Most of the junk yards around here have primarily 10 year old cars and older.
That's a little phrase I just made up for hitting the front end of a parked car.
Still there? Still need it? If so, let me know, and I'll copy it for you.
1) my brakes make a slight grinding noise when applying them but it doesn't happen all the time. it seems to happen mostly after a rain or when there's a lot of moisture in the air. And it isn't a loud grind, it's very subtle and sounds almost more like a rubbing noise. it's very low-frequency as well. And it always goes away after a few minutes of driving the car. is it time for new pads? any other ideas what could be wrong?
2) when it's cold out the starter takes a couple extra seconds to start. it always starts (at least up til this point) but in real cold temperatures (below freezing) it sounds like it's about to die right before it starts. what could this be?
3) in that same cold weather, i notice that sometimes the acceleration is a little choppy in 1st and 2nd gear (mostly 1st). i do let the car warm up for at least a minute before i drive. any ideas what this could be?
thanks!
#2 - most likely your battery is at end of life. They normally last about 4 years. Take it to an autoparts chain (pepboys, autozone, etc), they do free battery and alternator load checks.
#3 - not enough info, given engine performance could be a zillion things.
2.) This is normal for most any car. I have a 2006 which takes longer to crank in cold weather. Any battery will have less charge in cold weather (by cold i mean Freezing or colder, typically). If it is WAY off from normal, you might get it looked at for free like Kiawah mentioned, but I ran into this the other day when the low was 17 degrees, and my car is much newer than yours.
3.) This is normal as well, in every Honda we've ever had this has been the case. (2000 Odyssey, 1996 Accord, 2003 Accord, 2005 Accord, 2006 Accord). In fact, all of the symptons have applied to all of these vehicles, except the 1996 which seems immune from the oxidation on the brakes.
To repeat, everything you've mentioned seems well within the range of normal operation. Also, you don't have to let your car warm up - drive moderately (keeping things under 3,000 RPM) until the car gets warm (check your temp gauge). This prevents excessive waste of fuel, and won't hurt anything at all. Just don't go redlining when the engine is cold.
Honda puts a real weak battery in the Accord. Mine just turned 2 years old, and in 40 degree weather, it sounds like it is almost dead.
Last oil change, it tested fine, but that was 416CCA (off of a rated 440cca). Most replacement ones are rated at 600-700, which certainly could explain why it is lethargic in cold weather.
THe brakes do sound like oxidation being scraped off (I get a lot of grinding like that too, and my pads checked out at almost new thickness). You didn't mention miles, but most tire places will do a free check, or just get it done with the next tire rotation.
I love my 2.4L, just thinking about some things that aren't quite pleasant about it (obviously I'm nitpicking to the nth degree here, just thinking out loud).
-- How can I check the engine mounts?! 600rpm maybe right, but I still insist that for a V6 this car vibrates execively at idle speed in gear... As I mentioned before, my '06 Sonata, a 4-banger, is a LOT smoother when idling in gear...
I'm gonna bring it again to the dealership, have the service manager sit in the car but then also COMPARE it to another, comparable Accord. If that's the way the V6 Accord was designed, fine with me. But I want to check it out first.
Mrbill
my theory: you can blow a fuse easily if the charger plug / accessory port aren't aligned well in the process of plugging the charger or other accessory in. this causes the tip of the accessory to short the accessory port's contacts.
if this fixes your problem, you'll know what to do going forward.
driver side door lock doesn't lock/unlock from control switch.
so i went to dealer to fix it.
it took five hours and they charge me $405.34.
The problem is that part was $37.34 but labor fee was $362.95.
Is it normal?
I have a 2004 Honda Accord EX 4 door. which I rarely take to the dealership. I have recently replaced the brakes and tires but have done nothing else to the car besides change the oil approximately evrey 3,000 miles. The cars has about 75,000 miles today. I do have an extended warranty. Is there anything I should do to the car to prolong its life? Transmission fluid? As you see by name it inspired me to buy an MDX. Any help would be appreciated.
Thomas
I would change out 3 quarts. All the fluid does not drain out, so you can not totally replace it. Use only Honda ATF-Z1. The condition of the fluid that drains out will tell you how frequently to change it in the future.
You may have a wheel bearing going bad.
Sorry about not being able to help more.
Does your car have the remote windows, which can be opened from the transmitter? If so you can always open them and unlock it that way. I think if it's an LX or higher it should have them. I've been told that the DX's don't have some of the things like that. Sorry I'm rambling.
It would probably be easier just inserting the key in the driver's door lock and twisting it.
If you have full comp, you could always brake glass, but there is probably a better way than that I hope.
