram filter used on all these Cummins engines the correct one for that application?
Fram guarantees that their filters meet the requirements of OEM certification through SAE HS-806. That means that the Fram type designed for that application meets all of the manufacturers' design parameters.
Second. Is this comment from your service manager supported by documented proof? His say so? Or his he passing on third party stories? If this were true you can bet that Cummins would be denying claims for repairs, and/or that someone would be bringing suit against Fram in a hurry.
Third. All these Cummins engine failures? Failed oil filters or not, based on what I know this particular engine is considered bulletproof. I've only ever HEARD of one major Cummins engine problem, and even that was attributed to owner abuse.
Dusty
I put a drop-in K&N filter in my 99 GMC with the 5.3L and I could tell a moderate performance improvement. More than anything with the GMC, I could tell that it did not shift down as easily when going up hills. This is what I want on my Ram......here in southern Ohio it it quite hilly and all those unrequired shift downs definately relate to worse fuel mileage. I am for sure going to drop in a K&N Filter.....I just wondered if the airaid system helps a little more.
It's good to hear that you at least saw a performance improvement. My son installed a K&N filter on his '91 Dakota many years ago and he felt that it made a difference, too. He said he saw an increase in gas mileage, but I'm not sure if he was fastidious enough to take accurate readings.
Dusty
http://cpgparts.alliedsignal.com/cpg/catalog/fram/legal/CumminsBulletin.pdf
Hope this helps
98 Z71 5.7l and can't say that after swiching them back and forth that I noticed any difference.
However I do have some concerns about small particles being able to pass through the K&N filter.
Now one can increase flow and one can increase particle trapping on an existing system. The trick is to be able to do both within the mechanical confines of the OEM's design. I suppose that the technology in media has advanced like a lot of other things, but it begs the question why don't OEMs use something that's presumed to be more effective?
I suspect that with any system like the K&N there is some trade off. I believe that the K&N design requires an oil saturated media. Low restriction medias are more porous and less effective at trapping smaller particles. So an oil is used to increase the collection ability of the media as air currents bring small particles through unaligned media layers. This type of system can be effective, but can also suffer from loss of effectiveness under certain conditions. One would be at very cold temperatures where the oil looses some of its tackiness an cannot attract as much particles. Heat can also have a tendency to allow the lubricant to flow out of the media (desaturation) thus reducing the effectivity over time.
I wonder if the aftermarket manufacturers give any specification with respect to filtration effectiveness and micron size?
Thanks for your post, Ramforce.
Best regards,
Dusty
Your point about oil is the most crucial thing. Where K&Ns really shine is when they get really dirty, they still allow good airflow. If the filter is not oiled properly, dirt is going to be sucked right into the motor. I run a K&N on my Silverado right now and really haven't noticed any appreciable difference. I probably wouldn't recommend getting one unless doing other changes, such as adding a higher flow exhaust that could take advantage of any additional air flow. I don't plan on putting one on my Hemi when it finally gets here.
Like the item that was transmitted the other day from the original author, this one contains a link to the "Allied-Signal Engineer" that is inoperative. If anyone has this memo I would appreciate either getting a copy or a link to the originating source.
Dusty
i think all filters have anti-drainback valves which serve to help keep oil "up" in the engine for fast return on cold starts...some seem to work better than others.
(The term "research" is technically more accurate in this case, anyways.)
But I do agree with you that whatever it is it is not very scientific. The author promotes opinion that is not supported by the evidence in his own investigation. In addition, he and others who site his work promote through implication that there exists a design or component composition problem that is so generic, basic, and pervasive that associated problems must always symptomatic. That is not fact.
For 140,000 of 160,000 miles I used Fram oil filters exclusively in a 1989 Plymouth Acclaim and this vehicle never suffered from cold-start valve clatter. That's forty oil filters and not one problem! The only two vehicles that I've ever owned that did have this problem has been with other brands of oil filters. My son's '91 Dodge Dakota with a 3.9 engine has had this problem for about the last 170,000 miles out of 230,000. I asked him the other day if he uses Fram oil filters and he said "yes." But he also said that the cold-start valve clatter has been present in this vehicle regardless what brand of filter he has used.
There are a number of methodological issues with this work. The "eyes and common sense" litmus test is in fact totally unreliable, especially if used in a cursory way.
Since heterodoxy and research analysis is a specialty of mine, I couldn't resist changing out my Mopar factory oil filter today for a Fram PH16. We'll see. I might, despite having two Purolators on the shelf for our Chevrolet 305, just install a Fram in that to see what happens. This vehicle does in fact have a cold-start valve clatter problem (currently has a Purolator). And I've been using Fram oil filters in my wife's Avalon since I've been changing the oil myself. No problem there, either.
