OW
I have been considering changing them to regular tires, possibly Michelins or other ones suggested by the users here. I mentioned it to the mechanic at my local dealership and he said that most likely the ride will be better. However, he said that the tire pressure will not work with the regular tire and will be lit up and there is no way that he can turn that off. That aside, he also said even if I do not mind the light being lit up, with that one, it will not pass inspection, anyone care to comment on that, am not sure.
I had a 2009 328xi as a courtesy, have to say that there is much improvement in the ride. The tires are still Bridgestones, but rides a lot smoother and less road noise. Obviously they have made a lot of improvements in regards to using these tires. So I was wondering if the new Bridgestones will work better with my 2006, anybody tried them?
My wife has a 2008 328xi with the Bridgestone EL42 RFTs with about 6800 miles on the odo. My nickname for her is Maria Andretti. She had a '95 318ti before this one with 134,000 miles. I fully expect her to keep the tires for, at least, another 20,000 miles. That should take about a year. Check back then for an update. She has the wheel warranty (dealer cost) as well. More about that later.
I drive a 2007 335xi with the Continental ContiProContact with almost 17,000 miles. Both cars drive well, with the EL42s perhaps a little stiffer in the corners. Both ride fine, but be sure you have the right inflation. I found that, after my dealer rotated (front to rear) and balanced the tires, they failed to inspect the inflation. This is especially ignorant as the fronts are supposed to be at 33 psi with the rears at 36 psi. There was a noticeable rumble when the tires were down in pressure. At the right inflation, the ride is firm, as it should be, but definitely not uncomfortable, and the rumble is gone.
The reason for the rotation and balancing was a complaint I filed after hitting a pothole hard with the right front tire. I stated that there was a shimmy and a perceived flat spot on the rim. They "checked out" the tire and wheel and found no damage. Their recommendation (which I had been considering anyway) was the work they did - $129.95. My intent was to take advantage of the $795 I paid for the wheel warranty. The tire never lost pressure, and the shimmy could have been attributed to ruts and the generally poor condition of the roads in MA. In any case, the ride seems to be better once I corrected the dealerships oversights. I consider this to be routine maintenance, which BTW, was not covered in the bumper-to-bumper warranty. No S$$$!
The blogs seem to indicate that the '06 Bridgestones were definitely of inferior quality. I agree that they have (reluctantly?) made improvements. IMHO, I think you're OK with either brand (Continentals or Bridgestones). I figure I can hit at least 30,000 miles with the Contis, and I'm happy with that. When you buy into a car of this class and performance, you should expect to pay more in the long run for tires.
Hope this helps.
xeye
That's one of the dumbest things I've ever heard, I'm thinking that it's time for you to find a new mechanic. FWIW, RFTs run with pretty much the exact same tire pressure as GFTs. Tell this failure of a mechanic that believe it or not, the same tire pressure will act the exact same way on the TPMS sensors.
If you feel like having a little fun at his expense, ask him to put that in writing and then send a copy to BMW.
Best regards,
Shipo
Anyway, the Bridgestone OEM tires are horrible. Noisy, rough and BMW refused to do anything about it. I've been corresponding with them, and they did nothing. I was able to suffer with those tires until 22K and purchased a new set of Michelin Pilot Sport PS2 ZP's. What a nice change. I actually enjoy driving this car again, for the first time in 14K miles. Michelin tires made a huge improvement.
The dealer wanted $2700 to replace the tires. Same tires from a dealer were $1500.
I would have opted for non run flats, but when I turn this car in, it must have run flats on it. Besides, there is no place to carry a donut since the trunk is taken up when the top is down.
This will be my last BMW (It was my third) after this tire fiasco. BMW really needs to adress a known issue. A car like this should not have such a problem tire as OEM equipment.
Have driven since I was 16 (now 66) and I have NEVER been so disatisfied with tires as I am with the Bridestones on my 2006 330i. Replaced new ones at 25,000 miles and now have 13,000 on replacements. Showing same wear as the first set did. Why not? They are rated with a 1 wear rating. Can't get lower!
