I have also checked out Warranty Gold (good prices)but am concerned if the company were to go out of business, I'd be out of luck.
The drive shaft was replaced last week, but it did not fix the problem, there is still vibration during acceleration over 45mph.
"ford extended warranty extracare",
you'll find many other sources for OEM Ford extended warranties. When I searched 3 years ago, there was only one dealer doing it.
Beyond the dealer in Iowa I used at:
http://www.fordwarrantycentral.com/
Hunt Ford in Maryland. 30% off suggested retail.
http://www.fordwarranty.com/
Broadway Ford Truck Sales in St. Louis at:
http://www.fordesp.com/
A classic! Bubba Oustalet Ford in Louisiana will give you a quote via email.
http://www.oustaletford.com/Pages/esp/pricequote.html
Many others, too.
These are all Ford dealers trying to make a few bucks off the internet. I'd imagine that since you're using a credit card to buy the warranty, there's zero risk in using any of them so you can shop strictly based on price. Internet search engines are a wonderful thing.
I'm confident this is wind and not road, tire or engine noise. I've verified all windows and doors are shut. The noise only appears above 50mph and is constant now. I was thinking molding around the windows was coming apart or something, but everything appears to be intact.
Anyone else have this issue come up? Solutions? I want to have some ideas before I get to the dealer. Based on past experiences, the dealer usually either says No problem found or they claim it was something and that doesn't fix the trouble.
I know I had a wistle type wind noise from another vehicle I own, and the dealer ended up replacing the rubber molding around the front windshield--it fixed the problem completely.
Thanks for any advice.
I have to replace the mirror assembly on the passenger side of my 97 Explorer SOHC.
I've ordered and received a salvaged part, and now I realize I have to take apart the door to install the new mirror.
I can go to the library or bookstore and get a Haynes or Chilton manual, but I don't seem to find the time to do so. Is anyone aware of instructions on how to replace a mirror assembly being available on-line?
You can get information of how to work on your car online at
http://www.alldatadiy.com/
You can buy a supscription for about $20, and it will give you all the information for just about anything you need to do.
If you want to buy it locally, some dealers are willing to negotiate, I found one near by that would match the price, but they still had to charge me sales tax, which I didn't have to pay on the out of state transaction at fordwarranty.com
Also decided against the WarrantyGold after hearing from a friend that just went with them and didn't have a good first experience. He had some problems getting WG to call the shop back in time to give approval to get it done the same day and ended up having to rent a car. The rental ended up being covered, but the headaches of having to keep calling the dealer and WG just wasn't worth the price difference.
Thanks for all the links, saved me big bucks.
maybe somebody has gone through the same situation, my explorer 95 automatic transmission downshifts suddenly when I am driving it, for example if I reached the 3rd gear, suddenly downshifts to 2nd gear causing a huge shock in the car and a increase in RPM, usually does not happen when the car is cool but after driving a while and the car temperature increases it starts downshifting and shaking the car due to the sudden change, also the O/D light in the board starts blinking. I have already taken to the shop and they "repaired" the transmission but still has the same problem , other people checked the solenoids but did not find anyone damaged. Does anybody have any idea why is this happening ?
I'm looking for some advice. The transmission on our 93 XLT 4WD just went out. It's got around 80000 miles. We've been quoted $1800 to fix it. Would it be worth it to fix it or can we expect some other big ticket repairs soon? Ordinarily we would just replace it, but we just replaced our other car last month. I don't like the thought of two car payments. Thanks for any help.
Sounds that it may be a problem with the computer controls to the transmission, cause the computer tell the solenoids when to shift.
To mj2468:
I've had 3 Explorers, a 91, a 93 and a 97. The 91 to 95 transmissions behind the V6 engines are known to be weak, it takes exceptional care to make one last 155,000 miles like my 93 did. Since these are problematic transmissions I recommend serviceing and changing transmission fluid an filter more often than the factory recommendation, do it every year, AND be sure to pour in a bottle of LUCAS TRANSMISSION FIX every time you service the transmision, and also when you have a transmission problem, or when you need to add fluid.
If you buy another Explorer, be sure to buy one with the V8 Transmission, it runs much better and the transmission is much stronger and will give you much better service.
Good Luck
Big AL in Sunny Florida
Gee. I pounded the snot out of my 1992 Navajo (2dr Exploder) and never had issues with the transmission in 145,000 miles. I can't remember ever changing transmission fluid though maybe it got done once. The drivetrain problem I remember with that car was the front electric hubs. I've had far more drivetrain problems (pretty much all moving parts from the front transfer case outwards have failed) with my 1998 V8 AWD Mountaineer.