Dusty
Dusty
Based on observation of a towing package-equiped RAM I saw some time back, and the package definitions from the Dodge site, I believe that the heavy duty cooling is a three-row radiator instead of two (meaning three rows of cooling tubes).
It appears that on the RAM the transmission oil cooler is located between the air conditioning condenser and the radiator.
Maybe someone with the towing package can verify that.
Dusty
The base Ram has Four radiators:(looking from the front)
Right side (electric fan) AC
Left rear Water(coolant)
Next 4.7L(1/2 sized)Transmission oil
OR 5.9L (full sized) Transmission oil
Front small power steering cooler.
However The heavy duty cooling may say a bigger(water) radiator(pre 02) but I still have not seen any evidence of that!!!
thanks,
bweave
The plugged piston cooling nozzles issue is so serious that issue 36 of the “Turbo Diesel Register” (Alpharetta, GA) suggests insisting on buying oil filters only in unbroken plastic wrap. The Register mentions that one Cummins engine failure was caused by dirt and insect larvae plugging the nozzles. The same material was discovered in the filter can - apparently the location of an insect’s nest.
an excellent vehicle. The Ram has certainly changed my opinion about Chrysler products! It's comfortable, quiet (except the for sound of the engine which I expected when I bought the truck), and unlike earlier Dodge trucks, completely squeak and rattle free. Having owned a Chevy before I bought the Dodge, I think you'll be MUCH happier with the Ram. I've yet to see parts fall from under the dash as I did with the Chevy. Also, the fit and finish of the Ram is light years ahead of Chevy. If you don't object to the sound of the Cummins engine and the 3 gallon oil changes, I'd recommend the diesel option. Mileage with the diesel is nothing short of phenomenal. My truck consistently gets over 20 MPG and frequently delivers 22 MPG. Of course, that's reasonable driving. If you frequently take advantage of the engine's incredible torque, mileage will drop substantially. All considered, the Ram 2500 is one of the most enjoyable vehicles I have owned. I recommend it highly.
One of my pet peeves with the Chevy/GMC's is that the upper fender seems really flimsy where it meets with the lower winshield. You can grab that area of the fender and move it 1/2" easily. I know it doesn't make any real difference, but you shouldn't be able to move the sheet metal on a new truck that easily.
For those of you who have the 20" wheels, was the upgrade worth it (in your opinion)?
thanks,
bweave
I purchased the keyless entry separately and installed myself. It comes with detailed instructions and it was a fairly easy task. But you still have to have it programmed by your dealer or with someone who has a DRBIII. I believe the dealer charged $35 for the programming.
Steve
At post 619 Peppe remarks he got the same type of notice:
>>Just got a notice that says Caution your 2002 Ram Truck was filled at the factory with GL-5 SAE 75W-90 rear gear lubricant. This notice states that before towing a great distance replace the factory rear axle lubricant with SAE 75W-140 synthetic gear lubricant to reduce the potential for the rear axle over heating. My question should this be done in any case towing or not? If so then when your buy the towing package why don't they put this lub in at the factory?<<
#620 of 659 Differential lubricant................ by dustyk Nov 17, 2002 (10:14 am)
My first guess is that the 75W-90 was installed to reduce driveline friction and correspondingly reduce fuel consumption. For most applications, 75W-90 would be more than adequate, including long distance operation with some load. Replacing 75W-90 with 75W-140 will probably provide an additional margin under conditions close to the extreme limit of the axle.
[deletia]
Dusty
When my trip computer in my overhead consule says the fuel tank is almost empty ("10 miles to empty"), and the gas gauge is down in the orange zone, the low fuel light is on, I pull in to the nearest station and fill her up. But I can only get 20-21 gallons in the tank. Isn't this a 26 gallon tank, which would mean at approx 10-11 MPG I get in the city, I should have another 50 miles left. With the consule reading "10 miles to empty" I would expect to pump in around 25 gallons. I have to be missing something, but if there are 50 miles left until empty, why wouldn't the computer or gas gauge show there to be?
Also, does anyone know the gas mileage specs. on the Hemi 5.7L? I'm considering buying shares in Exxon with the 5.9L Magnum. Any ideas how I can get better than 9-11 MPG in the city, stop and go?
So, it seems that whatever increment the fuel gauge, there is always more fuel than you think. This might be intentional on the part of the designers.
Dusty
I wanted to know for sure - so I put my lawn mower gas can in the bed (just in case) and drove 70 more miles with the low fuel light on. When I pulled in to get gas it would still only take 25 gallons. I guess it is better to have a few extra gallons in the tank - you never know when you are going to get stuck in traffic.