By now, BMW must know what they are losing with this cost cutting measure. The negative feedback FAR outweighs the positive.
I have the Sport Package which greatly accelerates the cost of the rear tires. (Faster than the car accelerates).
If each of us that has shown a negative reaction to these tires (on this site alone) gives the same feedback directly to BMW of North America, perhaps (and I say "Perhaps") we will provide a service to future drivers who appreciate a fine car (not the tires it rides on).
John......Springfield, Oregon
I hear Michelin are good also.
Its a trade off between perfrmance and ride.
Just bought an 07 328i Coupe. Now have the OEM Bridgestones on there and am in the market for new rear tires. I've read a ton of bad reviews on these tires and wondering if I should turn to GFT's instead. I was thinking getting a regular set of tires and getting a emergency tire kit (fit a flat - continental comfort kit) but the guy at BMW told me that if I put something like that in my tire it will ruin the Tire Pressure Moniter automatically. Is this true? Has anyone put GFT's on their RFT recommended car? Going to buy tires this weekend and I really need some help!
the BMW could be different--this is the vette I am speaking about. I like the vette tmp better--I get a display of tire pressures--
when driving long distances thru mountains--os temps change and thus tire pressures change--somehting to watch esp at hi speeds like in AZ coming out of mountains into valley with temps changing significantly
- The RFTs that fit your car are typically more expensive than similar GFTs.
- When you buy a set of four GFTs, you're probably going to save at the very least $200 compared to the cost of the OEM rubber (and depending on which GFT you buy you could save nearly $500 compared to the OEM stuff).
- TPMS sensors are relatively inexpensive. TireRack sells them for your car for $49 per sensor.
- The way I look at it is if you're worried about the sensors, buy a spare or two when you buy your tires and Comfort Kit. Even still, you're going to buy a better set of tires, and the kit, and the spare sensor for less than you'd pay for a set of four OEM Bridgestones.
Best regards,
Shipo
re: donut spare and jack: if you just drive around town a bit buying a donut and jack is a waste because with the run flats you can get a repair or new tire in your local area. But if you are going on a long trip a full size spare tire is a good idea. No jack is needed. A call to roadside assist will change your tire so you can continue on your trip, which is the important part and get the blown tire either repaired or replaced upon returning from your trip.
Problem I have found for 3 years (2006 330i) is that RFTs are not allways available were you may be driving. For instance, I am in Springfield/Eugene Oregon and neither full sized cities have the rear tires for the Sports Packaged larger size.Fronts are fine. Portland does have them but that takes 1 day (so I am told by dealers here). RFTs are not yet widely accepted so accessability is limited.
I carry a "donut" in the trunk no matter. The tools including a power jack remain hidden in the well under the tire. I guess if a Bimmer owner makes full use of his trunk all the time, then he/she may see a problem. I don't as I only make full use when traveling or large scale grocery shopping. I guess since I never did have a full trunk (got the donut soon after buying the car) I don't miss the space.
Regards.....John
Appreciate your advice re Pirelli P7's as I am on 2nd set of Bridestones (37,000 miles) ans with Sports Package, tire replacement is very $$$$.
Regards.....John
I am getting a set of 4 new, NOT RFT's for my 07' 328i coupe and need some help with deciding on which to buy. Does anyone have experience with the Mich. A/S Plus? How different (Handling, Steering Responce) would it be with the Mich. A/S Plus compared to a nice summer tire. I hear the Mich are great. I live outside of Philly, so does get fairly cold in the winter. I don't want to do the summer to winter tire switch every year, so was thinking about going with A/S's. I don't plan on driving in the snow, but was wondering if it's safe to use a Max Perf. summer tire in the winter cold. Do you just loose some performance or is it a NO NO to use a summer tire in 25 degree weather (sunny and dry).? Any help would be greatly appreciated!
Jeff
Best regards,
Shipo
Got a set of PS A/S Plus' about 3 weeks ago from Costco. See my other posts on E90 for background on my 3 sets of RFT's.
