Chevrolet TrailBlazer Maintenance and Repair
Talk about Trailblazer problems and share solutions here.
ANY IDEA'S !
Wacky
I have own a ' 03 TBlzer LTZ and it experienced a very similar problem. A vibration in the rear drive train around 55-65 mph, especially in cruise. It was particularly a noticeable when carrying a cargo load or when carrying 4 adults. When in cruise and accelerating up a long hill, it was really a problem. I called the local (large) Chevy dealer who claimed that they never heard of such a thing and were not helpful at all.. I called a small dealership out in the county and the SVC mgr said right off that he knew what the problem was and furthermore, there was a GM service bulliten on it. The fix was a new set of rear coil springs. I called the big deal back and they still claimed that never heard of the bulliten. Anyway it took care of the problem for me.
Good luck,
PMc
The bad tire idea is just that, a bad idea. Tires have been replaced with a high end Goodyear Fortura tire. Same exact problem no better. I replaced the drive shaft with a one made of steel, this increased the problem 10 fold. The original was out of round by .030 front to back. Not a HUGE deal. I placed the aluminum back into the vehicle because the vibration made it un-drivable. The spring theory could be it. I'm just theorizing how that could fix it. The ride high makes or has no effect on the vibration at all. The U-joint angle could be set wrong from vehicle assemble I suppose but all of this was a gradual problem that got worse.
One thing I notice those is the front end is very loose. The struts rattle over every bump. Sounds like their falling off at times. Maybe a connection their. My dealer is playing dumb and does not want to dig any further. Nothing like spending huge money and not getting the ride that it had when new. Their is nothing like making a payment on a vehicle that is a lemon. I must say those that of all the SUV's I have owned, this TB is the most comfortable of all.
Keep the idea's coming in. I appreciate it.
Wacky
I should have read your post more closely, I apologize for suggesting something you have already done. The other posts seem to be hitting on the possible problem. My EXT runs fine, so I'd appreciate an update if you find the solution in case I have to deal with it in the future.
***Keyless entry should lock/unlock one/all doors with horn/lights.
***Rear window wiper and fluid should work
***When key is removed from ignition, radio should still play for ten minutes, interior light should come on and windows should still roll up/down.
NONE of these are working or ALL of them are working. It's intermittent and hard to figure out the problem. If the door unlocks with the keyless remote, all of the above mentioned will work correctly. However, when i turn the engine off and the radio turns off too, I can't use the keyless to lock the doors and arm the alarm. I called the dealer (out of warranty of course) they said $500 for a computer Switch assembly with labor. Does this sound like a correct diagnosis? Any ideas? What can I check for? is there a site that has a diagram or description of what the modules do or which computer controls what? I'm lost. please help.
Any ideas? I'm tempted to take the dash apart and look-see but I'm afraid I won't find anything I can simply fix. Someone suggested to me that the relay switch (located under the glove box) may be bad... it almost sounds like a poor connection or short too...but what do I know.
Anyway...living in Las Vegas...A/C is a big issue... suggestions are appreciated.
Has anybody had problems like this? Also, I've read a couple of places that Chevy extended parts of the warranty for TB's for 5/60k. Is this true? This seems like a pretty big problem for a TB with low mileage.
Any help would be appreciated. Thanks.
-gmfan
Here's a TSB on your problem. Hope this helps.
My car only has 37k miles on it. I took it to the dealership today, but would appreciate anymore feedback so I can ask the right questions after they diagnose.
If it is a bad oil pump, would GM possibly help defray some of the costs (since it has such low miles and just left the 3/36k warranty period). If so, do i discuss with the dealer (not where i bought the car) or call GM?
I will definitely keep you posted how this plays out.
A head gasket problem that loses a gallon of coolant a week is probably also going to manifest itself in visible loss of power, overheating. I want to give you a little hope here by saying if you are not noticing anything else other than loss of coolant then you probably have something else going on besides a head gasket but just have not found it yet.
How many miles on your blazer? Have you pressure tested the radiator cap? If yours is a 98 and you've never replaced the cap now would be a good time. How about your water pump? Most of the time when they leak they do so through a weep hole on the underside of the pump casting where the impeller shaft runs through and leave a puddle but not always. With the engine off and key out of the ignition grasp a fan blade and they to wiggle it up and down or side to side. If you've got some play then it's time to have a mechanic check the waterpump. While you are at it, how are your radiator / heater hoses. When did you replace them last. The factory wire hoseclamps are junk. Replace them when you have a chance with real hose clamps, not the formed wire factory junk. If you have a leak on a hose at a joint that is near the exhaust manifolds, well the coolant will turn to steam once it comes in contact with the mainfold and all your evidence more or less goes up in smoke to be cliche.
I've saved the easiest for last and it's something that is frequently overlooked: Your heater core might be leaking. Check the carpeting on the pasenger foot area where the carpeting works it's way up the firewall. If you've got a leak there the carpet will be wet.
These are just some thoughts and ideas but if some of the things I've written above sound totally foreign to you you might be ahead of the game getting your blazer in a shop for a coolant system pressure test. Just giving you some ideas to try to save a little money by eliminating the obvious. Good luck. I bet you are going to find it's something minor.
Has anybody else seen this or have had problems with this vibration. Any help is greatly appreciated! Thanks!!
Here's a good one!!!!
Service engine soon light came on intermittently, then stayed on & reduced engine power light would come on too when car first started in the morning. aAfter car was running a while I restart car & reduced engine power light turns off but Service engine soon light still on. Brought to chevy dealer who put it on the computer & the following codes came up:P0530, P1221, P1634, P1481, P1635. They say main harness is rubbed through & faulty throttle body & both need to be replaced. I take car to my mechanic who does not see any damage to main harness, so thinks it just might be throttle body & orders the part. In the meantime I'm driving my car again & if upon exiting my car I turn on securuty system, all sensors get cleared out & car is running fine. What's up with that? Body control module shouldn't affect fuel system sensors?????
I opened the electrical panel under the backseat and was surprised to see a green wire snaked into the panel and clipped into one of the fuses. The wire was pinched flat by both of the panel covers. It appears that this band-aid was done at the factory.
OK here's an update- replaced the throttlebody & "reduced engine power" light went out but "service engine soon" still coming on. They figured it was actually a "bad computer" now instead. They replaced the computer & everything was fine
but the next day "service engine soon" light came back on. Everyone is baffled!
Any ideas????? :confuse:
Kevin
Both times, (they were months apart) it was the ignition switch.
Good luck
Hope that this helps.
Why ME!!!! Has anyone had this problem, if so did you ever get it resolved?
:mad:
