BTW.. I was trying to do it before but dont yet have all the specs. I believe the new XLE V6 will be more powerful and have more features ( for certain ) and nearly the same room ( TBD ) as the 2000 XLS Avalon... at $3000 to $3500 less money!! Impressive.
Maybe I'll trade the Prius in July on my birthday. Nahh, I'll just max it out in 5 yrs and get then Gen7 Camry with Hybrid tech.
A car that big getting 43mpg? It looks like a cross between a Lexus and the new Maxima.
I'm going to buy one! Toyota destroys the competition again!
I think since the
Honda Civic Hybrid is the HCH
that the
Toyota Camry Hybrid should be referred to as the TCH
Anyone disagree? Let's make it the TCH and keep it consistent, agreed ...???.... :shades:
Just look at how Prius doesn't compete directly with Camry-Hybrid. Toyota clearly hasn't positioned the design configuration to overlap, as some people have eluded.
JOHN
I agree with you that it is the prophet but I think that every time Toyota introduces new Hybrid technology in future - they are probably working on the 3rd or maybe 4th generation as I write this - it will always start with the Prius and make it's way to the other models. I have been told by the powers to be at Toyota that the Hybrid option will be less than $1000 by 2010 and offered on every model they make. The Prius helps them achive that with it's volume.
Just curious but will the TCH that will be offered during spring be from Japan?
If I am not mistaken are "Made in Japan" Camrys different from the US made Camrys ? Especially in terms of dimensions(Japanese Camrys are smaller) and different interior designs.
I didnt mean to imply that the Prius was done after this model. Another iteration certainly seems likely but the Camry always is the heart of the product line and IMO the emphasis will be there.
I also own an MR2 which as you know was allowed to retire until a later date.
On the one hand, it seems like the 2007 model should still be based on the existing 2002-2006 model. On the other hand, I've heard it's based on a new "global platform" from which the 2006 Avalon came.
Anyone know which one of these is right?
There was a perception at one time that the Camry's made in Japan were 'better'. I think that's been put to bed by now. Smaller no.. unless you were joshing..
Does that mean the new Camry shares its platform with the 06 Avalon? I am not sure?
Gasoline Engine Type 2.4-liter, 4-cylinder, aluminum alloy block with aluminum alloy head Bore and Stroke 3.48 x 3.78 inches
Displacement 2,362 cc Expansion Ratio 12.5:1
Valve Train Twin-cam, 4-valve/cylinder with VVT-i Horsepower (SAE Net)* 147 horsepower @ 6,000 rpm
Torque* 138 lb-ft @ 4,400 rpm Recommended Fuel Regular unleaded
Emission Control AT-PZEV ELECTRIC MOTOR/GENERATOR/POWER STORAGE
Motor Type Permanent Magnet Synchronous Motor Electric Motor Power Output 105 kW/4,500 RPM
Torque 199 lb.-ft. @ 0-1,500 RPM Battery Type Nickel-Metal Hydride (150 lbs)
Nominal Voltage 244.8 V (204 cells, 1.2V/cells) Transmission Electronic Controlled Continuously variable transmission
Capacity 6.5 ampere hour Battery Peak Horsepower Rating 45 horsepower
System Voltage 650 volts maximum COMBINED
Hybrid System Net Horsepower 192 horsepower * The Society of Automotive Engineers revised Standard J1349, which sets forth the protocol for testing horsepower and torque as of January, 2005. The revision specifies that certain equipment be installed on the engine and operating at the time of testing, as well as the use of the manufacturer required grade of fuel during the test. Presumably, all manufacturers will be using the revised Standard for future tests. Toyota decided to retest most of its engines using the new protocol this year. Consequently, the horsepower and torque ratings for many of our vehicles declined this year. Any changes in horsepower and torque ratings based on the implementation of the new testing protocol, however, have no impact on actual engine performance.
