Quick Links
Quick Links
any feedback is appreciated
Joe
- replace engine oil
- replace oil filter
- replace oil drain washer
- replace transmission fluid
- replace engine air filter
- replace distributor ignition cap and rotor
- replace brake fluid
- replace spark-plugs
- replace HVAC filters
is this worth $470 ?
I'd like to replace them but am a bit confused as to what to get. Anyone here replaced their OEM tires yet? Not interested in plus sizing; just want to stick with the original size.
Over in the Tire Rack forum, a Tire Rack representative stated that Honda only requires H rated tires for 2003+ generation Accords, not V rated like I have now. Can anyone confirm that? There are many more choices available in H rated tires, and at better prices too.
Just wondering. Thanks.
Webby
I definetly agree with you [djm2]. Thanks for the help
tranny? Any better reliability?
Some local shops will refuse to put tires on that don't meet the OEM specs.
I find that with some tires specially Michelin's car seems to wonder all over and other tires will track as though they are on railroad tracks.
The reason I asked you the size is that a lot of times you will get the tire mismatched with the vehicle and therefore performance will vary.....that is typical of reviews in Tire Rack reviews...same tire with different feedback.
I find that BMW knows how to match tires and Honda has no idea.
Webby
LX sedans were equipped with 205/65HR15 tires. Taller profile, smaller diameter, and lower speed rating.
o "Weak acceleration in short-ramp fast freeways (--I was able to remedy this by using D3 gear initially and then at the right moment shift to D; now I'm also incorporating the "2" gear when making sharp turns that go uphill, shifting from D to D3 then "2", then D3, D depending on the slope; yeah this automatic transmission can be operated as a "stick" without having to worry about depressing a clutch!)" .....not normal, real HP comes at 5200 RPM but you should have enough power and not have to go to the D3 mode....not normal
o" Low MPG in mixed city-highway (60%-40%) driving -- only averaging 23.9 miles per gallon!" .....I have not calculated mine yet but I know it is not good.
o "Obnoxious engine sound when running between 40 to 50 miles on a hilly road (is this what they call "gear hunting"?)" ...again not normal...try another brand of gas ?
o" Noticeable "rough" auto transmission shifting, especially the first drive in the morning."....not normal...mine is smooth regardless of outside temp and how long the car has been sitting outside
Thanks for your reply.
So you think there are many abnormal observations with this car. What I find interesting is your assertion that the real HP comes at 5200 RPM! Do I need to be that aggressive on the gas pedal when trying to merge on short-ramp fast freeways? I seldom exceed 3000 RPM, if at all!
Another interesting point you made is the possibility of eliminating some of my problems by using another brand of gas! Really? What brand of gas would you recommend?
Regarding the auto transmission, there are really times when the shifting is kind of "noticeable" or "rough", but most of the time it's smooth.
As for the MPGs, other owners think that they're representative of my driving conditions and driving habit.
Regards, ramida
I took the car to a Honda dealership, at first they said their tech did not hear this noise and this is normal noise for a Honda 4cyl. I told the service manager that I have owned 12 cars since I've been driving, including 4 Honda Accords(4 and 6cyl models) and I did not hear this type of noise from any of them on cold starts and gentle driving. So he took a ride in my car and another 4cyl Accord on the lot. He did admit he heard the noise from my car and not the other car. He finally agreed to keep the car another day and have the tech adjust the valve clearance on the car.
The car was returned to me the next day still making the same noise on cold startup. I did not keep the car at the dealership longer or argued with them, because it was 3 days before Christmas an I needed my car.
I think the car is not getting enough oil circulation (oil pump problem) because after the car warms up in 10 minutes the motor is nice and smooth. I did mention this to the service advisor, which she denies is not the problem. My car only has 11,000 miles on it.
If anyone has a clue to this or has a 2003-2005 Accord 4cyl with this issue please let me know and if this issue was fixed by Honda so I can get my dealership to fix it. I don't want to wait until the warrantee is expired and shell out big money for this. Thanks.
Hermann
Hermann
Will a 2005 I4 EX go faster than a 2005 LX I4 with the same transmission. I doubt it, the 2 tires have virtually the same rolling diameter(815 & 816 revs per mile) so I can't see why it would make any difference..
Hermann
Very interesting !....can not find the bulletin on the web.
Can you please attach the link or copy the article.
I would love to take this to my dealer and have them contact Honda HQ.
