Honda Accord (2003-2007) Maintenance and Repair
1106107109111112117
  • elroy5elroy5 Member Posts: 3,735
    No. 30 (7.5A) fuse in the under-dash fuse box is for both power mirrors.
  • chucko3chucko3 Member Posts: 793
    Unless the car burns oil, one can check the oil level to see if it goes down.
    I have been lucky with Hondas, no oil burning until the car got over 150K miles.
    With 92K miles, my 03EXV6 still keeps the oil at full mark level at every oil change.
    Knock on wood.
    Have an appt to have the timing belt package done this Wed.
    Will see how the old belt looks after 92K miles/8 yrs+1month.
  • ezshift5ezshift5 Member Posts: 858
    .........your take on the old timing belt will be interesting. The interference engine (well, we all know the consequences inherent here)
    Are you also replacing other parts? Water pump, tensioner pulleys et al.........
    best, ez
    Water pump, all belts, and seals. That's all.
    Time for a new battery on the I4 Accord. Forget the pathetic 51r - it is too small and did not last very long. I will probably put in the 35 from the V-6, but has anybody tried a 24 from the Odyssey?
    It also looks like a 56 should fit, but they seem to be harder to find.
    I am OK with light modification.
    I don't need a monster battery, but it gets real cold here and I do a lot of 1 mile trips with the lights on and the deffoger going - death to batteries when it is near zero out. It also looks like most of the better batteries are not even available in the 51r size.
  • chuck1919chuck1919 Member Posts: 176
    I have read that if you go with a bigger battery, one of the cables need to be changed because it won't reach. I believe it's the positive one, but do a google search.
  • mrbill1957mrbill1957 Member Posts: 823
    My original battery died in my 04-I4. I installed a larger battery from another car but to make it fit I just left out the plastic battery enclosure. There is plenty of room and the battery cables were no problem.
    Not knowing why Honda uses the plastic enclosure (heat?) I decided to install an Optima battery and reinstall the enclosure. They can handle my abuse of leaving the car sit for months at a time.
    Mrbill
    Reposting this message. Somehow the previous one got deleted when Edmund changed its look.
    The timing belt was replaced. It still looks good. No signs of crack. Could go another 10K miles.
    Two cam seals & front crank seal, water pump, and accessory belt were replaced.
    The auto tensioner was also replaced because it started leaking. This is a known problem for 2002 Accord V6.
    Replaced the group 54 battery with the group 35 from the V-6. This should help with the weak reserve capacity of the stock battery. Also I couldn't find any premium batteries in the 54 size. I wound up with an Everstart Max from wal-mart. Well rated by Consumers Reports and should do fine.
    I did have to take out the battery box so the new battery would fit. Will probably buy the box for the V-6 and install that. Or I might get something aftermarket that helps keep the heat off better. Heat is what kills batteries and it gets over 100 way too often in SD (hit 121 in the shade 2 years ago). I may get something silver to reflect the engine heat away.
    My word (had no idea that SD logs temperatures of 120F plus). My perception is the opposite extreme (but then perhaps North D colors my perception).
    Season's best from foggy Northern CA, ez sends..................
  • srizvi1srizvi1 Member Posts: 263
    Regarding the coolant, unless I'm mistaken, w/ the 2004 Accord i4, per the manual you had to do the coolant at 120k miles and then every 60k miles. Why do it earlier? I'm not sure about my family's other Hondas ('07 CR-V AWD and '07 Accord EX i4) but I thought they were something aroudn the same. They use the maintenance minder thing so usually I use the edmunds maintenance guide to figure out where I should be and what I should be doing.
    http://townhall-talk.edmunds.com/direct/view/.efdf924/5486#MSG5486
    Thanks for starting the discussion on the battery. A couple months back My wife's '07 Accord i4 battery had died over the weekend and needed to be jumped. It's been feeling weaker on start so I'm thinking about replacing it. The car's at around 41k miles now and was bought new in September '07. I think it's outside any warranty window now. In June, when the car was at 33,611 miles and less than 3 years old, I had the battery tested from the dealer as part of a package I had done w/ oil change and other inspections. They reported it good (rating 410 CCA, 12.90V 477CCA) so at that time, I think if they had noticed something it could have been done under warranty.
