I don't like leaving the car in gear when we park because someone could bump the car and damage the transmission.
With the car in gear, the transmission is, in effect, linked to the wheels. If the car is bumped and moved 6 inches, then the wheels will move, and that means the gears in the transmission will try to move. For the transmission gears to move, the engine will have to turn over a little.
This could put a lot of stress on the geras in the transmission.
if however on level ground, and specially if parking for several days, say in an airport parking lot, i will not engage the brake, leaving it instead in gear (if manual) and park (if automatic) only.
I set it when parking anywhere except in the garage at home.
To give my vote, I've never applied the handbrake to park except when taking my driving test. I find it funny that some people refer to the handbrake and some people refer to it as the parking brake.
I've also been told that with manuals you should park it in neutral with the handbrake engaged to avoid tearing up the transmission as was said about automatics in the previous posts.
On a stick, I learned that way, and swear by it. I also leave the car in gear just to be safe!
IMO, I don't want the weight of the car being held by the tranny (or the parking prawl on an AT). Just can't see how that could be good for it!
It is such force of habit now that I doubt I could leave the brake off anyway.
I am still amazed that people put their car in park on a slope and let it lurch back (or up!) until the trans catches the weight.
Oh, and I thought the handbrake adjusted automatically (maybe when you abck up?) although that might just be the brake part, not the handle.
But, I would not have done either (and neither would my wife) if we had parked our AT Odyssey. I guess, using our foot is too unnatural.
But seriously, for extended stays on the level, i will not apply the HB or EB or PB in our ATs. Just won't do it unless I forget to avoid doing so. :shades:
To return to the original question in bobst's post #3249, and a couple of responses, if any of us has had our cars at the Honda dealer's shop for any kind of service, the tech may have adjusted the cable linkage and the owner may never have been made aware of it. I wouldn't be at all concerned about bobst's 26,000 mile adjustment.
At some point the clutch is released, and the transmission and engine are forced to rotate by the push (usually quite a few yards before the engine starts), and I've never seen a manual transmission or engine damaged by this.
Now there was a time many years ago in my 95 that I used neither while visiting a friend who's street was on a very slight incline. A neighbor knocked on the door asking if that was my car a block down the street up against a curb. How it didn't hit a parked car, I'll never know. :sick: So much for sticking to my habits!
Pry the panel up starting from the rear (closest to the arm rest) being careful not to break it. I didn't want to have to post too many pictures, if I don't have to. Let me know how it goes. Good luck
Mike
Hmmm, we just had our 2006 accord at the dealer to replace a Mass Air Flow sensor, and asked them to tighten up the hand brake because we have to crank it up pretty high to hold on our driveway. I counted 12 clicks before it would hold.
The dealer, said "sorry, the handbrake is not adjustable, it's designed to adjust automatically".
He lied to you
The passenger side is the one I posted earlier (by accident). I don't think there is only a switch on the driver side. It's the entire control unit for all doors. This is the pages for the control unit (I hope).
Shocking...Car dealerships have always seemed so honest to me...
Pffft. Sorry, it's hard for me to keep a straight face while saying that.
-A/C compressor clutch will not engage, was intermittent to begin with,system
is full, i've confirmed power at the compressor lead
-Sunroof opens fine, but shuts only after 5-10 min of repeatedly hitting the button,
it does not move forward at all until that 100th ish push of the button
-Drivers door lock actuator is dead on LOCK...unlocks fine.
This car has 55,000 miles on it. I'm the second owner. Bought it at 33k in Jan of '06. I took it to a dealer for diagnosis and asked for some good will from Honda last fall. The answer was "pay for diagnostic and we'll decide after it's diagnosed" ..$400 to remove head liner for the sunroof...$200something to pull the A/C compressor. And a simple "NO" on the door lock actuator. This is amazing for a Honda...I've owned more than I can count on two hands. I've referred to it as my "Ford Accord" Starting to think that I should apologize to Ford for the slander.
Go by what the manual says, not the dealer. The dealer is out to make money.
You shouldn't be filling so full as to have the fuel get that high in the filler neck anyway - you could damage your car's vapor canister (somebody who knows more can chime in here, I can't currently remember the exact wording for it).
I fill up til it clicks, round up to the next quarter, then I'm done.
With regards to the vapor canister, I don't know much, but I do know that overfilling can cause a car to go into vapor lock (I believe that's what it's called.) I know that because a friend of mine has a habit of filling the car with too much gas and then driving off. She did this once and got about 10 feet from the pump and the car just quit on her. Apparently there was too much gas and it couldn't vaporize effectively and therefore couldn't be burned off. These are my two cents.
I got a couple estimates so far and one was $698 and the other $793. I want to see if I can do it myself or have a friend who may know body work do it, but I also don't want to screw anything else up.
To put it in perspective the crack is about 1.5 feet long and there are softball sized holes along the lower edge of the bumper, could ice have been driven under the car to create that sort of damage when it was hit?
Anyway, I know that the color on mine is about as common as booger green or earwax cold was in the 70's which is to say it's everywhere. I have a silver coupe and honestly every coupe I've seen of the generation save maybe 6 has been silver.
Not sure where you work - if its a shopping center type of place, its anyone's guess. As far as where I work, its the same people every day.
I've become a Target fan since then - more medians in their parking lot so you can park in an "end" parking spot, get half the chance at a door ding, and buggies are stopped from rolling all the way across because of the curbage there.
You best bet might be to find a used one in a wrecking yard. I really is pretty simple to pop on and off, so if you could find one cheaper, it might be the way to go.
Depending on what the damage is like, it is also possible to patch it. My body shop offers that, but on my car, the bumper was too deformed to just patch the hole.\
So that, or silver duct tape?
