Honda Accord (1994-1997) Maintenance and Repair
1181921232437
  • ocruz265ocruz265 Member Posts: 1
    I just got my transmission rebuilt about a month & half ago. The place where I had it done gave me a 2 year, 24,000 miles warranty on it. It seems like other things aren't working properly, even falling apart due to the lousy job done on my car. My question is; if I have to buy the hose that feeds the fluid into the transmission myself, what is the cost of that part and how do I go about asking for that part? Does it have a name? Can I buy that one hose or do I have to purchase an entire kit just to get that piece?
  • cknapp58cknapp58 Member Posts: 5
    Bambu 151,
    I hope I'm wrong but I would say, you have a blown head gasket, 99% of the time you have to overheat the car to blow the gasket. I am going through the same thing right now. My son blew a small bypass hose and drove the car not realizing he was loosing water. It didn't take much by the time he saw the gauge it was too late. There are a few ways to check it. most of the time the car will be fine until it warms up, then it will
    1. start to run rough a little rough to sometimes real rough with more than normal steam and water dripping from the exhaust.
    2. If you have the correct amount of anti-freeze in with the water the exaust will usually smell sweet.
    3. If the gasket is really bad the overflow tank will over fill real soon after you shut off the car and maybe even with it running.
    when I pulled the head I could see that it didn't take much to blow it. I would take it to a shop and have it tested. This is something that you do not want to misdiagnose.
    1. The easiest way to test it is to use a smog tester to sniff the radiator with the cap off to check for exhaust gases in the radiator. 2, check the oil to see if any water is mixing in, it will look discolored. This doesn't always happen. 3, do a compression test, 3, pull the plugs and look for one or two next to each other that have signs of water. 4. do a cylinder leak down test.
    Carl
  • chuybarbachuybarba Member Posts: 1
    Honda accord 1993
  • honda_luvrhonda_luvr Member Posts: 5
    :sick: It stutters on acceleration and we can't figure out what is wrong. It's not throwing a code so I can't get it hooked up to a computer to check it. So far we've checked the compression (fine) changed the spark plugs, fuel filter, checked the Map (?) sensor the O2 sensor (fine) catalytic converter (fine).
    Now we are thinking it's internal. As in somethings wrong with the motor itself. :( Some one has mentioned the valves.
    Does anyone have any insight?
    EDIT: She has 225k miles on her.
    My 1996 Accord LX went through a tank of gas that caused the car to SHUDDER upon start up, and made it tough to crank. After that tank of gas it never had a problem though. Maybe it is bad fuel?
    I'm not a mechanic, so I really don't know what to tell you. Try the 1994-1997 Honda Accord Maintenance and Repair Forum - you'll find many more answers in there than you will making a topic yourself. Follow the link to it:
    1994-1997 Accord Maintenance and Repair Forum
    Sorry I couldn't be of more help :sick: . Good luck, and keep us posted :shades: . ;)
  • elroy5elroy5 Member Posts: 3,735
    Read this link about EGR ports, it may be your problem. I may have another link besides this one on EGR ports too.
    http://www.tegger.com/hondafaq/misc/t2t013.pdf
    Elroy: My husband cked the EGR the other day and said everything looked clean and OK to him. He said he'd ck out the link you gave me to see if he missed something.
    A lot of people check the valve, and not the ports. The ports are the problem more often than the valve. Mention that, and good luck.
    He just cleaned everything and while it was highly gunked up but it's still running the same.
    It's running rich too. You can tell it's loading up with fuel.
    :cry:
    REPOST: It stutters on acceleration and we can't figure out what is wrong. It's not throwing a code so I can't get it hooked up to a computer to check it. So far we've checked the compression (fine) changed the spark plugs, fuel filter, checked the Map (?) sensor the O2 sensor (fine) catalytic converter (fine).
    Now we are thinking it's internal. As in somethings wrong with the motor itself. Some one has mentioned the valves.
    EDIT: She has 225k miles on her. Just cleaned the EGR ports. " He just cleaned everything and while it was highly gunked up but it's still running the same.