    I'd of course like the get the best battery I can for her car. I'm wonder if I'm still the same group 54 as you in my '07 i4 and could go the same route you did. I'm nervous about anything too complicated since I'm not very familiar w/ car battery replacement. So when you say "take out the battery box," is that something I can do? How much is a replacement box from the V-6 that you're planning to get? or aftermarket?
    If you think doing what you did is not for the faint of heart, what's the easiest/best way to go? In my old 2004 i4 Accord (which is now my sister's), I think I put in a battery from sears many years back and as far as I know it's still in there. I guess it's doing ok, I'm not really sure. I'll post details on that later
  • michael2595michael2595 Member Posts: 72
    As some of you know the rotors on that car are made of tissue.... turned them twice and are now pulsing... Back rotors are fine.. I am changing the fronts and not with Honda rotors.. Do I also need to change the back rotors.. People tell me in this situation it would not be good to use OEM rotors
    Any suggestions as to what type of rotors, or anyhting else I should do would be deeply appreciated.. Never expected this from Honda .. I may have 18k miles on it.
  • tallman1tallman1 Member Posts: 1,874
    Are you sure it's an 07? I've read the stories about the current generation (08-present) but the previous generation was pretty solid. My 06 (identical to the 07) is well over 80k on the original brakes and rotors. No tissue here. ;)
  • genericaccountgenericaccount Member Posts: 8
    i like that car
    edited December 2010
    97k on my original brakes and rotors. The rear are about half worn and the front about a third.
    having said that they do have a very slight pulse that shows up sometimes if you are braking extremely lightly as you coast to a stop you can just feel the brakes grab and release a little as the tires rotate. I know better than to fix this since cutting the rotors will just make them thinner and they will be much worse after a few weeks. No reputable shop should have turned them twice and expected them to get better. New rotors are the answer.
    I actually just went through this on my wife's Sienna as well. She wanted (not needed) new front brakes at about 92k. The shop said it would be fine to turn them I said I just wanted pads don't turn. They gave me some gobbldegook about safety and said they had to turn them. Sure enough they warped within a week after they were turned even though they had absolutely no pulsing before the brake job.
    They replaced the rotors with some generic brand (I just paid the difference for the new rotors) and they are fine again.
    As far as changing the battery goes it is simple. All you need is a 10 mm wrench. Undo the terminals to the battery and the two nuts on the battery hold down (4 10 mm nuts total). Remove the hold down and remove the battery. The plastic cover for the battery is in two pieces. The top piece will come out with the battery as it is just sitting on top of the battery. The bottom piece is then just sitting on a steel plate and can just be lifted out.
    If you want the simplest procedure possible to install the new battery do what I did (since it was 5 degrees and I didn't want to mess around too long). Just place the battery on the steel shelf and bolt it down with the original hold down. You will need to bend one small tab on the hold down to make it fit better.
    I will install the hold down from the V-6 (about 3 bucks) for a perfect fit as the I4 hold down does not contact perfectly (still plenty good to hold the battery, but not ideal). You can either leave the battery naked or buy new upper and lower covers from Honda. The lower is about $25 and the upper is about $15. The covers help protect the battery from engine heat and maybe keep it a little warmer in the winter (you could argue they protect it from engine heat then as well).
    Being a cheapskate I will probably cut the lower cover to fit the new battery and then buy the upper cover.
    The battery I wound up with was an Everstart Max from walmart as it was well rated by Cr and wal mart is everywhere and always open if I have a problem. The Bosch batteries that pep-boys sells and the duralast (top model) from autozone (I think) were also top rated as was the diehard gold (more expensive).. This is for a group 35 battery.
