GMC Tow/Haul mode
I recently purchased a new Sierra 1500 Z71 with
the trailering package. It has the Tow/Haul mode
switch on the end of the shift lever. I will be
towing a 20' Bayliner.
I currently pull my boat with a Jimmy and do not
use overdrive. If I use the Tow/Haul mode when
towing with the Sierra, can I use overdrive or
should I continue to use drive?
Put the truck in 3rd, and press the Tow/Haul button. What the Tow/Haul mode does is sharpen the shifts, and extends the shift pattern. So when you are accelerating from a stop, it will hold each gear a little longer. When it does shift, the shift will not be as 'smooth' as normal driving mode. This gives you max engine power and best transmission performance.
Besides, if you tried O/D and Tow/Haul, the computer would actually keep it in 3rd gear unless you were going down hill.
GM recommends not towing in OD?? That's a good one.
TOW/Haul Mode only delays the shifts and firms them up. GM trucks still hunt in an out of OD with it selected. Not of much use if you have a strong transmission. Guess that says something about GM transmissions.
I have Towed heavy and light...all in OD...with tow haul selected...if you are on flat/normal land...it will go into OD...it does not lock ut 4th...if you feel any hunting of gears...(should only be on hills)...put it in 3rd.
The new tow switch is a very nice option as it re-programs instead of delays..
Take it from me....I own one unlike F150....(he is always in envy of us)
...(and in severe denial)
- Tim
- Tim
GM says in the owner's manual you can tow in OD. The difference between the GM and Ford transmission is that GM was smart enough to program their PCM such that it will downshift to 3rd sooner than Ford to prevent overheating/damage to the tranny, whereas Ford will just let you pull in OD even if you are in marginal lugging conditions.
I'll put my GM 4L80 tranny up against the Ford E4OD or any other Ford unit any time. Despite what he says, if f150 is towing more than his truck's rated capacity, and goes down to 3rd gear only when going up long, steep hills, he'll be in the tranny repair shop.
- Tim
- Tim
The GM 4L80 had 2 weaknesses, one of which was related to an engine problem, not the tranny itself. The Ford E4OD tranny had about 10 listed weaknesses. And the Ford tranny is better? yeah, right!
- Tim
Apparently they improved the oil flow in the Silverados...which was the whole reason behind needing to pull in 3rd to begin with.
More proof to just make F150idiot spew insults and trash....
Rich
ehehehehee
- Tim
Nothing new. Same old stuff that falls apart as the "old" old stuff. Couldn't come up with any innovative designs fast enough to outdo Ford so the new shakerado was put together last minute, using any old design they have had for 30 years. Even the body looks about the same.
GM Engineers are either not very creative or just plain lazy.
this topic is being "frozen." It will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