2007 TOYOTA
CAMRY HYBRID PRELIMINARY SPECIFICATIONS SUSPENSION
Front Independent MacPherson strut suspension with stabilizer bar Rear Independent dual-link with stabilizer bar
BRAKES
Type Electronically Controlled Brake system (ECB) Front Ventilated front disc (hydraulic with power assist) with standard Anti-Lock Brake (ABS) system and integrated regenerative brake system Front Diameter 11.65 inches Rear Solid disc (hydraulic with power assist) with standard Anti-lock Brake System (ABS) and integrated regenerative brake system Rear Diameter 11.06 inches Parking Foot pedal type
STEERING
Type Electric power-assist rack-and-pinion Turning circle 36.1feet (11 meters)
TIRES AND WHEELS
Wheel size 6.5 x 16 inches Type and Material Aluminum alloy
Tire Size P215/60 R16 Tire Type All-season
Spare Temporary CAPACITIES
Fuel Tank 17.1 gallons
2007 TOYOTA
CAMRY HYBRID PRELIMINARY SPECIFICATIONS EXTERIOR DIMENSIONS (inches)
Wheelbase 109.3 Overall Length 189.2
Overall Width 71.7 Overall Height 57.5
Tread Width (front/rear) 62.0/61.6 Minimum Ground Clearance 5.9
Coefficient of Drag 0.27 INTERIOR DIMENSIONS (inches)
Headroom (front/rear) 38.8/37.8 Legroom (front/rear) 41.6/38.3
Shoulder Room (front/rear) 57.8/56.7 Hip Room (front/rear) 54.6/53.9
EPA Passenger Volume 101.4 cubic feet EPA ESTIMATED FUEL ECONOMY* (mpg)
City/highway/combined 43/37/40 *Actual mileage may vary VEHICLE MASS (lbs)
Curb Weight 3,637
2007 TOYOTA
CAMRY HYBRID PRELIMINARY SPECIFICATIONS SAFETY AND SECURITY FEATURES
Driver and front passenger advanced airbags Front and rear side curtain airbags, driver and front passenger seat-mounted side airbags and driver’s knee airbag
Side-impact door beams Three-point seatbelts for all seating positions, Emergency Locking Retractors (ELR) on driver’s belt, Automatic/Emergency Locking Retractors (ALR/ELR) on all passenger seatbelts; three-point front seatbelts with adjustable shoulder anchors Anti-lock Brake System (ABS) and Electronic Brake-force Distribution (EBD) Vehicle Dynamic Integrated Management (VDIM) Child protector rear door locks ISOFIX CRS top tether anchor brackets and ISOFIX CRS anchor attachments Daytime running lights BASIC LIMITED WARRANTY COVERAGE
3-year/36,000-mile Comprehensive 5-year/60,000-mile Powertrain
5-year/unlimited-mileage Corrosion Perforation 8-year/100,000-mile Hybrid-related Component Coverage
15-year/150,000-mile Hybrid-related Component Coverage (applicable states are: CA, MA, NY, NJ, VT, CT, ME, NH and RI) with the exception of the hybrid battery. The hybrid battery is warranted for 10 years/150,000 miles.
•P215/60 R16 tires with 16-inch alloy wheels
•Temporary spare tire
•Tire pressure monitor system
•Halogen headlamps with auto on/off feature
•Daytime running lights
•Smart Entry with push button start
•Dual color-keyed power outside mirrors
• Heated outside mirrors
•Eight-way power driver seat and four-way manual passenger seat
•Power door locks with anti-lockout feature
•Power windows with driver’s auto-down
• Optitron meters
•Fabric seat and door trim
•Premium AM/FM/six-disc CD changer MP3/WMA compatible with
Bluetooth™ with eight speakers, 440 watts
•Auto-dimming electrochromic rearview mirror with compass
• Homelink®
•Dual zone climate control air conditioner with air filter (electric)
•Leather wrapped steering wheel and shift knob
• Cruise control
•Tilt steering wheel with audio/Bluetooth™/climate control
•Manual telescopic steering wheel
• Courtesy lamp
• Maintenance indicator
•Driver and front passenger advanced airbags
•Seat-mounted side airbags
•Side curtain airbags
•Driver’s knee airbag
•Anti-lock Braking System (ABS)
•Vehicle Dynamics Integrated Management (VDIM)
•Rear center headrests
• Engine immobilizer
•Chrome exhaust tip
•Rear disc brake (regenerative)
• Cargo net
•Audio auxiliary jack
• Multi-informational display
•60/40 split fold-down rear seat
" John is as fully aware of the raison d'etre for the Prius as anyone. He was one of the first and a good source of information since before the '04's launched. "
You are right, now that I think about it, I did learn a lot of Prius information from John1701A in the Prius 2004+ forum. John cleared up a lot of my misunderstndings
A couple of examples:
In message #2701, I learned that instead of dusk sensing autolights the Prius had updated thier auto lights to a simplier off/on switch. I had always thought before that that was auto-off and not automatic lights. But John cleared up my misunderstanding.
In message #3830, I learned that the Prius did not have either transmission or gears. Instead of gears the Prius has a power-split-device. Before I had incorrectly thought that a transmssion was used to connect the power of the engine to the turning motion of wheels through gears (plantary in the case of the Prius). But John cleared up my misunderstanding.
The Prius was a good car, but the replacement TCH (Toyota Camry Hybrid) will be much better.
Cheers,
MidCow
the TCH and the Prius can coexist quite well as long as the third generation Prius is differentiated with new technologies(as I believe the Prius 3 of the future will become a "new technology show case car" for Toyota).
MPG focused customers may end up buying the hybrid Corolla/Matrix in future years instead of the Prius, especially if the hybrid Corolla is significantly cheaper than the Prius.
Despite the future hybrid Corolla affect on Prius sales, I do believe many will still stick to a Prius for its cool geeky image(pardon the oxymoron).
http://www.toyota.com/
TMV for a package # 8 Prius in San Diego is $31,366. I cannot imagine a fully loaded Camry Hybrid for less.
