Thanks for your input,
Sue B
Loud noise from under back seat in my 1989 Accord LXi Sedan 2.0 AT.
Took the tank off and lots of rust in tank and on fuel supply unit and fuel gauge sending unit. What is the little red thing mounted on the tank between the fuel sending unit and the gauge sending unit?
Thanks :confuse:
First off: When I go to start my car it clicks and doesn't make any sounds after that, but when I move the battery cables around it starts up. It may take a few times to get it to start. I noticed that there is electrical tape on the cable. Would that have anything to do with it not connecting? Would I need to buy a new battery cable?
Secondly: Whenever it rains the foor boards get soaked. Like not just wet, but like literally soaked. At first it was just my driver side but now its my passenger side too. Just wondering what that might be and how I could fix that.
Hopefully I got my point across. This is my first time posting a thread of any kind.
As far as the choke operation and choke pull off, you should be able to watch what it's doing when the car starts. Most pull offs I've delt with partially open the choke once the car starts by using the engines vacuum. Does the choke partially open when it first starts, and slowly open the rest of the way while the choke warms up?
Mrbill
I have 2 problems with this car that appeared at the same time, one day at startup, with no advance warning or change in performance.
Idle began searching suddenly from around 750-850 up to 2500 RPM's, constantly! No warning or change in running or performance prior to just starting it up one day and it began this. Cannot find any vacuum leaks, and know very little to nothing about Hondas, let alone early fuel injected models. I am very familiar with GM/Ford/Chrysler systems, and IAC valves etc. I have a Haynes manual as well as an 87 Honda accord dealer manual, but for some reason cannot seem to find a possible cause or solution. 1 mechanic mentioned a "thermo" control valve with a wax pellet type set up that sticks and can cause bad temp readings and lead to idle searching, but I find 3 "thermo" type valves listed in the dealer manual but no exact location, explanation or preceedure listed. No matter which thing I look for, the diagrams in the shop manual and the Haynes, have very bad quality drawings and pictures. Desperate for help as to where to look for cause and solution, as I am disabled on a very small fixed income, and this car never got less than 38MPG until this happened!! Temp indicator gauge also reads redline at what should be normal operating temp, does not use or lose any water, and is not the thermostat, so any ideas as to where this problem may also be?
Desperate for advice!! Thanks!
You are right, you don't want to try and rebuild those old Honda carburetors. I'd try every other remedy before getting into that rat's nest. The choke thermostat might not be too hard a fix, since I believe that is external to the carb. Maybe you could spray some carb cleaner around the choke butterfly to see if it's even working?
You might also try some fuel line de-icer, and also change out your fuel filter.
Let us know how it goes for you.
Have you checked the battery?
You can also check yourself for loose or cracked vacuum lines/hoses.
The idle issue in gear is most like an idle air control valve( IAC ) that has gone bad, sticking.
Any help is greatly appreciated as this is my only reliable transportation at the time.
Sorry for all the questions just trying to see if your headed in the right direction. After cars sit for a while things tend to freeze up such as vacuum advances, fuel injectors, idle air control valves and fuel can even go bad.
If the fuel pressure was checked during power loss then I would check to see if it has spark after power down if there is enough time to do so.
I cant think of a reason why the car seems worse after the fuel filter replacement that just doesn't make much sense. The plugs being dry is good but still nice to know if spark is available when car dies. Also makes me wonder about the injectors being clogged allowing enough fuel at idle but not off idle.
Just making sure of the complaint once again the car originally was idling great but once driving down the road would die? Or was it when coming to a stop it would die? Sorry if I am not understanding something but read back and not for sure..
The pcv valve, vacuum leak, tight valves, temp sensor and or the idle air control valve could be whats currently happening but there are test available for those components if you can get a hold of a service manual.
any help is much appreciated
http://images.google.com/
Corkscrew
If the former, you may have a simple problem of a bad brake light switch which will not release the gearshift "neutral safety" system. You can release the lever by inserting a screwdriver into a slot that should be nearby the lever.
If you mean the latter, your transmission is shifted hydraulically, not electronically, so you either have a badly adjusted or broken shift cable, no fluid in the transmission, or a bad transmission.
Anytime someone says "all it needs is a simple ____" one has to wonder why they never did it prior to sale.