    It's running rich too. You can tell it's loading up with fuel. "
    All I can think of that hasn't been mentioned is vacume leaks, intake restriction, or exhaust restriction. You may need professional help. :confuse:
    already cked vacuum leaks and the exhaust. We are thinking it has something to do with the valves. Husband (mechanic) is going to tear it down tomorrow and look at the valves. We are completely confused on this one and everyone I have talked to is stumped. :confuse:
  • sam421sam421 Member Posts: 14
    Check out the rear/front speed sensors.
  • ctlady401ctlady401 Member Posts: 1
    transmission fluid is leaking a lot, just had tune-up, oil change, and transmission fluid flushed
    Having a transmission fluid flush on an old transmission (and yours is fairly old) is a dangerous thing. It can loosen more bad things as it flushes others out.
    I'd take it back to where you had it serviced immediately.
    How many miles are on the car?
    For reference, I have 177k miles on my 1996 Accord LX and was told getting a flush so late in life was likely to do more harm than good by a Honda/Acura specialty mechanic shop.
  • mtnman5mtnman5 Member Posts: 3
    MY 1995 ACCORD HAS LOW AIR FLOW FROM THE DASH VENTS, EVEN WITH THE FAN ON HIGH. DID THEY USE CABIN AIR FILTERS IN 1995?
    Or, could it just be wearing out?
    I'm pretty sure the fan in my 1996 doesn't blow nearly as hard as it did when it was new. It's barely adequate, but for a 12 year old car with 177k miles on it, it'll do. :)
    could be wearing out, yes or even the air inlet ingested a good bit of outside debris (from tree leaves and hungry squirrel / nut eaters dwelling in trees above the vehicle). both are a common cause of evap coil pan drains getting clogged.
    Well, I can see the inlet to mine and I think it is clear. Just to make sure, which inlet are you talking about? (I'm talking about near the windshield wipers in front of the driver)
    Your are right, looks like it doesn't have one. Will need to take it apart and see what the problem is.
    Thanks man.
    Dave
    right, when you open your hood, it's a good idea when checking the oil and the coolant level, ps and brake fluid levels to remember to remove any debris sitting on the inlet at the base of the windshield. besides nut shells and tree leaves, pine needles are bad news too. eventually enough of the stuff gets sucked in and contributes to clogging the evap coil pan drain.
    symptoms of that is hearing a sloshing of water on turns, a hissing sound like water hitting a hot frying pan, and water in the footwell, damp carpeting and musty odors.
    Right, when you open your hood, it's a good idea when checking the oil and the coolant level, ps and brake fluid levels to remember to remove any debris sitting on the inlet at the base of the windshield. besides nut shells and tree leaves, pine needles are bad news too. eventually enough of the stuff gets sucked in and contributes to clogging the evap coil pan drain.
    I park outside, around many trees. This past fall I had to clean that area out at the very least once a week!
    Then you will likely find some of this when you change the cabin filter. There are some really hard to get to places on 7th gen cars. Have you thought of covering the vents while the cars is parked in this area?
    Since I drive every day, often leaving early in the A.M. and getting home after 11 P.M. (such is life as a TV News Intern), covering the vents would not be a viable option.
  • amandaakersamandaakers Member Posts: 4
    Okay..I have a 1996 4 door Honda Accord V6 and it has 170,000 miles on it....(I know it's a lot).
    I've had it for about three years and I got the igniton coil replaced, a new timing belt, new spark plugs and fixed some oil leaks.
    But once again I have another problem. Don't get me wrong. I love my honda. It's wonderful and I wanna make sure I can fix this problem.
    Just recently I noticed that if my boyfriend drives my car over a pot hole or a big dip there is a bump noise and I can actually feel it under my foot in the passenger side of the car. It also makes the bump noise when I turn right a lot. I don't know what it is. Im scarred to drive it too far.
    Also another minor problem is that when I'm driving normally not braking or anything the back wheels of the car will squeak a lot. I'm not braking. I don't know but if someone could give me advice that would be great! I need to know if my car is safe to drive or not!!! Please Thank You!
    ~Amanda
    Sounds like the front strut is blown out. Given the miles, I don't doubt it.
    The rear squeak could be nothing more than old rubber bushings. A good spray with WD40 might quiet those down. If not, could be a rear strut damper maybe?
