Thanks, I found my TCM box to solve D4 problem on Ebay and it's affordable. At Autozone parts store, they were asking $379 and I bought mine used on Ebay for $59.00. I hope it'll last me long.
peace
Jim
It's me again.
Here goes, I replaced all of my incandescent light bulbs with LED light bulbs and all the trouble lights came on. e.g. brake light on, turn signal doesn't blink check engine light stays on.
I mentioned this problem earlier on this forum but I forgot what I wrote. Someone wrote that I needed an LED compatible flasher relay.
I called all the parts house in Hawaii but some of them did not know what I was talking about.
Where can I get a flasher or relay to run all of my LED light bulbs. I took all the LED bulbs out of my car.
Any answer would be greatly appreciated..
Mahalo,
94shadow
Now, I must pose another question. I need to replace the wiper on the driver side. I already bought the blade and the arm. How do I unlock the current wiper so that I could put in new one?
The instructions that came with the Michelin HydroEdge wiper was not clear. It had instructions on how to install it but no instructions to remove the current wiper!! :confuse:
Help again!
any suggestion?
My Honda accord 93 has worn tires that feel hard and has no bounce. How can I get back that new car bouncy feel in my Accord? Should I get new tires before looking into springs and strut replacement?
cybercool
My Accord shakes a bit when at idle and I know it needs a tune up. Should I get the oxygen sensor and timing belt replaced? Or should I get a full complete tune-up? I just want my car to driving smooth without shaking. Thanks, Cybercool
After replacing my radiator, top hose and thermostat less than two years, I've noticed at a stop light my Accord's temp gauge starts to rise. There is no visible leaks when my car is parked over night. Can there be an internal leak somewhere? I've added water periodically but I think I'll have to do a thorough flush. Your thoughts please.
Cybercool
Thanks, Jeeper81
Good Year is the best to buy correct? They'll last for a long time correct?
Cybercool
I personally prefer Bridgestone tires, simply based on my good experience with them. I've never had trouble out of Michelins either; I have 47,700 on my 2006 Accord Michelin tires and have a good 15,000 miles or more left on them from the looks of things. The big question is how long will I wait to replace them... I will have had the car for 4 years in November; wet traction isn't quite what it used to be either.
Also from your comments--the fact that the battery post sparked on installation suggests that you might have a constant battery drain in the car.
Can a heat sensor be the problem for over heating? I just Spent $8 on antifreeze to see if it'll cool my engine down. Will the antifreeze help? I hope I didnt throw my $$ away on antifreeze. Thanks for your help.
jim
http://techauto.awardspace.com/ignitionswitch.html
My 93 Accord EX is dripping oil on to the exhaust. The leak originates from something between the oil filter and the engine. There is something that looks like a tin can attached to the engine, then the filter attaches to this thing. There is at least one hose attached to the "thing" as well.
This part is not mentioned or shown in my Chilton's guide.
I originally thought the leak came from the filter itself, but changing it made no difference. Next I thought oil was dripping down from the oil sending unit on to this thing, but changing the oil sending unit also made no difference. I finally got under the car with a flashlight, after cleaning all excess oil from the area, and with a light on the area can see the leak originating from between the engine and this attachment. It leaks only when the engine is running.
Does anyone know what this is, if there is a seal between it and the engine, what it is called, and whether it can be replaced?
Tom
Not sure, but it looks like it would be #33 in this illustration. O-ring for the oil cooler.
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&cat- cgry1=ACCORD&catcgry2=1993&catcgry3=4DR+EX&catcgry4=KA4AT&catcgry5=OIL+PUMP-OIL+- STRAINER
Much appreciated.
Tom
Tom
I have an automatic car and was wondering, is it safe to put my car in neutral while waiting at a red light? I just dont want to put too much force on brakes while waiting.
I've been doing this for a while now.
cybercool
trouble
I would be more concerned to the wear and tear to the transmission shifting it in and out of drive/neutral. Brakes are alot cheaper then a transmission.
Mrbill
Lets say you did shift the car into neutral, unless your on a level road, you still need to keep your foot on the brake to keep the car from moving.
Just seems like alot of work for not much (if any) gain.
Mrbill
I've had cars in the past (65 Pontiac Bonneville, my first car) that would stall, if you didn't put the transmission in neutral. My first Accord would vibrate, if the A/C was on, and I was sitting at a stop light. I would put the car in neutral, if the stop light was going to last a while. The V6 engine in my current Accord doesn't vibrate at stop lights, but from what I hear some of the 7th gen 4 cylinder cars do.
In Louisiana, 99% of the roads are very flat, and there is very little tendency for the car to roll in neutral. Even if it does roll a little, it takes very little pressure on the brake pedal to stop it.
Just trying to give some reasons for putting the car in neutral. Some may make sense to you, and some may not.
I have accord 93 10th anniversary edition. A couple of days ago, the Check Engine light came ON on the dashboard. After some researching on the internet, I found a way to find out what is wrong. I found out that the Exhaust Recirculation System is going out.
What the heck is it? How long can I go without repairing it?
How much will it cost?
Any help is appreciated. Thank you.
If you don't get the problem fixed it could maybe cause problems with the catyllitic converter, cause hesitation (especially on acceleration), and probably hurt gas mileage.
Mine has gone on three years ago and still running but a bit rough.
I want to repair it asap but with today's economy, I still come up short on doing it.
I found out my code 43 form the book and it's a fuel system supply issue.
cybercool
I'd like to know exactly what I need if possible, rather than the hit or miss trips to the HW store I've been making.
Thanks again.
Tom
I'll take another run at it today, but was hoping there might be a source to get the size so I can get a socket and get it over with.
Tom
