Honda Accord (1998-2002) Maintenance and Repair
Mr_Shiftright
Member Posts: 64,481
In order to make the original and highly popular “Honda Accord Owners: Problems and Solutions” forum more manageable, we are dividing that forum into “Accord generations”.
Please make sure you are in the right generation for your Accord, and then post your questions concerning any maintenance or repair item.
Thank you again for helping to make the Accord forums so great here at Edmunds!
MrShiftright
MrShiftright
I own a 2002 Accord EX with about 45k miles on it. Lately when driving at night I've noticed a slight fading in the brightness of the instrument panel readouts, sort of in the center. The markings near the end of the tach and the beginning of the odometer are fading a bit. Any ideas/suggestions? Is this an easy fix? An expensive one? Unfortunately, the car is out of warranty now, but has been trouble-free so far.
http://www.autorecalls.org/1998/38667.shtml
Some guys say just replace ignition switch, or main relay.
Bought a 98 accord lx about 8 days ago from a dealer. Seemed fine. had 93k on it. the transmission failed yesterday. I have no warranty. Is the dealer liable or responsible for any expenses? The car stopped in the middle of the road, the mechanic said that the axle had popped. Please advice.
I had not checked the car with a mechanic before buying it (should have), trusted his word that it was fine. And I do not have any warranty, the dealer sold it as is. Now I am not sure which way to go. I haven't spoken to the dealer yet. Should I go to 'Better Business Bureau' if the dealer does not help? It is not even 10 days since I bought it.
Please advice.
Axles normally don't just pop out unless something is really worn, or the car just had an axle replaced, and the installer didn't correctly lock it into the transmission. If it's the latter, then it may just need to be reinstalled if nothing was damaged.
You may want to have the car inspected by a mechanic to see what failed, and if an axle was just serviced, you could argue the dealer incorrectly repair the car.
Good luck
Mrbill
I dont know as to why the axle failed yet. It may have worn out. I am getting it inspected by a mechanic. thanks.
Obviously, the only thing necessary is the timing belt. If that fails, it will damage the engine. Replacing the rest of the parts, well, how much are you willing to gamble? They could last till the car need another timing belt, but if they don't, you will be paying alot for labor at that time to have them replaced.
Since I do my own belt, I did it all except for the seals.
($70 total for non Honda parts) You can see where the cost comes from, LABOR.
Tough call
Mrbill
I'm sure like anything else, there is a quality difference between the brands of aftermarket parts. I would think that brand name aftermarket parts would be just as good as Honda parts, they may even be the actual supplier of the Honda part. In some cases with aftermarket parts, you can save $$ with rebuilt parts. Water pumps are a good example. they save castings and just replace the wear items. It was interesting though, I was able to purchase a new water pump for less then some of the rebuilt units. I suppose that it came from somewhere overseas. 30k miles so far with no problems.
That's the one thing that bothers me about going to the dealer to have service work done. They get a premium price for labor, and a premium price for parts as well.
Mrbill
Second question is that the light behind my milage/trip-ometer is not working. Honda book does not cover fixing this. The fuses have been checked and seem fine, therefore I assume it is a bulb. Anyone have an idea of how to get to this or how to repair it without going to the dealership?
Issue:
I purchased this car used at a dealership. Before taking it in to them i want to see if i can take care of the problem myself. When accelerating to about 40mph and 2k rpm's the rpm needle begins to fluctuate up and down. The vehicle/engine feels as if it choking or stalling. When it is past this point i dont experience this problem any longer. Also, when it is below this speed i dont experience the problem either. The check engine light is now on as well.
I would really appreciate the help.
I own a 2000 Accord with 95K miles on it. The clock works, but the back light doesn't, so I can't see it at night. Do I have to replace the bulb, or the clock, and is possible for me to replace it myself? Thanks! :confuse:
He says the part will run around $1100.00 and around $450 in labor for the job! This is my first Honda, and the way it's going, it may be my last! Your thoughts??!
I'll check with my local Honda representative if there is similar coverage on my vehicle!
Have a great New Year!
One of my friends said his car had same problem. He simply found a leak on the fuel pressure regulator. Reeplace it, the problem was solved.