    But the front struts need attention sounds like.
  • trumpcartrumpcar Member Posts: 10
    Ok i have a 94 Accord coupe manual. when im driving and im changing from 3rd to 4th gear once engaged and in gear a start to hear a noise like if it was a broken CV boot but i check both inner and outer on both sides and nothing. or if i change into a higher gear but at a llower speed it will begin to clunk but then stop after 50mph or so but will begin at about 40 wiht gears changing. im a student at a technical school in the automotive program and it even stumped my proffesor so if any one has had this problem then hey let me know, but other then that the car is great. Also if i where to change my tranny fluid with it nearing roughly180 to 190,000 miles and not knowing when it was changed last really do so much bad, even if there wasnt a problem before?
    A simple drain and fill may or may not help. But I advise against a (power) flush. A power flush can force particles from the bottom of the transmission, where they are doing no harm, up into places where they can clogg up they flow). A drain and fill will not replace all the fluid, but it will give you a good idea under what conditions the transmission was operating. There is a magnet on the drain plug. If this magnet is a large glob of metal shavings and sludge, it may have never been changed in it's lifetime. If one drain and fill (requiring 3 quarts of Honda ATF-Z1 only) shows some improvement, and the condition of the old fluid was really bad, another change may help too.
  • sfranzosfranzo Member Posts: 6
    My 1997 Honda Accord Ex engine light came on. It has 71,000 miles. Took it to Autozone and code is po137. Was told it is Oxygen sensor #2 just before the cat. converter. However, I do not know if I should buy the 4 wire or 2 wire. Has anbody had this problem and suggestions are welcomed.
    thanks :confuse:
    This should still be under warranty, as the emissions system (including the Oxygen Sensors) was included in an extended warranty for 150,000 miles or 14 years on Accords from 1995-1997.
    Do a search for message # 108 in this forum for more details.
    I have had two O2 sensors replaced under this warranty in my '96 LX. This SHOULD BE FREE for you.
    Keep us updated.
    hmm i see, well its manual and only requires 2 qt's but of motor oil not tranny fluid i found that a lil surprising.
    :):) Yes, you are correct. I called my Honda dealer and it is covered. The rep. said they may charge a $92.00 diagnostic fee if necessary but everything looks ok. I found the Consent Decree from the U.S. Justice Dept. "US v.Honda Civil Action No. 98-01433, DJ, Ref; 90-5-2-1-2170 :)
    Thanks for your help.
    Thanks for your help. :):)
    You're very welcome. They really shouldn't need to do the diagnostic.
    I agree. The Agreement also reads spark plugs, wires and oil changes.
    I will let you know, have an appointment with the dealer wednesday.
    Again, thanks so much for your help.
    You are very welcome. Hopefully the previous services haven't been performed yet so you can get them all new. Mine was done around 88k miles, but I got yet another O2 sensor close to 150k miles when I threw a Check Engine Light again.
    There's no way to know if a CV is going bad except by a) noise and b) taking it apart. A visual inspection while it's assembled on the car, or even attempting to grab it and wiggle it, won't tell you anything.
    Since the higher gears put the most strain on the driveline, you might very well have a bad CV joint.
    You might try and find an empty parking lot. Lock the wheels to the extreme left and go around in a circle with a bit of speed (people will think you are crazy but so what); then turn it to the right and do the same. This usually will annoy the CV joint if it is bad and it will start clanking away.
    If it's bad, replace the whole axle assembly as a rebuilt unit, unless you just want to learn something by replacing only one of the 4 CV joints.
    i did that not a squeak. its only on the straight line never in a turn of either extreams. im thinking its the tranny maybe th clutch either way i dont kno i took out all the cv's replaced one cuz the boot was riped and changed out my bearings and still so im almost sure its the tranny. but dont got the cash to get the parts so it aint bothered me so much im still gettin crazy good mileage, and i drive it about 400 a week and it still goes so im just gunna keep doing wat i do and treat my baby right! ;)
  • autoboy16autoboy16 Member Posts: 992
    OMG I HAD ALL OF TH ABOVE!! I thought it was all coinsidence! I had approached the parking curb to much and backed up and the sound I thought was the bottom surubbing the road as i was turning was actually water(it had a waterfall sloshing/scraping sound)! I had washed my car and shampooed my carpets and i thought that because it was cool, it was taking to long to dry! I had the musty odor, but I thought it was just the air freshener that just went bad and dried up!! LOL i was totally oblivious!