    Also - I made a mistake about the original size it is a 51r not a 54. Part of the problem with the 51 is that it is so thin that nobody makes their premium batteries in that size.
    I was a little disapointed that my original only lasted 3.5 years (it gave me problems last year at 2.5 years, but I nursed it through the winter) as my Integra original battery lasted over 7 years under the same conditions.
    One other note. Some battery gurus feel the Johnson Controls versions of the Everstart Max are better than those made by Exide. Walmart carries both.
  • propwash49propwash49 Member Posts: 38
    Make sure if you are going with a group 51 battery that you know if you need a 51 or a 51r. This happened to me a few years ago. (I'm pretty sure that the sizes involved were 51 and 51r, but it might have been a different group size.) They are exactly the same size, but the terminals are reversed on the 51r with respect to the 51. You have to know which one you need so that your cables will fit on the proper terminal of the battery.
  • imidazol97imidazol97 Member Posts: 27,132
    The Everstart MAXX from Walmart that I had put in my Buick had a 9 year warranty and only lasted about 7.5 years. Walmart prorated the replacement! Actually, I was impressed. That battery lasted longer than any battery I ever had before.
    I searched for a Johnson Controls battery for my replacement in my newer car. Walmart didn't make the battery for my car. Advance Auto parts had a battery that was vented for use in my car under the seat--by Johnson Controls.
    thanks for the breakdown. suggestions on where to buy the hold down, upper, and lower covers? dealer?
    I am sure.. I paid the bill for it. its a 2007.. drove the 2008.. couldnt stand it.. they has a few 2007;s on the lot.. we bought one.
    So I have been pretty busy and its been a while since I've been on here. The '07 Accord EX has had some trials and tribulations mostly beyond its control, but the issue that has been driving me nuts is the squeaking and squawking when it goes from fall to winter (i.e. it gets cold).
    I bought the blessed shin-itsu grease stuff, for $14 online, reportedly straight from Mr. Honda's eh :sick: something. I cleaned all the weather stripping around the doors and windows and then treated all of the rubber with the grease. While I still think this is one of the most ridiculous automotive maintenance tasks I've ever had to perform, it did do the trick and the commute is much quieter. Now its just the dash rattles.
    Oh and as far as some other threads, 50k and I haven't replaced tires or brakes (except fluid) but its all highway driving.
    I am at a point, with the car almost paid for, where I am trying to decide: do I want to modify it to make it enjoyable or just start over with something else and payments?
  • tom017tom017 Member Posts: 16
    Has anyone experienced this...?
    We have a 2005 Accord LX 4 cylinder automatic with just under 30,000 miles. My wife drives it on short local trips. The car is very well maintained.
    The car sits out at night (no garage). We live in a cold climate and the overnight temperature is near zero and single digits.
    We've noticed when it gets colder outside, the car takes longer and longer to crank over to start (6 or 8 cranks). It takes quite a few seconds to crank over, then the engine feels like it's slamming as it does start. We put a new battery in it last year because the battery was 4 years old and we felt there wasn't enough cold cranking amps to keep up the extended cranking when it gets cold. We have the new battery in it and it still takes a long time to crank. We also had the oil changed last month, too. The car runs, drives, and shifts fine after it starts.
    I have a newer 2008 CR-V with the same 4-banger engine. It sits outside too next to the Accord, and it starts (slowly) in about 2 or 3 cranks in zero weather and doesn't slam when it starts. Both cars get gasoline from the same station.
    Does anybody have any ideas why it takes so long for the Accord to start when it's cold? When the car heats up or the outside temperature warms up, the car starts perfectly fine.
  • robgraverobgrave Member Posts: 65
    Only 17000 miles on my 2006 EX-4cyl, and I'm already on my second battery (the first was something of a lemon, as I judged it). Even now, however, cold weather starting isn't as good as I would like.
