Code 1---oxygen content---Check the oxygen sensor, heater and the oxygen sensor circuit
Code 41---oxygen sensor heater---Check the heater for proper voltage signal
Try checking to see if the O2 sensor is even plugged in, or check for damaged wires.
If you're looking for cheap sensors try: Discount O2 Sensors
Good luck!
My belt(s) are squealing when I start my car. I know its possibly oil leaking, because I'm losing oil, but only when the car is on. I dont see any oil spots on the ground. What can I check and how do I check it? Thanks.
Well... my starter from my 93' accord EX went dead. I had my car towed to my place due to no-funds to fix. Is the starter a DIY work? It's near the front and visible. I found the starter for $87 at Discount Auto.
1. Disconnect the cable from the battery negative terminal.
2 .Remove the engine wire harness from the harness clip on the starter motor.
3. Disconnect the starter cable from the B terminal on the solenoid, and the BLK / WHT wire from the S terminal.
4. Remove the two bolts holding the starter, and remove the starter.
I need to change my fuel pump, and I was wondering if there was anything to be careful of, other than the obvious (I know gas is explosive, I will take proper precautions). Thanks!
Check the fluid and see how it smells.
My power steering pump fluid has this weird smell to it, kind of like burned out electric motors. Also, I noticed when I started up the car one day, I looked under the hood and the fluid was bubbling up out of the reservoir. It was the only time and hasn't happened again to my knowledge. The car wasn't hot, and the car handled just fine and the fluid was at the correct level (before and after). The smell also seeps its way into the car while we are driving, and it isn't pleasant, so I'm going to assume that whatever is happening, it is also happening while we are driving. I'm stumped as to what this could be. Any comments?
Just wondering if anyone had any tips for replacing the front oil seals. Replaced them earlier this year with the timing belts and water pump, and one (or more) is leaking gallons (not really, but it is ALOT) of oil while its running, and I want to make sure I do it better this time. Any thoughts? Thanks
I bought my 93 Accord EX with a dead odometer that stopped at 130,000 4 years ago. My car has been good to me with fixes and repairs along the way.
There's no way I'd be able to know the true mileage on my car. How can I preserve and maintain the engine to keep running even longer? Should I do the timing belt change and main tune-up?
I'm always thinking of selling it and getting another maybe newer Accord with a working odometer.
Please advise what to do.
You could remove the timing belt upper cover and inspect the belt for wear or oil-soaking, or cracks or any suspicious looks. You can easily see if the "lugs" on the belt are worn on one side.
Did it work by replacing the ignition switch?
Im having the exact same problem.
Lucyrafa310's problem sounds like a bad ground in one of the underhood circuits. These are something to be checked especially if the car has ever been wrecked in the front end. There are two main grounds located on the inner fenderwall. On the driver's side (this is on diagrams as "Ground 301", I think) it is near the washer fluid bottle (it looks like an aluminum box about 1.5x1.5x0.5 inches. You can take this box apart fairly easily and clean all the connections and reattach to the fender. The box on the passenger side is the same size and is located between the battery and the strut tower.
Tracing electrical problems in Hondas is a "joy"
Accord. Car runs fine,but have lost all gauge indications,except for battery lite.Pwr windows and seat belts inop.Have found a short in interior lights and radio circuit.Have not found the cause of those shorts. Have read a few pieces referencing ground connections near window washer bottle and on rt fender. Can locate neither. Know of grd to fender off of battery. Rplcd that cable. Am convinced this is a ground issue. Any help would be appreciated. :sick:
Hondas have odd combinations of things on the same circuit. Example, speedometer, cruise control, windshield washer and wipers are all grounded through G301.">
I filled it with oil (took about 2 quarts). but that came right out when the engine ran.
Tom
I wonder if you have way too much crankcase pressure, like from a clogged PCV valve/system.
Or, excessive oil pressure from a stuck oil relief valve.