Regards
Webby
I find that when merging or needing a burst of forward momentum, being decisive with the gas pedal makes a big difference. Don't slowly depress the pedal, you need to create a downshift and depressing the pedal quickly really helps. You don't have to floor it, about halfway will do it. You have a marvelous powertrain (best part of the car) don't be scared to use it. Honda's love to rev. Turn the radio down, and enjoy the marvelous engine sounds. I passed a car yesterday doing 45 in a blink by just pulling the lever back to third, and giving it about 3/4 throttle and letting it rev to 5500 or so. Then shift to regular drive. The only things you will lose is a little bit of gas.
Hermann
Webby
....give it a try, can not hurt anything !
"Another interesting point you made is the possibility of eliminating some of my problems by using another brand of gas! Really? What brand of gas would you recommend?"
......I use Sunoco and Shell ( in Canada ) if can not find Sunoco .....my 330i had nothing but Sunoco and is running like a turbine....I am putting Sunoco in the Accord but to few miles to have an unbiased opinion.
When I wrote:
"EX sedans original equipment tires were specified as 205/60VR16. You should not "downsize" to H speed-rated tires.
LX sedans were equipped with 205/65HR15 tires. Taller profile, smaller diameter, and lower speed rating."
I did not imply that the EX would go "faster" than the LX. It is a fact that a 60-series V-rated tire will make a vehicle handle much better than a 65-series H-rated tire. That's why the best handling, cars are specified by their manufacturers to use the lowest aspect ratio tires. For example, Corvettes, Aston Martins, Lamborghinis, Ferraris, etc. use 30, 35 and 40 series tires.
Paraphrasing the Tire Rack: "The 65 indicates that this tire size's sidewall height (from rim to tread) is 65% of its section width. The measurement is the tire's section height, and also referred to as the tire's series, profile or aspect ratio. The higher the number, the taller the sidewall; the lower the number, the lower the sidewall."
This thread started with a response to crankky's post #65. Please read there.
When the headlights are on and I stop moving,after about 5 to 10 seconds, the headlights dim. It is as though something turns on and drains the electrical system. The AC and heat are off. I used to see this in older american cars, and it coincided with an AC compressor turning on.
Do any of you experience this? We do not have this condition with a 2000 civic.
Also, the dealer is adding a foam strip to keep the light in the glove box from seeping through the crack at the top of the door. The glove box light is always on when the headlights are on. I guess it's cheaper than adding a switch.
JA1
The moral of the story: 1) Take your car to more than two or three dealers to get more answers and don't take no for an answer; 2) Buy extended service contract since it covers literally everything; Honda cars don't make them like they used to be.
Hope this helps.
Over these Christmas holidays, wife's 03 Sedan's headunit also blacked out. Dealer yesterday made a big deal of it, I waited 1.5 hours while they "got clearance from Honda of America," and said "...good news, we'll pick up the tab on the replacement and you just pay $95 for installation."
Got it down to $42.00, but without Advisor stressing that an "excellent" satisfaction survey was the least I could do in return.
Honda of America issued a TSB last year, clearly saying that they'll foot the entire bill.
Other Accord owners can take the cue from this post, and to car dealers/salespeople on the forum: honesty builds loyalty.
I have the exact same thing on my second car (99 Civic EX) and it started at 40K miles. I took it to the dealer multiple times and they said it is normal. The last time I went they did a valve clearance adjustment just like yours but it did not help at all.
I KNOW that it is not normal, and would appreciate if somebody sheds some light on this issue. I gave the car to my brother to get a 05 Accord LX and hope that I do not have the same problem with my new car in the future.
In another month after the holiday, I will take my Accord to another Honda dealership to see what they have to say about this problem. I will post here if I can get this problem fixed. My ca is under warrantee and it has been making this noise as far as I know at approximately 8,500 miles.
also we know that TSBs are sometimes used to circumvent the need for announced recalls...
I imagine a TSB - where Honda of America fully absorbs the attendant costs - to be somewhat stronger than a simple advisory.
But you're right, almost everyone would agree that from a legal standpoint, it's the dealer's option.
That the dealer opted not to take the high road (they're getting full compensation from H of A anyway) means the win-lose game between dealer and customer continues. Unfortunately, imo.
Can you fully and accurately document your claim that "honda has a reputation for soft, thin and super orange peely paint."? That would probably be news to the vast majority of Honda owners.
The operative words in your message are "a few people". While if the problem is yours or mine, we consider it to be serious. However, that doesn't necessarily make it widespread, as steve58 implied.
The only paint problem on my 2004 Accord is where some careless person slightly ding'd it when opening their door in a parking lot. Otherwise, I'd consider it perfect.
I have no idea whether Honda has a paint problem or not, and it's not something I really even care about. My last car was a Civic I had for over 10 years, and I can count on one hand how many times I even washed that car in that time span.
Anyone else have this problem? Mine is still under warranty so I'll get it fixed, just curious if it's the switch or what, and if it's a common problem.
Dave