    Rather than keep it cranking in the first try, I've found that a quick release of the key after 2 or 3 cranks, then waiting 5-10 seconds before trying again, works very well. On the second attempt, it starts up in an instant. So far, at least, this seems to be the best way to deal with a battery which frankly isn't as powerful as it ought to be, regardless of age. It's the biggest shortcoming of an otherwise well-equipped vehicle, in my view.
    The slamming, which only occurs infrequently with me, is annoying, even more so because I really don't understand it. Someone else in the forum can perhaps enlighten us.
    Not sure what the slamming is - never had it happen.
    I did read in the owners manual that it cranks longer because of emissions. My accord always cranks a few times before it starts, even in the summer and even when the battery is full of juice and can crank forever. My Integra would start almost instantly.
    It doesn't seem to be a battery issue.
    Both the Accord and the CR-V crank a few times before they start in all weather (hot or cold). Both of them crank the engine very slowly. I've heard other Hondas start and they're slow too.
    I'm just concerned that there's something going on with the fuel delivery in the Accord causing it not to turn over until after about 6 or 8 or 10 cranks. In sub-zero weather, there won't be enough battery (even a new battery) left to keep cranking it that long.
    Once the Accord has been driven or the outside temperature rises above single digits, the car starts perfectly fine every time. Figure that one out!!
    Try to prime the fuel pump and wait a couple seconds before cranking the engine when the temp is cold.
  • fixitdaddy1fixitdaddy1 Member Posts: 14
    Suggestions: full synthetic oil, engine warming blanket (to make it easier to start) & keep oil from thickening or congealing"); hotter plugs to create a spark, for easier starting; the 2 to 5 seconds of cranking, leaving the key ignition energized to help the electric fuel pump crank gas, to reach the carburetor or fuel injectors! All great ideas, to lessen resistance for the cold battery, and circulate oil, a little easier. Hope this helps & Merry Christmas, Happy New Year!! :) ">
  • stickguystickguy Member Posts: 50,435
    my 2005 (4 cyl, stick) has always been a sluggish starter. even when it is warm out, it doesn't sound happy about firing up. And when it is cold, it sounds like cross your finger time.
    and even last year after I got a new battery, it was still pretty sluggish. Always fired up eventually, but not a warm and fuzzy wait.
    one thing that I found (at walmart) was that they didn't carry a higher output battery in that size, so it is about the same 450CCA rating as the pitiful OEM.
    I also have an Odyssey and Acura TL that fire up immediately (especially the TL) and sound much more energetic. They also both have higher capacity (750ish) ratings.
    That is why I upgraded to the group 35 battery from the v-6. 640 CCA and a 9 year warranty (pro rated of course).
    The car still cranks a few times like it does in the summer, but they are faster cranks and the car never seems like it won't start.
    Interesting story about batteries. When Nissan first started bringing cars to the US they wondered why they were getting so many complaints about dead batteries. Turns out in Japan everybody would put a blanket over the car at night to keep it warm. In the US nobody did that so bigger batteries were needed.
    I even bought the new battery from the dealer and this is what was specified for the car.
    I'm afraid to put too much more CCA's. Years ago, a trusted mechanic told me if you put a much higher CCA rating battery in the car, you may be replacing the starter within the year.
    I think the mechanic's theory is more fanciful than based on fact. Starter motors are used for very short bursts and can take enormous abuse because of that. Besides, 12V is still 12V, no matter what the CCA's.
  • blufz1blufz1 Member Posts: 2,045
    My NTB battery croaked within 2 years. Replaced at the Honda Dealer. Dealer tests battery w/every oil change and caught it. I believe the Honda battery warranty on my new battery is 8 years with a 3 year free replacement. Good luck with it. Happy Holidaze to all.
    Car will turn over more easily with synthetic oil. Use the oem spec weight synthetic 5-20? or 0-20 if permissible. Hope this helps.
