Honda Accord (1994-1997) Maintenance and Repair
1585961636493
  • erchavezerchavez Posts: 5
    Got it. The drain connection is right under the glove box on my 94 accord. I pulled off the hose and water went everywhere! The blockage was up in the catchpan not in the hose. I just took a peice of wire and poked it back up into the catch pan to clear the debris.
    I have an engine sputter that seems to occur between 1500 & 2700 rpm. Outside of that range its fine. I have no check engine light and the local Goodyear guy says its the dist & rotor....Replaced those as well as the plug wires and plugs.....injectors ar cycling and have the correct resistance between terminals (2.5 ohms).
    Anyone got any ideas? I'm stumped!
    Never Mind.....clogged EGR ports in my air intake.
  • Hi all,
    I have a 96 honda accord with 180000 miles have a speedometer that goes from swinging wildly to dead.....odometer and cruise control only works when the speedometer works. Tachometer works at all times....engine seems to lurch at times as well. believe it is the vehicle speed sensor but want to be sure before i order it. when i look at auto zone or e bay it shows a small control unit or 1 with cords coming off of it....i dont understand which one i need.....also is this just off of the distributor? any help with testing, removal, and replacement would be great.....is ordering one off of e bay ok? thanks, keenan
  • elroy5elroy5 Posts: 3,741
    This link is mostly about 90-93 Accords, but your car is probably very similar. It has troubleshooting, so you can test parts. Good luck :D
    http://techauto.awardspace.com/vss.html
  • thegraduatethegraduate Posts: 9,731
    I should mention here that my '96 Accord LX had its odometer/speedometer fail at 111k miles. It wasn't the VSS.
    Not sure how you'd check to see if it was one or the other, as my speedo jumped around (going from showing proper speed, to zero).
    That's why it's important to diagnose/trouble-shoot a problem, before just guessing a part. Good point.
    The speedo clusters have been known to go out too (do you know some of them were made by Ford? :surprise: )
  • bkempebkempe Posts: 1
    I have a 1997 Honda Accord. I recently purchased an iPod, and an FM transmitter for it. The cigarette lighter was spinning around, so that the iPod wouldn't stay were I wanted it to. So, I pulled that panel off, and saw that the rear portion of the cigarette lighter wasn't attached. I screwed the two pieces together, then put the panel back together. Since I was't doing anything significan to the electrical system, I left the battery connected. Once I got things put back together, the cigarette ligher didn't work AND the radio back lights would come on, but not the radio. Does anybody have any ideas where I should look for either a broken wire or have I totally screwed up the car?
  • I just got a 1997 Honda Accord Special Edition. The check engine light was on when I bought it. I went to auto zone to use there tester and I couldn't find where to plug in (typically under the steering wheel), the worker couldn't find it either. Any ideas? Can you turn the check engine light off with a sequence of operations like other Honda's? Thanks!
  • Tim,
    On my 96 the plug is behind the ash tray....try pulling the ash tray out and it should be right there......good luck....ktk
  • daves14daves14 Posts: 2
    The radio and lighter are on the same circuit, I suggest you check the fuse, under the hood, passenger side, on top near the windshield.
    Same thing happened to me. To remove the center console see directions at http://www.installdr.com/InstallDocs/Honda/PDF/466037.pdf . I removed the 15A fuse for the radio and lighter circuit before doing this to prevent shorting out the circuit. The female part of the lighter when you use it screws into a larger female cylinder behind the console. (A transgender part).
  • omarromarr Posts: 88
    keenanknight is correct about location of the OBD-2 connection, behind the ash tray
    I believe that you must use a code reader to read the OBD-2 codes.
    To turn the check engine light off.
    1. Turn the ignition switch off.
    2. Remove the BACK-UP (7.5 A) fuse from the under hood fuse/relay box for 10 seconds to reset the ECM.
    The fuse/relay box is on the passenger side near the firewall and hood hinge.
  • ive got a 97 accord with an auto . it will drive to the bottom of my 100 yard driveway then quit. it just revs like its in neutral. if i get out and unhook the batt, and hook it back up it will drive about the same distance..... could someone please tell me what i might do to fix this situation? thanks in advance
    More info needed.
    Does the motor quit?
    Does it do the same in all gears?
    Are you sure unhooking the battery does anything?
    Can you wait the same length of time with the motor off and move the same distance after restart ?
    Have you checked the transmission fluid level? Use only Honda compatible fluid?
    Is the check engine light on?
    How was the car acting prior to this condition? All of a sudden yes /no
    Two questions. Does the D4 light start flashing or go out (even when the car is in Drive), when this is happening? When you start the engine, is the D4 light on, even after 2 seconds (with the shift lever in Park)? These are signs that the transmission computer is toasted.
  • i had the same problem and went ahead and replaced the float system in the tank and made sure i had a good ground. . now it works. i ran out of gas 2 times figuring it out. my gas lite works now also. these cars are something else. but im sure if u do that your probs will be solved.
    i got the float on line at carparts.com for 67.00 i have another veh. i learned not to do to a dealer. even thought a carparts place dont show it listed. if there is a will there is a way.
    dealers always mark up there parts. i get even after market parts. at least they work.
  • check the bulb. if the trany shifts ok its not the trany. . check the ground comming off the wiring harness. the hondas esp the ones made in canada have alot of problems with ground connections.
  • check the buld socket. or ground. if the tranny shifts ok its not that. .
    Change the Master Cylinder.
    Honda is notorious for the M/C to fail with an internal piston seal failure.
    You will not see an external leak, The fluid is bypassing the seals internally.
    Bench bleed the new MC first.
    Install M/C, snug the brake lines, leaving slightly loose.
    Press pedal to the floor and hold, tighten the lines, finish bleed all 4 wheels.
    Been There Done That on 94 and 97 Honda's.
