Acura RSX Accessories and Modifications
Discuss RSX accessories and mods here!
#1 of 2 GrillCraft grille for Acura RSX rusting after 1 yr. by dengan Aug 12, 2005 (7:27 pm)
Bookmark | E-mail Msg
Hi
Just a warning to RSX owners or this possibly applies to anyone buying a GrillCraft grille:
My grille started rusting after one year. I bought it from www.driverFX.com but I don't blame them, I blame the manufacturer.
This is a Canadian car but the first year I had it on was not particularly snowy and therefore did not get salt on the grille as far as I know (Even if it did get salt on it, it shouldn't have rusted like that).
I installed it myself but I don't really want to take it off and send it back to them for warranty (it's probably too late now anyway).
I plan to just spray rust paint on it and hope for the best.
Anyway, here's your warning.
ps It is a nice grille but who wants rust in the first year.
Just wondering if anyone has had experience with aftermarket armrests for the RSX. I saw two on Ebay -- one with a storage compartment that mounts to the center console, and another that bolts to the driver's seat. Here are the auctions for these if anyone's interested:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=7993225541
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=8006409572
I like the storage aspect of the first one, but the second one looks wider and might be sturdier if it's bolted to the seat.
Can anyone relate their experiences installing one of these or something similar?
I was looking at using a TSX knob for my RSX. There is a boot adapter ring that's included if you buy one of Acura's RSX-specific knobs (the aluminum one in particular). The parts guy on Ebay that I corresponded with said the adapter rings are no longer sold separately, but I did manage to find one for sale on the web. Use froogle.com to search for "rsx boot adapter" and you'll see it.
Good luck,
Rich
Joel
Have you or anyone used the cold air intake modification? How hard is it to install? Does it void the manufacturer warranty? Does it really improve HP, torque, and MPG, + give it a nice growl???? I've always been told, if it sounds too good to be true, it is! There is one on e-bay for only $20, w/air filter.
Hmm, cold air intake modification?
Installation: Well, that's easy to install. Whatever aftermarket brand you plan to get comes with an installation guide and all the parts you need already come with it. You might need to drill one hole on the aftermarket intake for the sensor.
Warranty: It can void the warranty of your RSX if the dealership can pinpoint that your modification was the cause and source of the problem. But since an air intake is unlikely to cause any mechanical problems since there's nothing mechanical about it, you shouldn't have to worry about anything. Unless you installed it improperly, then that's a big issue. Remember to keep your stock air intake just in case you decide to put it back.
HP, torque, and MPG: Slight horse power increase, something like 5hp+ but I don't know about torque. MPG, this is the major drawback. I have a 97 Civic with an Iceman cold air intake installed and my MPG went down a little bit. I am considering putting back the stock air filter but I guess it was already thrown away years ago--my bad. My friend's 2002 Accord's MPG went down a bit as well after he replaced his air intake. Everyone I know who had their air intakes replaced got lower MPGs as a trade off. My advice, get it if you don't consider your MPG going down a little bit and get a little bit more power. Your car's MPG is at it's best the with stock parts.
Maybe I'll experiment with the intake - it's on e-bay for only $20. As long as I could swap it out without too much hassle or wear and tear, it might be worth sampling...
Installation was very simple -- pull down the boot skirt to detach it from the old knob, unscrew the old knob, slip on the MOMO threaded collar and a rubber sleeve, push the new knob onto the shaft, tighten up three set-screws on the new knob, and screw on the threaded collar from below. In all it took about five minutes.
The one drawback is that there's no attachment between the MOMO knob and the boot skirt, so there's a small gap between the boot collar and the new knob. It doesn't look bad because the gap is very small, but with the boot collar being loose, it rattles during shifts. I'm either going to pick up one of the aftermarket boot adapters, or maybe just slip on a couple of rubber O-rings to stop the rattling.