    Interesting re the window strip grease,think I'll try it. Less pressure in the tires or a softer riding tire might "fix" the dash rattle. Best,financially, to keep the car,if you think it's a good unit. You have already taken the depreciation:Why start the depreciation all over,again?
  • jonahdogjonahdog Member Posts: 28
    Have to share my battery experience. My wife also drives an 07 accord. About 2 mos ago the car was dead in the am so I charged the battery. It lasted the day and was dead the next am. Took to the local advance auto, they tested the electrical, said the battery was fine but the alternator was suspect. (They were running a battery special and I purchased one but did not have it installed). Took car to Honda for same tests. Was told the diagnostic would only be @ 15 min but ended up taking over an hour!!! And on top of that, they found....nothing wrong with the alternator, but, wait for it....it needed a new battery and of course since I was there and already invested an hour of labor, purchased the Honda 100 month battery at a total cost including the labor, of just over twice what the advance battery was costing. Here's where it gets really good. My wife drove her car home and parked in the garage. Later that night I went down to check on her car and noticed the interior dome light on... Of course I checked the doors (all shut) and then found the ceiling dome light switched on. I changed it to the auto off position. (Interesting Honda didn't notice)
    Seems our granddaughter is at the "push button / flip switch" age.
    In summary:
    1. Advance said I had good battery but alternator was bad
    2. Honda said alternator was ok, but battery was bad
    3. Battery was probably fine all the time
    My only consolation is that the battery was approaching its useful life anyway and better to have it changed before the cold weather arrived.
    Live and learn...
    I did all the seals on the doors and on the frame where the door closes, as well as the window tracks (the windows are much faster now). Hopefully that will help the longevity of the window motors, since all the window motors on my '93 Accord failed between 5 and 7 years (not terrible, but on my '96 FORD Contour they never failed).
    Yeah, I think it was always the wrong car for me to buy. Its a size to big and not very interesting to drive. The upside is 32 mpg on my commute, and it holds a child seat in the center rear position and allows the use of the two outside seats by normal people.
    I am weighing that against the modifications I would like to make the car more palatable to me, knowing the expense of those modifications and their affect on resale value. Firmer suspension and lower profile, firmer tires (and wheels) offsets a lot of the savings. And would likely make whatever loose rattle issues I have now considerably worse.
    My battery experience was much less dramatic. Pulled into the Honda express oil change facility. Honda does free checks with the oil change and discovered the NTB battery was below good. Sold me the Honda battery for $113. Took the NTB battery back and got a full refund from NTB. I prefer to deal with fewer vs. more vendors. 3 year free replacement on the Honda battery,the $99 NTB battery was gone in less than 2 years.
    I would not go beyond higher performance tires on the oem rims,but,then, I'm an unexciting person. .02.
    Well, if you have the 17" wheels, that is relatively easy, but since I have the 16" wheels coupled with 205/60 tires, I am SOL there. I have been keeping my eye out for a stock sport or aftermarket 17" wheel that will let me run 215/50R17s which have a lot more options. There are several Honda/Acura wheels that will work, and a billion aftermarket ones.
    Some of the spring manufacturers make a "mild drop" spring that only lowers the car about 1" so it should still do well enough in snow. Coupled with some sport oriented shocks, that should give a much more connected feel. The Acura TL has thicker sway bars and that is an easy afternoon upgrade for the rear, somewhat more involved in the front since you must drop the sub-frame.
    If I can get H/A 17" wheels and TL sway bars, that would make the shocks and springs the only non-oem parts.
    Pay small;Lose small.
  • dolfan1dolfan1 Member Posts: 218
    Hope I'm in the correct forum. My 07 SE V6 is approaching 37K miles riding on the original factory tires. I'm guessing they'll need replaced at around 40K. Should I replace them with the same tires or would some other tire work better? (I live if Florida)
    ....replaced OEM Michelin HX MXM4 215/50-17 with same size Mich Primacy MXV4 about 25,000 miles back. I join the Tire Rack folks in their high ratings of this somewhat pricey tire.
