Sounds like an ignition switch (electrical part, not the lock cylinder) problem. If you hold on to the key, not letting it go all the way back when it starts, can you keep it running? The contacts in the switch get worn down.
Turned out to be my main cooling fan motor (the one you hear running off and on during idle in the summertime). Was around $300.
sounds like the ignition switch to me. Mine quit on me in town one time,but i was able to get it back home by holding the key about half way between start and run. It's an easy fix with basic tools. Have fun!
As long as you are not overheating.........you should be okay.
i wonder if you bled the air out of the system? their is a bleeder valve screw by the thermostat that you need to bleed the air out. Here is the run down for over heating i use on a honda 90-93 accord; fill up radiator with 50/50 mixture use a funnel in radiator and fill up the funnel so their is no air in the radiator,start car let run until fan comes on, (watching temp gauge always!) check that fan is running and heater is on full blast, Now find bleeder screw (it is by the thermostat hosing on the block) Loosen nut and turn the screw open wait until anti freeze solution runs out with no air bubbles. watch that anti freeze in funnel stays full as to not allow air in system,turn screw tight and tighten nut. remove funnel, rinse area with water, fill over flow reservoir as directed and check temp gauge. your done!
I appreciate you writing. KK
(not that we aren't brilliant mechanics, but the person who does them day after day has a large advantage in time-saving).
I was told that only Honda steering fluid should be added into all hondas. Well, a few years ago a mechanic added a generic brand when my steering fluid hose was fixed.
My car is starting to make steering noise when I make turns and I also notice rough steering. Can I just fix this problem by replacing old fluid with Honda brand fluid? Thanks
cybercool
Can I install new oxygen sensors without a catalitic converter? I dont want to throw $$$ away if it defeats the purpose. Thanks, Cybercool
Does a my 93 Honda Accord EX use two fuel filters?
Thx
cybercool
I'm getting this rough wobbly and annoying steering noise from my 93 accord EX. I was told to add only Honda steering fluid. How can I get back the smooth steering as if the car was new? Flushing with original Honda fluid will fix this?
I also understand it can be an alignment thing correct?
Thanks for your help.
Jim
My steering wheel shakes and vibrates, but got a balance and alignment and its perfect now.
Here in canada it cost about 80.00 for alignment and 20 for a balance
Can someone help me locate the oxygen sensors on my 93 accord? Are there two?
Is this something I can change myself? A DIY type of thing?
Or is a professional mechanic needed?
cybercool
I've looked in front of my car at the exhaust heat shield and I dont remember seeing it. Is it possible to send me a pic of where you see the Oxygen sensor on a 93 Accord?
jim
Just curious. I want to set a fair price on my Accord EX 93 for sale with the following problems. I have the car 4 years and it's been good to me.
Automatic and has 165,000 miles
driver side power window needs motor regulator replaced
Oxygen senors needs replacement.
ABS and light goes on
power steering makes noise when turning ( maybe due to non-Honda fluid?)
no visible leaks, car is in good body shape, black in color and beige interior
Jim
On a good day, with everything in order, cars like this might be worth $1500 to $2000, so with all your car's problems, you aren't going to even see $1000 in my opinion, as it sits.
Sorry for the late reply. I cannot post a pic here..........tell me where you want me to send the photo.
Titus.
Send it to cybercool66@yahoo.com
Jim
I'm getting this rough steering when driving and turning. I have a 93 Honda accord.
Can it be because I don't have the genuine Honda steering fluid inside the power steering reservior?
Jim
I'm getting this whinding noise when steering. I get rough steering. How can I reblenish the steering system so it can steer like as if I bought the car new. 93' Accord EX
What should I check for?
jim
