Chevrolet TrailBlazer Real World MPG
This topic is for TrailBlazer owners to share their actual MPG with others.
"Real World" Fuel Economy vs. EPA Estimates
Save Money on Gas
We Test the Tips
Save Money on Gas
We Test the Tips
-gmfan
Bruce
P.S.
Hemi? What's a Hemi?
A few months ago, my gas mileage dropped to 14, but I noticed it needed a new air filter. I replaced it and mileage went back up again. I use shell 87 octane gas.
Not bad gas mileage. I had to pull a 5,000 lb dual axle featherlite, and the 4.2 pulls it pretty good. I could use a little more power off the line, but it still works very well. No problems to report yet. I am already sold on the 2008 redesiged Trailblazer unless they go unitbody.
Friends of mine have 8 cylinder silverados that get same if not better mpg.
overall I think its not too good and I think gas tank should be at least 22 gal vs 18.
pure hwy somtimes gets 20-21mpg
I just out of warranty and don't know what I should do? :confuse:
i have a 2004 trailblazer LT when ever im driving and i turn the wheel and i sometimes hear this grinding or louder rubbing noise in front end so i went to the dealership under warranty and they sayed it was the mud flaps and the dealer installed them before i bought it and still the tire isnt even close to the mud flaps...they come up with some good ones somtimes! :mad:
can anyone relate to this?
P.S. GM factory recommended 30 front 35 rear psi (EXT)seems to be correct for maximum wear pattern.
Someone else said theirs gets about 13.5 in town, about 21 at 70-75 on the highway. That's very much inline with what I have always seen, stock or "tuned". The best so far was all between 65 and 70 it got 23.5. I have the 3.42:1 gear ratio. That makes a difference too. Each step up in numerical gear ratio will make the highway MPG less. Choices were 3.42. 3.73. and 4.10.
Any help would be apreciated.
This is unacceptable! Returning home we drove 55mph and got 8 mpg. Still unacceptable. Research - Trailblazer with 342 to 1 rear end gear ratio tow capacity is 5400#. 373 to 1 rear end is 5700# and 410 to 1 rear end is 5900#.
We found our 07 LT TB has a 342 rear end , our 06 LT TB has a 373 rear end. So the TB we were using was over loaded! Not towing the 342 gearing gets about 16 MPG while the 373 gets about 12 MPG.
My question is will the 373 get better MPG and struggle less towing our small toy hauler? How much difference does the rear end make in MPG and Towing?
I did ad a chip to the 07 LT TB with the 342 rear end before we went on vacation. it has made no difference in power or MPG.
Any information or help will be appreciated.
Bob
Hope this helps.
I don't know how oyhers are driving their rigs, but I drive fairly conservatively,only juicing it when I need to merge into dense,fast moving traffic.
I get no brake noise, and I get a measured 2 mpg better gas mileage! Measured by stock DIC. I am thinking of changing the back pads and seeing what happens.
