yeah, a broken or failing engine mount.
there's a test for it. you can google it. i think it involves putting the brake on with the vehicle in gear and applying a bit of throttle to see if the engine moves appreciably. maybe it is in the accord '02 forum, but something should be found on the web.
I have a Honda Accord 1997 with 202000 miles on it (Auto, 4cyl) that seems to have spongy brake. Every time I step on it I feel like I am going to hit the floor. Is this a known issue and if not what needs to be done about it?
P.S. I recently changed my disk pads and shoes.
http://syclone.motocrew.com/CG5/brakebleed.htm
Just wanted to say thanks to everyone(esp mamamia) for all the help with my car over the last 1.9years!
Cheers! Many more reliable years with this great car and this great forum for info! Its been a great 1000... Well 1001 now!
-Cj
I have 97 Honda Accord with 82,000 miles on. The wheels need alignment (by local mechanic shop). I am also planning to change both sides of drive axles because of broken CV joints (DIY).
I am wondering if I would change drive axles after alignment or vice versa. Are these two systems close related? Does it matter in order?
Thanks for your reply in advance.
sdd
Help please,
Nitro74d
Did you get the problem corrected?
What the heck is the O2 sensor heater?
I bought a plug which they told me fits, however I have not been able to locate the place it belongs in.
Thanks for any help.
Charles
HC ppm = 1800 allowed 127, NOx 1600 allowed 910.
replaced the catalytic coverter (results were reduced to 300 NOx ppm, HC remained 1800.
Replace the oxygen sensor HC ppm = 2000, NOx=1600 both failed,
Timing is good,
No vacuum leaks,
Plugs have been replace.
How can I reduce readings to within allowable limits?
But such high HC is almost always an incomplete combustion issue, i.e., ignition or related.
Maybe funky injectors?
Brief Summary: Larger cooling fan not working. Replaced motor($48), sender($32) & sensor($12), and checked fuse by switching wtih power windows. Windows still worked. Still no action from larger fan(the right looking into car. Left from drivers seat) while smaller A/C fan is still working. Need Ideas, a part name, or repair place. Local mechanic recommend sensor and sender change. When hot wired to the battery, larger fan worked perfectly... but I cant leave it like that!
I asked at Autoparts Advance. He recommended a Temperature Switch change($44).
Car gets to 3 quaters hot but thats as high as it will go as running my A/C provides some cooling as smaller a/C fan still runs. Not the Thermostat as when it says the car is getting hot, it starts to act sluggish and the interior begins to feel hot. Only noticed at red lights. While moving(25+mph not and directly behind someone like traffic), mother nature cools the car down to normal operating temperature.
Currently Carpooling and Driving Dad's Expedition (OMG IT CAN BURN $80 IN GAS IN NO TIME!!) and can't wait to be back in my own seat and to stop paying $80 in gas...
:sick: -Cj
http://techauto.awardspace.com/overheating.html
Good news is that there is this nice 1994 Acura Vigor MT sitting at the local dealer ... :P They want $3,700 and its whistle clean too!!! Iheart5cyl's too!! BUT thats if my car kicks the bucket beyond repair and I find $3,700...
-Cj
I also have a few other problems that I would like to have fixed. I love my baby and have been driving her for the last 12 years. I bought her brand new and have taken good care of her. She's just getting a little old and I need someone who can help me take care of her!
I wrote this post about poor mpg when I first got my accord. The mpg was so bad that I was even thinking about getting rid of the car. Well I’m glad I didn’t.
It seems that city driving is terrible on my car. I get about 200-15 per 13-14 gallon tank. The car performs completely different on long hauls. I took a 250 miles trip today and only used half a tank of gas (I filled up on ‘regular’ from Mobil). I was cruising between 60-75 mph most of the time. I haven’t done much work on the car. I did a tune up (plugs, wires, fuel filter) and added a can of valvoline Fuel Injector cleaner about 2 months ago.
Do you think the mpg will increase by adding a cold air intake? The muffler is also shot dead - the join to the exhaust pipes is rotten and pretty much broken off.
Thanks for your help!
PJ
so then i turned it off and now it wont turn over. tried pushing it while it was in gear [clutch was in], and the car wouldnt go. put it in neutral and parked it. now it wont go back into gear.
aaah! help!
I only drive 3 miles to work daily in cold weather and my car has 157000 miles. Not sure if 14 miles per gallon city driving is normal given the age of the car and the driving conditions. I'm going to purchase a new valve cover gasket kit and some fuel injection cleaner additives to see if it will fix the problem. Please let me know you have found a fix or if you have any suggestions. I'll also keep you updated. thanks, polo
Whoa, whoa, whoa. Your car doesn't even have time to warm up. It's running extra fuel the whole commute trying to get your car to normal temp. Combine that with winter fuel, city driving, and any extra warm-up time your car has, AND the fact that you get great highway mileage, and I'd say there's nothing wrong with your car. 3 miles is a painfully short commute; painful for mileage, that is. I used to get under 20 MPG in my 1996 LX years ago when my commute was 2.5 miles. Now that its 13 miles, my MPG averages 28 now, 30 if there's more highway than average.