At what mileage did you start having problems?
I have a 93 V6 2 WD have had to put one auto transmission in at 155,000 miles.
I have a 97 V8 2 WD with original transmision at 105,000 miles.
The A4LD's have a know history of problems, you may get lucky and have one last over 130,000 miles, but most fail before 100,000 miles. I have know of many people with these transmission who have had trouble with them.
You can have trouble with ANY of them, or you could get lucky with ANY of them, but they all still produce an overall history rating. I've worked on many of them and on a scale of 1 to 10, I would give the A4LD transmission an overall rating of about 4 or 5, and the AODE or 4R70W behind the V8 about an overall rating of 8 or 9.
I was rather surprised by your post, about the 96 Explorer steering feeling "squirrely". I've got a 97 Explorer, and the steering feels so nice, stable and steady compared to the 91 and 93 Explorers that I've had. The older ones had the I-Beam front suspension with the radius arms and bushings, and the newer ones, I think it started in 95, have the upper and lower swing arm suspension with the rack and pinion steering. I really love driving the 97 Explorer with the rack and pinion steering because it is so steady and comfortable. Mine is anything BUT squirrely.
Ray
For answers to your mechanical problems, try the BAT AUTO website:
http://www.batauto.com/
I can't speak specifically for the 5R55E, as my experience has been with the earlier A4LD's, but there are many similarities between them. In the A4LD, the power enters the overdrive unit first, then passes through to the rest of the gears. I had an experience that the 1991 transmission started making bits of material clinging to the magnet, then after a while I had a sudden failure that left me stranded on the side of the road (fortunately near my house)at about 140K. The overdrive unit has an overrunning clutch that suddenly failed and would not hold, therefore power would not go through the transmission. It turned out that the overrunning clutch had been slowly wearing as evidenced by the scoring on the overunning clutch race.
Being that yours has high milage, it may last a while yet, but could fail at any time. I would begin making plans to prepare for it's demise, which is sure, and possibly swift.
What I did was go out and look for a good deal on a good used transmission, which I found a 1993, and put the good used 1993 transmission on the shelf for when I needed it. Sure enough, one year later I needed it and put the 1993 transmission in the 1991 Explorer. It paid off for me. I then rebuilt that 1991 transmission, put it on the shelf, and then put it in the 1993 Explorer when it failed at 155K (lost overdrive, but kept going until it blew a seal), and now it's running great to this day.
One big lesson I learned about the ninties Explorers is to keep a spare transmission on hand!
Good Luck,
On start up with a cold engine, the revs seem to be around 700-750 rpms (normal) regardless to how long I idle and rev the engine. After I drive it and the engine warms up, the idle will seem to stick at higher rpms; anywhere from 500 to 700 more than it should be. I have noticed it happens in the foward gears as well as Neutral and Reverse. Also, after the over rev condition has happened and I restart the vehicle (engine still warm) the revs jump up to 2000 then settle to 1200 again over reving now in idle. When the engine is cold the over rev condition just doesn't occur.
Unfortunately, I will be bringing it in to the dealership tomorow. If anyone can give an idea of what the heck is wrong I would greatly appreciate it.
marcjlc
The topic is Side Doors -- Wind Noises.
a small C shows up next to track number
but CD won't play.
Rear Window Wiper won't operate but
washer fluid does and fuses are ok.
Didn't want to start just ripping
apart back door and get suprised
by hidden flanges breaking, etc
any help,
Mike
> pound the snot out of it. I have not had any problems with it so far.
> I live next to the beach and take it on the dunes rather frequently
> and take it off road in the snow a couple times a winter. With only 54k on
> the truck, it might be a little early for problems to surface.
The car was relatively trouble-free until it hit 75-80,000 miles. Then, it started living in the dealer until virtually all moving parts in the front end got replaced. I'm very glad I had an extended warranty. I went out and bought a VW GTI to commute with last August and the Mountaineer now has 97,500 miles on it without further problems. It's headed into the dealer to get the power door locks and rear wiper fixed before it goes off-warranty.
I have a 98 XLT (60,000 miles) and had the LED display quit on the AM-FM-Cass-single cd player. My local dealer quoted $580 for a new replacement or $280 to repair. I found a used unit for $245 but was concerned that it could fail as well. Ended up buying a new Alpine unit instead.
I've heard that the display failure I experienced is quite common. Is that true?
Two weeks after ownership the wiper is not working again. What gives?
Anybody please.