With about 400 miles on them, they are noticeably more comfortable without being soft. Some noise, but less than RFT. Very slightly less turn in response and cornering agility than RF's. Wet handling seemed just as stable as RF's.
No warning about operating in freezing temps since they are A/S and will not feel like bricks in the winter.
Can't rotate laterally without dismounting from rims since they are directional. They should wear very well since there's a 45,000 mi. treadwear warranty on them. No warranty on RFT.
Costco mounting ran $15. per which included nitrogen, hand torquing and a road hazzard warranty. They handled my 197's with kid gloves. No scratches.
I bought am M Mobility kit for the trunk from Tischer BMW (MD).
Total price without tax came to $1,411.96...includes $70.00 rebate from Michelin.
Still pretty steep but BMWNA was picking up the tab.
REMEMBER - Don't go over 10,000 mi. if you want BMWNA thru your friendly dealer to replace them at no cost to you. But, they must demonstrate a noise/wear problem. Over 10,000 - 20,000mi., you might work a 1/2 & 1/2 deal.
My main concern was the steering responce...and sounds like it is very minimal which is great. How did you get the Michelin 70$ rebate...was that solely through Costco?
Michelin is giving the rebate thru dealers. Might be ending soon?
The good thing about Michelin and Costco is that, I had a brand new set of PS2 ZP's RFT on from Costco and could trade them in within a month if I didn't like them. I drove for 2 weeks. They're the best of the RF, IMHO, after experiencing all the others.
But....still wanted A/S and a little more forgiving ride. I live in NoVA now. Roads are terrible, and that's being kind.
Costco ordered them, then switched to the PS A/S Plus.
I'm lovin' em.
I wasn't charged since he really didn't have to make any adjustments.
Nice guy, with good business sense.
Alignment checks are very important when installing new tires of course--if it's seriously off, you can eat up a new tire so fast you wouldn't believe it possible.
just bought 09 328 sport package. read all about the bad experiences with the RFT.
You mentioned under 10K it's replaced by BMW?
how's the new tires feeling?
Again, if you have a RFT problem, make sure you bring it into your dealer and let the service mgr. see, feel and hear it. They usually contact the BMWNA Zone rep. who will come and check it out too. Be able to strongly state your case and the tires should speak for themselves. They're more apt to replace only the offending tires...usually the fronts, but push for a full set, especially if you're up around 10,000 mi.
Best regards,
Shipo
However, my wife's '08 328xi came with the Bridgestone EL42s.
I have ~17,700 miles on the Contis with about 8,000 on the Bridgestones. Both sets are wearing and handling well.
I believe the real issues with the Bridgestones were with the '05 and '06 versions as most of the threads involve those years. A lot of people complain about the CPO older models. I have no complaints about the newer Bridgestones - in fact, they seem to handle slightly better (read: stiffer sidewalls) than the Contis.
I have a feeling that the higher end model gets preference for the Contis and the 328* might get the Bridgestones. I don't think you'd do badly with the Bridgestones, but a lot depends on how you drive.
Hope this helps.
xeye
My 2008 335d came with summer Bridgestones. After 17,500 miles and a new pair of rear tyres of the same brand I have neither driving, riding nor noise complaint (RFT standards). Now is time of changing front tyres and I'm going for Bridgestones again.
Jose
BM-36120416268
BM-36116750007
BM-88881800859
BM-71106773536
CIRCLE BMW IN NEW JERSEY DISCOUNTS AND MAILS PARTS.
CRIS IS PARTS GUY.
RE:REPAIRING RUNFLATS-PLUG IT, PATCH IT, BALANCE AND MOUNT IT. BETTER THAN NEW. I DROVE FROM CT. TO FLORIDA AND BACK. THE TIRE DIDN'T KNOW IT HAD BEEN REPAIRED.
HOPE THIS HELPS.
The bm8888 is a cover for the tire. Try Tire Rack. Wheel specs are: bolt pattern 5x120mm, hole size 72.66mm, offset 47mm, wheel size is 17x8 w/ et34.