Flip - http://www.jjproducts.net/jj_products_htm/products/Acura/AcuraRSX/index.html (Also on eBay)
Console - http://www.rsxarmrest.com/
I choose the flip so I can get it out of the way when I'm solo and can put it down for the comfort of my passenger.
Now I've got to deal with a slow leak in the left front tire. Damn, there goes at least $100. Why are good tires so damned expensive. I just replaced on on another car like two months ago.
A good first choice is to leave it parked when practical, but if you MUST get out there and/or you're deep in the snowbelt, go for a complete set (yup, 4!) of snow tires. If you have the funds AND THE SPACE to store a separate set of wheels, get rims. Studs are good for ice, but they'll give you a loud ride. Michelin, Yokohama, and Bridgestone come to mind for tires built with an ice-handling compound. See what they're saying at Tire Rack.
Also, any thoughts on how hard this thing is going to be to install?
Thanks in advance for any advice.
L.R.
Is it a short ram or a cold air intake?
One is a short tube and the other is longer and snakes down through the engine compartment towards the front left foglight area.
The short ram is easy to install but doesn't provide very much performance gains.
The cold air intake provides more gains but is haredr to install.
Besides that though, you shouldn't have any trouble fitting an intake onto a 2006 model. Nothing has changed in the engine compartment. For more investigation you might want to check out some other websites geared specifically towards the RSX.
I'm figuring on about five extra horses. But there's no way an intake is going to affect torque. As for mileage I don't have a clue.
One of the main reasons I want to go CAI is to get a little more "rumble" out of the engine. Eventually I can go to a catback or just a different muffler, but I can't see replacing the exhaust components until they're ready to be replaced, which is going to be at least 4 or 5 years.
Also, anybody know if a CAI will affect emissions testing? We get tested every other year in Illinois, and I'm not sure I want to be taking the thing on and off. If that's the case, maybe just get a different air filter.
Aalso, has someone installed interior panel kit from Acura? I got the info that it is to enhance the interior of the car, but the dealer could not provide any details. Seems like, not many people go for it...
BTW, I have 2006 RSX silver color.
I'm trying to get OEM heated seats now, as the leather is cold mornings.
The internal is a waste of money.Watch out for your drivers seat as it will crack, being kidney shaped.
They say when you buy the entry model that's what you get.
My friends Subaru leather is alot softer and more comfortable.
The internal is a waste of money.Watch out for you drivers seat as it will crack being kidney shaped.
My friends Subaru leather is alot softer andmore comfortable.
Also, I don't want the car to look like a "tuner" car as I am going to clients offices with it and am working in a very high level sales position, so I don't want to give off the wrong impression. I only want to know that I have upgraded the car when I step on the accelerator.....will not do an exhaust unless it is only seriously more audible over 5000 rpms..what do youthinkk?
mike
I took my car to U-Haul on March 31st to get a hitch installed so I could tow the smallest trailer possible for moving purposes.
Acura said they don't do hitches in RSX's, but U-Haul bought the parts for me and installed them. It was yesterday when I dropped by to pick up the trailer so I could start my moving process. Well, I drove the trailer EMPTY over to my house and just parked it there. Today at work I realized the hitch was out of place so I went and checked under my car and noticed my car was damaged.
I didn't do anything unusual and it only took me 15 minutes to go from U-Haul to my house.
I was wondering if the type of hitch installed could've been the wrong one. Would anyone know? I went to my mechanic and he said it was not the right one, considering the arms of the hitch were attached to the thin layer just under the spare tire.
Here is all the relevant info I got from the receipt and by looking at the hitch itself.
Receipt:
1. Kit Drawbar Long 2.215" Drop
2. Ball 2x3/4x1-15/16" 5000 LB
3. Hitch1 Acura RSX
4. Class 1 (Up to 2000 LB (GTW) and 200 LB (TW))
Hitch:
Part#: 24719 2000 LB
Not sure if this is just a SKU number or what.
Please any help I can get will be highly appreciated!
Thanks to all in advance!
Marco