2) the wiper motors in back have been an issue. try lifting the rear wiper out of the cradle and letting it dangle.. this is the "service position." if it works now, or after you go around the block once, you probably have a reset switch issue. I'm still under warranty, so have not fiddled with it myself, but I bet a slight realignment of the motor would fix many of these cases (the switch for end of travel is not being reached before the arm hits the cradle.) lazy man's way is to reposition the wiper arm by a remove and reinstall.
it may have done that, and it may not have, but pinging is generally carbon buildup on the valve heads or the piston tops.
a little pinging is not the end of the world... run a few fillups without any non-gas items in the tank, and see if it goes away. if not, run a two-cycle Techron treatment as recommended on the bottle for clean-up.
if that doesn't do it, it may be time to have the injectors and cylinders cleaned with one of the on-car cleaner kits from 3M or Wynns. they replace the fuel line, so it's mechanic time.
these things are at the header to pipe flanges, and possibly also at the converter to pipe flanges.
there is a little flex in the exhaust system, so it's wear and tear... but it's also safety, if you're still under warranty have the dealer look at it. you might get away with tightening the bolts at that section of the exhaust system as well, but by now it will take half a gallon of penetrating oil before (assuming) any of the nuts will move.
Also going to have them look at the engine pinging, I ran through a whole tank of gas, and did some highway trips (20-30 miles) this weekend to blow it out, but no improvement. I'll let you all know.
Any feedback would be appreciated, Thanks
below the eject on the CD only Radio unit.
It's labeled COMP -- apparently this
is some undocumented feature. Anyways,
some CDs don't like it when in COMP mode
and will not play -- Press the COMP
button again, little C disappears
and CD plays ---
enough to drive you crazy.....
M.
-Rob
As for the engine noise, they gave me a copy of a service bulletin acknowledging what Ford calls engine "marble" in the 4.0 OHV put in Ranger and Explorer from '98-2000. It reports that the noise is common while at idle or while under minimal load (<2000 RPM). They say there is nothing to do to fix it, and that it is a "characteristic" of the engine (so I guess now Ford designs engines to sound like that!) Anyhow, the dealer said it is running "to spec" and that there was nothing to be done.
also, if your engine "lifts" to the right enough to be really interesting when you rev it with the hood up, you could have a bad motor mount, which would have caused the extra play in the exhaust which allowed the gaskets to whistle. "really interesting" is not a technical term, but there will be a limit measurement in the service manual. ask them to perform the mount tests.
2) so, a light rolling ping is a "marble" now, huh? glad they found a word for it. an occasional ping now and again is just an annoyance. if it's regular and steady and has an edge to it, then it can be causing damage, and it needs to be worked on.
not really sure what the complaint is. like, is it, "I'm in overdrive at 75 mph and I punch the throttle, the car sags but then jumps like I bit it, and when I get past the truck and let up it kinda wallows around and zips around and finally gets back to the 75 I was driving on the cruise control?"
if so, that sounds rather normal. cruise kinda coasts when you let off the pedal and drift back towards the set point, falls under it a couple miles per hour, and then punches its own pedal until it gets to the setpoint again.
the low idle could be something else, like maybe a sour plug or wire or two, with the computer riching up the other cylinders so the car doesn't die.
but the idle issues should come out if you have the engine scoped on the tuneup diagnostic set of charts.
got a big crowd of serious wrenches here, if you have more detail, they can probably hit it right away for you
I just installed an external filter in my 97 Explorer using a Summit TRD-1028 ($12.75) that was just on the shelf collecting dust. Having an external filter also makes a transmission flush an easy and clean if you use the Summit spin on filter bypass adaptor TRD-1013 ($9.95) connected to a drain hose. I have mounted the filter with a dog leg "L" bracket on the outside rail just behind the bumper. So forward is it that the filter is within 1/4 inch of the bumper bolt. This makes for very low visibility and the filter was sprayed black to further conceal it. Filter is installed between the radiator and the external cooler. Remember that fluids flow faster when they are warmer and those of you in colder climates should place the filter before the radiator. I am using a standard PL3001 oil filter. Don't forget the filter has a check valve, so don't inatall it backwards. Many filters can be easily opened for examination by using a good quality kitchen can opener. Just get your own because it is hard on the cutting wheel.
An alternative to this mounting hassle is to use the inline XL30 from SPX filters which also has internal magnets. Technicals can be seen on bryco.com. The filter can be ordered on bulkparts.com for about $15 plus shipping. I also get my pan filters for my A4LD and 5R55E from this site. Part number 23921 fits both and is the glass fiber media type from SPX/FILTRAN made in the US. In the A4LD application, this has double the filter area of the original. At $10.35, this is half the price of the Taiwan ones from Autozone.