    I understand - in addition to a $70 VISA card bonus - that Costco also factors in here on decent pricing................
    season's best, ez....
    I usually buy the bridgestone Potenzas but have also bought Falken tires and quite inexpensive due to the fact tht very little goes to marketing like Michellin does.. How much of the cost of the michelin tire is related to marketing.. I bet a major portion.. Wont ever buy Micheleins again after I bought pilotsl. Never really owned them , just rented them, they blew up so many times and of vourse they were the sidewalls
    If I were putting 10,000+ miles on my tires each year, I'd probably avoid paying the Michelin premium and go with Bridgestones, or whatever. But in fact, I drive much less than that, and it is the overall life-expectancy of the tire that matters to me most of all.
    Perhaps I'm wrong about this, but the Michelin tire seems to hold up better in time (because of a softer rubber, maybe?), which makes it a better tire to have at say 6 yrs/20,000 miles. At least, that's how my thinking goes right now.
    The more tire-savvy experts here may disagree, of course. As always, I'm more than willing to listen and learn.
    EDIT: Michael2595 got his post in before mine, and I gather he doesn't find that Michelins hold up so well. My own experience is different (with previous cars), so there it is: no definitive conclusion. And it may very well be true that you're just paying extra for the name when you buy Michelin. I just like to think that I'm good at not wasting money.
  • hondalovahondalova Member Posts: 189
    I agree with robgrave...I have a 2004 Accord V-6 EX-L 6 spd. and have always used the OEM tires (michelins). Every set I've had has lasted close to 50,000 miles (I have 157k miiles on the car and it still looks/runs great w/original clutch, starter, alternator, radiator, etc.).
    In all fairness, I would note that I put two Blizzaks on the front wheels from November thry March each winter (4 wheel snowtire freaks please don't yell at me - I've heard it all - we can agree to disagree b/c I've been doing it for 30 years w/o a problem), so that prolongs the Michelin's life somewhat, and they do tend to get noisier as they get older, but I've found them to be great all around tires with good traction and puncture avoidance, right up until shortly before I decided to swap 'em out for ones. I have never had a flat.
    I've also had Michelin Pilots in the past (used 'em on my old '99 Maxima GXE) and found them to be a vast improvement over the original Bridgestone Potenzas that came with that car.
    To a large extent, once you've vetted objective quality, the rest is really subjective t/b/d by the individual driver.
    Happy tire hunting!
    -FS :shades:
    Those of us who purchased 06 Accords got either Michelins or Bridgestones. I got the latter and couldn't be happier. Most of the Michelin people from that year had to replace them early. Mine still have good tread left at 88k. They aren't Potenzas though.
  • wise1wise1 Member Posts: 91
    So what were they? My 07 SE isn't ready for tires yet but I'm open to suggestions. Thanks, Happy motoring! ;)
    the OEM michelins on my 2005 were not very good. by 40K, tread was low, and they had gotten progressively worse in wet weather (not good to start with, by mid-30s they were almost dangerous). My 2005 Odyssey only got 30K out of those michelins.
    both were replaced with Yokohamas that have performed very well, and are lasting much longer (especially on the van, already more on the replacements and they are only 1/2 worn).
    For the Accord, the Yokohama Avid H/V4 is a good option (what I have). Not the best for snow though from the tests at tirerack, but if you live in Fla, not an issue!
    I also put BF Goodrich Advantage TAs on my 2000 Acura Tl (same size as the Accord). fantastic deal from BJs (with a coupon), and they have done a good job in the 2K we have on them. Even did great in snow up in Syracuse according to my son.
  • temj12temj12 Member Posts: 450
    What brand of tires do you have? I have an '05 that had as original equipment, Bridgestone Turanza tires. I replaced them at 75,000 miles, but they would easily have gone 90,000. I am just surprised that you were only able to get this many miles on your tires.