    It got fixed awhile back at AC Delco when I did that tune up! There was water everyehere on the floor! I felt dumb!! Totally embarassing!!
    Glad to know what actually happened!
    -Cj
  • kahele2002kahele2002 Member Posts: 1
    I have a power steering leak somewhere. I'm constantly filling it up every other day. Would this be something I could repair on my own considering I'm short on funds right now. Will it cause other damages if I don't get this fix right away.
  • sbtweedssbtweeds Member Posts: 2
    I recently rolled down my driver side window and now doesn't want to roll up. The passenger side windows roll down but dont roll back up from the master window switch. I have to roll them up by reaching across to the passenger door. My rear driver side window does roll up and down from the master window switch.
    Want to know if it is my master window switch or Power Window Switch Control Module/Relay???
  • mamamia2mamamia2 Member Posts: 707
    ...Just stopped by for a short visit... I haven't been driving the '96 Accord for exactly 2 years now (did a trade-in for an '06 Sonata). Keep up the good work, thegraduate, let owners know about this extended warranty that could save them a lot of money.....
    Im doing my best! Check in anytime!
  • bioraybioray Member Posts: 3
    My 95 accord 4cyl vtec runs rough at low speeds with light throttle. Changed coil wires and plugs whith no improvement. I disconnected the vacuum line from the egr valve and the problem magically disappears. What's up with that. Is it the egr valve or the control solenoid or that vacuum control thing that is beside the egr control solenoid. Any help would be appreciated
    The EGR valve and/or ports may be clogged up. It's a common problem. I used to have two links describing how to clean the ports, but unfortunately they both seem to have disappeared.
    Hey! found one. It's not as good as the 95 specific how-to, but it will give you some idea.
    http://home.comcast.net/~em-engineering/T2T013.pdf
    Ok I didn't post it but i had an issue with my car for a few days. I was traveling down I95 in traffic and I noticed my car began to run hot. I was just passing the South Beach Exit and was in dead stop and go with no place to pull over. It began to get frighteningly hot so I got off at the MLK exit and took some back roads until my car cooled down. I stopped at my uncles house and he found out that a cooling fan(well the accord has 2 and the Left from drivers seat, right from viewing it was the culprit)wasn't working. He tried to hot wire the cooling fan with no luck. He added antifreeze and let the car cool down while watching American Idol. I drove home on I95 in NON-CONGESTED traffic without the car getting hot. It was like a 70's beetle, Aircooling! At the few red lights on the way home, the thermometer rose and feel when the car began moving.
    Come Saturday (I car pooled to school that week),I bought a new Shroud, motor, and fan for $90 and when I finally(with my dad and neighbors help) uninstalled the old one, the new one didn't fit right! I should have took a picture. Literally, the wires were on the opposite side and the the holes for screws weren't close to lining up.
    After r- packaging it back into the box, I took the Expedition to Advance Autoparts and got an exchange for just the motor and was refunded the difference(~$46). Got home put the new motor on old unit,reinstalled everything and all was good.
    It took about 2hours but I saved about $200 on labor to be a D.I.Y.-er. 2days later and the two fans work great! And I got to see the fight!
    Though aging and 3generations behind the times, my accord is holding up fine. maintence is low, easy, and quite cheap! I don't know how that'll change WHEN I get my Jetta/GTI MK4/5 or possibly gen5 prelude.
    Soon, I'll post a PIC of my neighbors new 08accord v6. Its like mine but sans the spoiler and adding navigation, cylinder deactivation, space, safety, weight, power, MPG, and a beige interior.
    -Cj :) :shades:
    That post confirmed what I was thinking. I disconnected the vac tube to the egr valve and my problem disappeared. One more question. Will it hurt to run the car with the egr valve vac tube disconnected? No time to fix during the week. Thanks
    I have no idea what it could cause, other than you would probably fail an emissions test.