Another person with same problem solve it by replacing the torque converter clutch solenoid. When the converter clutch is engaged, it provides a mechanical link between the engine's crankshaft and transaxle input shaft, eliminating converter slip and increasing fuel economy 3-4 mpg. Very common on GM fwd 3 speed transaxles (occasionally affects overdrive models) for the solenoid to become contaminated with ferrous wear particles and bind in the applied position. The clutch can't release, and the net result is the same as stopping a manual transmission vehicle without depressing the clutch pedal.
I am just quoting others' suggestion for your reference. Keep up posted about your problem.
Does your car have an automatic transmission? If so, the engine speed fluctuations around 40 mph may be the torque converter lockup "hunting" - especially if you're ascending a slight grade. Either slow down below 40 mph or speed up faster than 42 mph. (Once locked to vehicle speed, the engine speed will decrease around 200 RPM, so I suspect that's all it is.) If the former owner or the dealer changed out the automatic transmission fluid with non-Honda fluid, a condition known as "juddering" can occur, too. It's the same process but more pronounced due to non-Honda fluids not having the proprietary friction modifier chemistry for smoothest possible TC engagement in Hondamatic transmissions.
Car still has the high-pitched squeel. It seems as if it goes away when I accelerate. I think it can also be heard when the car is stopped with brakes pressed. Any thoughts?
The only thing to which I can compare it is my old Ford Bronco II, which with 100,000-plus miles started making a similar noise for a few seconds on cold starts (valve lifters leaking down and having to refill with oil, or so I understand).
Anyway, I've had the car to the dealership for this issue (I bought it certified used). They adjusted the valves, but it made no difference.
Anyone have any ideas? Similar experiences? This can't be normal; it's not a subtle noise. It bugs me that my well maintained, low-mileage Honda makes this kind of a racket--particularly when other Honda 4-cylinder engines I've heard sound like sewing machines in comparison.
Never got anything but "could not duplicate" from the dealership. It was a leased vehicle that I returned shortly afterward, so never really had to deal with it. In my case, at least, it seems unlikely to have had anything to do with the transmission fluid, as I leased the car new and know it was never hanged (car only had about 28,000 miles when this started).
As an aside, I don't own a Honda. I own a Hyundai Sonata. Hyundai came out with a technical service bulletin about six months ago implicating unnamed aftermarket oil filters in a knocking noise at idle. Word on the street is that FRAMs were involved, though I have no way of verifying that allegation. Still it's curious. I haven't used FRAMs for over a decade. FRAM was acquired by Honeywell Systems a few years ago and that's about when the rumors started about their declining quality. Yet the fact that Honda trusts FRAM to make their OEM and service filters for the north American market has to count for something, too, I would think. Please keep us posted.
Can some one shed some light on this, please?
Good Luck,
E.D. in Sunny Florida
Does that sound like a reasonable idea? Why don't they do it, Cost or to keep you coming back to buy new cars?
It was something you could swith on just before starting the engine. I think they only circulated oil in a low pressure, just enough to lube bearings and other parts, but would do nothing for things like valve lifters since they have to pressurize themselves.
Have you searched for an electric oil pump?
UPDATE: http://www.emp-corp.com/html/products/advanced/oil_mgmt/electric_oil_pump.htm
Mrbill
http://dodgeram.org/tech/dsl/prelube/
But my ORIGINAL question was, Why don't the Vehicle MANUFACTURER'S put a prelube system in their cars?
It's just one of those things that's probably best left for the aftermarket installers.
Mrbill
It looks as though I will probably be replacing this unit myself or with the guidance of a mechanic buddy of mine.
I didn't hear much on the difficulty of a left front wheel bearing r&r...
A horrible raspy growl starts at about 15 mph and gets louder with higher speeds. It maintains noise level according to rate of speed regardless of gear shifts or rpm level. I suspect the wheel bearing. Any advice of which manual to purchase for these services would be appreciated.
google: +shudder +egr +honda
The preprime oil pump would be neat as a part of a cabin heater that uses the oil for heat. Quick heat on cold winter mornings. My college roommate had one in his car.
Thanks in advance for any help...
