If you have a PTU and the smell is related to your PTU, it is most likely leaking fluid through a seal or has been overfilled. Either condition should be failry easy to fix and likely under warranty.
Naturally, but you were offered good advice. People tend to ignore messages written in ALL CAPS because they are hard to read. It's not a matter of etiquette policing but rather someone trying to be helpful.
SUVs and Smart Shopper
Has anyone sat in one?
I need to set the passenger side at 60 degrees so it blows cold air not cool air. Is this normal?
My wife's lincoln MKS gets cold at 72 degrees, the temp blowing in on hers is 60 degrees until it hits desired temp of 72?
help
The only way I found is to set the temps at 60, this maintains a high fan speed and cold air pumping out,
then when the vehicle is cool I change the temp to 68, the air is no longer cold but cool, It never gets to 68, I was in texas for a while last year and yes you do need the air conditioner.
My MKX does not cool down, dealer states that if the air inside the vehicle is 80 degrees or less the fan will not max or kick to high in automatic mode thereby the vehicle will take a long long time to cool down if set to 68 degrees and even longer if set to 70 or 72.. Can anyone confirm this to be true? I know the fixes but for a $50,000 vehicle should a fix be necessary? Dealer states the same unit is in all the dual climate control Lincolns.
yes I am ticked, I am using this forum to get responses if anyone else has this issue. dealer states this is the way it is engineered, I find that hard to believe.
anyone know how I can get the attention of Llincoln headquarters??
when I e-mailed and called ford I was patronized and offered an oil change.
The filter is behind the glove box.
On a separate note, we just love the look of the MKX. Our car is black with a black grill and we took the liberty of installing aftermarket ground effects and a new set of black and silver alloy wheels (24"). Everybody stops us and asks us about the car. The younger crowd especially. Who says Lincolns are for the old folks. :-)
And no, you shouldn't have to set it on 60 - it should work on 70 also. There must be something wrong.
http://www.myfordfreestyle.com/forums/viewtopic.php?f=9&t=3758
I don't know if MKX and Freestyle have the same AC system.
...or mountainous areas and will provide a limited amount of grade
assist features automatically.