I'd say nothing major is wrong if you're getting 275 miles on half a tank (8.5 gallons) when doing highway driving. That's over 32 MPG, on a car with an EPA estimate of 31 hwy. You're doing fine, it's just your short commute that really hurts you.
Elroy, wouldn't you agree that this is the main reason for such low mileage?
http://www.tegger.com/hondafaq/oilyplugs/index.html
PS: This is not an easy job, so if you don't know what you're doing (somewhat mechanically inclined), like they say "don't try this at home". One guy said the dealership was going to charge $350 to do this job.
so I finally found a decent 94 accord LX in the neighborhood. (my old 94 was stolen two weeks ago and I was desperately seeking a similar one!)
There are few problems with the car - i'm wondering about how much I should expect to spend on the following:
1) the power locks don't work - if i try to lock from inside, nothing happens so i have to manually push down the lock. And the rear windows do not open - I assume the wiring is messed up?
2) the speedometer doesn't work - it stays at 20mph the whole time - sometimes it goes up and down a bit, but it's definitely not working
3) the antenna is broken off
Any ideas on how much i should expect to spend?
1) Engine lacks power
2) sometimes after starting once I engage R. the RPM's drop noticibly, like it is about to stall.
3)After driving a bit I have gotten used to the smell of oil buring but not out of the exhaust, I have a small leak that drips on the exhaust pipe.
But the big one:
4) I cleaned the K&N air filter and replaced it and was about to change the sparks when I noticed a lot of oil on 3 of 4 plugs. I was extremely upset since I have had this issue in the past and EVERY mechanic recommended a valve cover (cheap part, 1 hr labor). I have done it once a year for the past 5 years already :sick: and feel that there is another problem causing this. Any ideas?
Also can I continue to drive like this. I have to drop off a B-day gift for my cousin downstate (A Wii game) and really want to get it to him but am worried about the Black Pearl (My car) :confuse:
One last question: Could the problem relate to my EGR or my Valves needing work and can I do that myself? (I'm a bit broke at the moment, otherwise I'd be in the 2008 V6 Accord Coupe :shades: )
Don't let anyone tell you it is the speed sensor. If the cruse control works the VSS is okay.
Been there done that, I got a used Speedometer for $200.00
If you replace the head only, Caution the assembly screws are also electrical connections , do not over tighten. the connecters will break.
Look at complete Assy parts at:Honda calls it a COMBINATION METER .
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&cat- cgry1=ACCORD&catcgry2=1994&catcgry3=4DR+EX&catcgry4=KA4AT&catcgry5=COMBINATION+M- ETER+COMPONENTS
Have a '96 LX sedan and the radio has been going in/out for some time now. Display stays on, just loses sound. Doesn't matter if I'm listening to AM, FM or CDs. When it goes out, it varies from a loud "pop" and then no sound to a gentle fade (like I've lost reception). When it comes back on it does the same.
No rhyme or reason to how it happens or when it happens. My initial reaction is that there is a connection between the radio and the speakers that has come loose.
If so, does this mean I have to tear into the dash?
Any other likely culprits?
Oh and I fixed my antenna problem uninstalled it, fed the cord through again and all is fine a month later. The only hint of bad news I have is the odometer being behind a just a little bit , and the small oil leak I have now. I think that citrus sent( :lemon: ) has just about faded away.
-Cj
#2. last week i noticed that my ABS light kept coming on randomly out of the blue either as i riding along the road or when i stop. i hear something click for a little while. also i having been hearing a vacuum sound every now and then but thats been going on for a while. Or my radio goes off and on for no reason. but now i noticed especially when i stop at a light or sign, my ABS light comes on, my lights go dim, and my radio goes off and comes back on. it seems to happen when i push my clutch in. does anyone know what is going on before i go to the Honda place and spend too much money on something simple?
I don't think your ABS light is related to your dim lights and haunted radio. What you describe sounds like your ABS pump is going out. That is pretty common in Accords/Acuras. Mine went out long before 100k but I never replaced it because the dealer wanted $1600.
The vacuum sound is the pump trying to come on. It finally gives up and stops working and then the light comes on. Oddly enough, the one time in all those years that I needed the ABS, they actually worked... even though the light was on. Saved me from a guardrail in the snow.
Well, Accords and Acuras of this vintage, anyway. I've never heard of problems with the 1998-current Accords.
http://www-odi.nhtsa.dot.gov/recalls/results.cfm
Regards
Corkscrew
