I'm new to this site, and I was checking it out because I just picked up a 97 accord coupe LX. I was a honda tech from 94 to 97. I saw some one post that you needed to get an alignment after having drive axles replaced. This is not true. Breaking loose the lower ball joint will not disturb anything that has to do with your alignment. If anyone has any questions please feel free to ask. I may not be able to troubleshoot everything, but I could point you in the right direction.
I can't really comment much on the other issues though, simply because I haven't had them.
I know it is in hindsight now, but next time you get a quote for so much $, get a second opinion. I got one quote on my timing belt for $720, not including changing the water pump (which should be done when the belt is changed, every 90k miles in this generation of Accord 4-cylinder). I got another quote for the belt, waterpump, and new antifreeze, and the total was right around $400.
When in doubt, check it out.
Honda's 94/97 rotor design makes this a horrible task.
The complete steering knuckle has to be removed on both sides.
The wheel bearings are destroyed when removed from the knuckle.
This has to be done to get the rotors off.
This job is not for the casual home mechanic.
You need the proper tools, which the casual home mechanic will not have.
Brake Pads/Shoes - Front about $30.00.
Brake Rotor x2 about $60.00.
Wheel Bearing - Front x2 about $100.00.
I just completed this job on my own car,
The $723 including labor for a place of business was a fair price.
Check it out at
">link titlehttp://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528003a46a
Some models may be different, example models with rear discs.
98 changes and the the front rotor is held on by two screws and is pulled from the front. This is simple to do.
The AutoZone link does not always have the exact/correct illustrations.
Step 13 of the AutoZone link says!
On late models of the Accord and Prelude, use a hydraulic press and suitable press tools to remove the front hub/bearing assembly. For specific details, refer to the hub/bearing removal and installation procedures in this section.
I will not put any information on this site unless I have done the job myself.
No WAG’s from this ole boy
Read the book for complete documentation.
http://hondatech.info/downloads/Auto/Manuals/Accord/
The brake rotor on the 94/95/96/97 Honda Accords that I have worked on has the rotor pulled from the rear of the hub. They are held on with 4 bolts. Total dismantle of the knuckle assembly is required.
On a cold engine, I can hit 4k+ RPM without problems. About 15 mins after I start the engine, the check engine light turns on and the car won't go over 3k RPM. I can drive fast, slow, or drive to the gas station and turn off the engine and it's almost always 15 mins after I first start the cold engine. When I hold the gas down steady, it will oscillate between 2.75 and 3.25k RPM and if I give it more gas, it will back fire periodically while oscillating.
Been meaning to go over to a friends to get the code but haven't been able to sync up with him. Anyone have any ideas what is going on? Am I completely hosed?
Thanks in advance for any help...
-Ds
Both. After the check engine light goes on, I can't go over 3k RPM in neutral or on the road. It may be a little higher in neutral but not much more.
It's been awhile since I posted, but having a problem with the power antenna on the car. It''s making "the noise" and won't let the antenna retract or extend completely. I have taken the whole thing out and have done some research to see if I need to replace just the mast or if I need to replace the entire power assembly. I've gone to this site (http://home.earthlink.net/~michaelpkeefe/HowTo_Antenna_Mast.htm), but it's for a '94 Accord. I just can't seem to pull my mast out of the housing. It sounds like there is something that prohibits it from coming out all the way. So, do I have to replace the whole thing or is there some trick at getting the mast out? Thanks for your help!
PJ
So, it seems clear I need to pull the clutch & remove some shims. I've never messed with a compressor clutch & there is precious little clearance from the end of the clutch to the inner fender - maybe 3/4". I'm not sure what I'm getting into here. I don't think there is enough clearance without pulling the compressor & then I'm not sure you could do it without evacuating the system? Can you do this with the compressor in place or must it be removed? I'm wondering if I might be better off to take it to a reliable mechanic & have them do this. I wouldn't expect there to be too much to it for them....maybe 1 hour labor or something like that? Any opinions or experience on this? Thanks again.
The car runs good, no trouble codes, no engine misfire, in park there is no vibration.
What was done to correct the vibration problem?
:confuse:
Thanks for your help.
on the other hand, i have also had two 86 accords automatics and they would vibrate when i stopped also. i would shift it out of gear also. all my friends have hondas also and they speak of the same vibration. i just think its a trademark of a honda. its kind of irritating but i got 483,000 miles out of my 86 before a deer totaled it and pushing 250,000 on my 97.
PS: If the engine vibrates more when the A/C or some other electrical accessory is used it could also be the ELD (electric load detector). If the engine rpm does not increase a little, when the A/C compressor kicks on, the ELD may be the problem.
I have the same exact car (year/make/model) and your mpg matches what I get. One piece of advice, start using high mileage oil in your engine. It helped mine dramatically. It still runs well after 189K miles on it.
By that point, the gauge was pretty much at "E" though. I've noticed when my car gets much below the 1/4 line, it takes more turns to crank the car, so I've quit letting it go much below there. The light is a very last-minute type of light, however, so filling at 1/4 is a safe way to go, 1/8 if you must. Keep in mind that some sediment may be at the bottom of your tank, so if you go too far, maybe the potential for picking up that sediment increases?
Hope this helps.
I understand what you guys are saying about running it that low, I was just kinda curious on how many miles I can get on a tank. I wanted to try it but like I said before I would hate to try it and for some freakin reason my light doesnt come on. It just amazes me on the difference in mpg on my 04 Ford Supercrew 5.4 and on this honda...I fill the ford up with 20-22 gallons and get about 400-410 miles. This car on the first fill up took 12.5 gallons and I got about 350. I hope this car lasts a long time like some of the other stories Ive read on here.
The previous owner had owned the car for 8 years and they made the switch to mobil 1 synthetic. I think mobil 1 has a synthetic high mileage, would it be a big deal to switch if I wanted to? Anything special I would have to do?
Thanks again.
Help!
TheGraduate
Next idea? :confuse:
Let's just say it cost me a lot more than $57 before it was all said and done. :shades:
A plugged A/C drain would result in water coming out onto the floor board; you'd have wet floormats (my foot got wet on my way to the dealer as water dropped from the A/C system, so I turned the A/C off.
Water wouldn't leak out the top, it'll travel down to the bottom. If water droplets are forming on the vents at the top of the dash (above the climate controls), I suspect little more than condensation, and have this happen all the time. I cycle the A/C on and off, and the humidity causes this.
That being said, I have no idea how to clear the drain.