I'd guess an XLE trim TCH will be ~ $31000
Price gouging and waiting lists for hybrids is a non-issue at least here in Canada since there are not as many hybrid tax incentives here as in the USA.
That means late Spring/Early summer instead of Fall 2006 which Toyota is telling the world.
Is something brewing that will make the TCH available earlier than expected?
If they "really" price the non-NAV version of the TCH at around $26K, I might do that instead of paying $22K for a 2007 HCH like my original plan was.
Hopefully Toyota will consider people who want the car for $26K but cannot afford (or refuse to pay) $30K for it.
By October, Convis said the plant will begin manufacturing the Camry hybrid in Georgetown, where the company plans to build 12,000 a month.
http://news.cincypost.com/apps/pbcs.dll/article?AID=/20060121/BIZ/601210314/1001-
The TCH will be made in Japan until Tennessee production kicks in sometime late 2006. I was told the new TCH models will have new colours.
If the audio is integrated with the video display, then forget it.
http://www.nascar.com/2006/news/headlines/cup/01/23/toyota.cup/index.html
I can only get 33 with my Accord on the highway so I am asking the tooth-fairy for another 15 miles per gallon like Excel gets.
YMMV,
MidCow
Actually it's the
PZEV based I4. The TCH will be good for maybe 50 lmpg for someone that wants high FE That someone would not be you given your poor FE driving habits
Good Luck
Wayne R. Gerdes
Must you always be so condesending about other's FE (Fuel Economy). You emphasis my poor FE drving habits, but I get equal or better than the EPA estimates.
You therefore are condesending and insulting to almost all Edmund's forum members because they do not or cannot obtain the extemely high miles per gallon you achieve.
That is great that you can achieve such high FE, but other drivers do not and cannot achieve that high of FE. That is no reason to insult me and other Edmunds forum members.
YMMV,
MidCow
203 foot pounds of Torque in the TCH - Nice !!! :shades:
The result is a combined 192 hp (143 kW) from the hybrid system with 275 Nm of torque, with estimated fuel economy for the hybrid of 43 mpg US city, 37 mpg US highway (40 mpg US combined).
PS
the formula is NM*.7376=FtLbs
I guess the battery is a bit too intrusinve to allow fold down rear seats. That's a shame.
The following is from the www.treehugger.com site:
Both '07 automatics include a manual shift gate. The Hybrid teams a special 2.4-liter 4-cyl gas engine with a battery-powered electric motor for 192 net hp. It teams with a continuously variable automatic transmission (CVT) providing near-infinite drive ratios. Like Toyota's smaller Prius hybrid, Camry's automatically drives on either or both power sources, depending on conditions, and requires no plug-in charging. Antilock 4-wheel disc brakes are standard for all models. So are front torso side airbags, head-protecting curtain side airbags, and, for the first time, a driver's knee airbag.
The Hybrid adds antiskid/traction control that's available for other models. SEs come with 17-inch wheels, the other models with 16s. SEs also have a firmer suspension, and specific trim inside and out. The Hybrid also has unique interior and exterior trim. A split folding rear seat is standard except on SE and Hybrid, which have a fixed seat with center pass-through. Leather upholstery is included on the V6 XLE, available for the 4-cyl XLE and the SE. A navigation system with CD changer and wireless cell-phone link is optional for SE and XLE, as are heated seats. A new-to-Camry keyless-entry/starting system is included on Hybrid and available for V6 XLE.
It is interesting to note that the automatic transmissions are now 5 and 6 speeds (except for the hybrid which gets a continuously variable transmission, like the Prius). Until recently, most automatics had fewer gears than manual transmissions, but trying to achieve higher fuel economy has pushed automakers to add extra gears.
Also, it seems that - if this information is reliable - Toyota has decided to position the Camry hybrid between the 4 cylinders and V6 versions when it comes to power (158hp for the 4-cyl, 192hp for the hybrid and 268hp for the V6). The thinking probably is that a good portion of mainstream buyers will consider the extra power a good reason to pay a bit more for the gas-electric drivetrain.
In fact, since the current generation's Camry has a V6 that generates at most 210hp, the next generation hybrid's 192hp can almost be sold as: "V6 power, better than 4-cylinder gas mileage.
The specs for the hybrid on pressroom.toyota.com indicate that the hybrid WILL have a folding rear seat. But if this photo of the hybrid is accurate, the folding seat won't be of much value, because the pass-through is blocked by the battery.
I'll be seeing it myself at the auto show in two weeks. I hope the battery lowers into the trunk floor.
toyolla2, "Advanced Course in Hybrid Engineering" #115, 24 Jan 2006 7:50 pm
It looks like Toyota is maybe rethinking its battery direction.
One has to wonder why? maybe there is trouble lurking as more and more Prius batteries come toward the end of their warranty life?
YMMV,
MidCow
P.S.- The 2007 Camry Hybrid looks to be an outstanding auto !!
Maybe I overlooked it :confuse:
link title
Is there any preliminary information on available options or option packages?
