4.8L or 5.3L in Silverado Ext Cab 2WD SB
I am thinking of ordering a 2WD Silverado Ext
Cab Short Bed with locking rear differential.
Today I test drove two ext. cab 4WD, one with a
4.8L and the other with a 5.3L engine. If I were
going to buy a 4WD I would get a 5.3L. But I am
not buying a 4WD. I could not test drive a 2WD
since the dealer did not have any, but the dealer
told me that I would notice quite a difference
between the 4.8L 4WD and the 4.8L 2WD with the one
in the 2WD having quite a bit more acceleration due
to its less weight and one less drive train to
turn. The dealer thought that a 5.3L in a 2WD
would be overkill and that the 4.8L would do fine.
What does anyone think?
Chet Kulus
Chet Kulus
I'd go 5.3
- Tim
Hans
Its roughly 30 cubic inches, the difference between the 4.8 and 5.3. Almost makes you wonder why GM went bothered making both when the 4.8 doesnt offer a signifigant improvement in mileage.
And the new 4.2 straight 6, which I'm sure will replace the 4.3 makes almost as much power as the 4.8.
Chet
Looking at postings under Silverado gas mileage topic it seems with the 4wd 5.3 people are only getting about 15 mpg. The larger difference is the initial cost however many people note the resale value will also increase.
Dave
I averaged 15.4 mpg for all of those miles with the camper. The power and mileage greatly improved after the first 5000 miles.
If I had it to do over, I would still order the 4.8L and 4wd and never regret it.
Mike L
get a 5.3
- Tim
On a pure highway trip at 75 mph I peaked out at 19.6 mpg. I doubt you would get more than 1 mpg more with the 4.8l. Couple that with the fact that most of the x-cabs are built with the 5.3, and you'll have a bigger selection at the dealer.
Go with the 5.3.
Peter
Don't get me wrong, I really like the 2500. I just don't think I needed the 6.0L in it. Actually, a 4.8L and some 4.56's would work just as well in the 2500 for me.
Mike L
I believe a lot of room to breathe is the way to go...
- Tim
Thats if you actually pull or haul anything occasionally. But I'd still recommend the 5.3 because then the power is there if you ever need it. I also noticed that there was no or little difference between the gas mileage of the two. But I'm sure the 4.8 will average a mile or two better.
So, IMO the 5.3 is well worth the extra $700.
Ryan
mike
better than the 5300. However, if there is any need for quick acceleration the 5300 will walk away-with a trailer, hands down the 5300. One thing i dislike about both is the torque curve is too high-need to wind out to get the power.
I choose a 2001 GMC Sierra 2wd, short bed, extended cab, locking diff, 4.8 V-8.
I knew that I would NEVER be towing anything. I wanted better gas mileage. When my Brother-in-law bought his 2000 Chevy Silverado, all that he could find was the small V-8. When I went shopping for my 2001, I had a hard time finding a small V-8. I drove both the 4.8 and 5.3 V-8 with 3.42 rear ends, and could not tell any difference. (I have noticed that at 75 MPH, I do not have neck wrenching acceleration if I need to pass someone.
Traditionally, a smaller engine gets better gas mileage than a larger engine, so I choose the small V-8. I actually had to find one, and the dealer had to travel 300 miles to get my truck.
I can burn rubber at a stop light, (not that I do that often, but it happened a couple of times), and I can still tow about 6000-7000 lbs if I wanted to.
I think I get good gas mileage (Last tank was 17.5 mph, and I have less than 3000 miles on the truck).
It seems that two trends I have noticed in this forum are that the large V-8 gets about the same mileage as the small one, and that the engine gets better after 5000 miles or so (from what I have read).
Now here is something else to consider. The SMALL V-8 (according to the published spec's) has MORE horsepower than the LARGE V-8 from FORD, the LARGE V-8 from DODGE, and the ONLY V-8 from Toyota. I do not know about the Torque.
I think the jury is still out on the "better gas mileage" with the small V-8 though. It certantly does not hurt though.
Now, the 5.3 will probably have a better resale value.
A unique comment listed above about the 4.8 potential to have a LONGER engine life due to the shorter crankshaft stroke. I hope so!
Of course, the 5.3 is also more expensive! Drive them both and see what you think. I drove them both and could not tell any difference.
Check out a 3.73 vs a 3.42 rear end, and you should feel more power with the 3.73. However, "They" say (whoever they are) that the 3.73 is not a fuel efficient and is a little louder at highway speeds.
If you ever had the need to tow more that 6800 lbs (I think that is what the limit is), you could always put in a different rear end (3.73 or even a 4.10), put on a flowmaster or whatever muffler (supposed to give you a couple of more horsepower, and a little better mpg), put in a K&N air filter (a couple of more horsepower), use a full synthetic oil (again an additional horsepower or two).
It seems that they are really close, in terms of MPG. Horsepower is 270 vs 325.
You commented on the expense. Whats $800 when your spending 30K. Thats how i looked at it.
Ryan
Might be the difference between eatin' catfood and filet mignon when you are retired....
Gotta do it while i am young cause in a few yrs i wont be able to (yes i will who am i kidding)
i would spend the $800 on accessories anyways. Seriously though whats $800 (not an investment cause i wouldnt save it) when you spend 30K.
Ryan
Ryan
Hans
In regards to the enginer reliability, the question is type of material for the crank shaft. Forged or cast steel cranks. since GM has the same engine block, changes are they are using the same crank and rods material. So, they will last as well as the owen takes care of them. I would me more concerned with the drive train. Rear Axels, Differential and trans. Go for the OD automatic unit. The first gears are truly low. This allow anyone to pull trailers. The auto will handle more than the manual because of torq converter slippage. Also the auto will hame more torque multiplication. Any way. sorry for the lecture. just an old drag racer talking.
Make sure you get the OD transmission. This will give you better gas milage. I personally like the 4.8. If I want power I would put on a Paxton blower and get some true power....400 hp at 4500 rpm. It bolts on and is Calif Legal.
Agree that at relatively low engine rpm's, the pipey motors don't perform that well. I think you and I agree that a relatively high HP (high torque) at low rpm motor is best for low rpm towing.
But it is HP that does work per unit time. Compare HP at 2400 rpm's to give indication of performance.
PS. My 4.8 at 4400 rpm tows up hills dang good!
Pocahontas
Pickups Message Board
