goodyear "gatorback" belts are also supposed to stay put and not squeal.
the sound of silence is great, especially since i got it fixed just before a 900 mile trip.
I realize it's no Lexus, but even my 2002 Volkswagen Beetle had an almost instant warm up, a temp control that could be set even hotter than almost anyone could tolerate for an extended period (but enjoy for those first few minutes on a bitter day). Why the suckie heated seats on my top-o-the-line $40,000 Mountaineer Premier? Yeah, I already know the answer.
I had an 01 Jetta with heated seats, things only worked on the hottest setting, so it was either burn the butt or shut them off. Dealer always said that was normal.
On my Navigator, you have heated AND Air Conditioned seats, with temperature controls. They still turn off after 20 minutes, and you have to restart them.
Does anyone have the part number for the part for the above problem? 98 ford explorer or the cost for these parts?
www.yourcovers.com
it is possible that the remaining +12 wire to the power distributor block could have a squirrelly contact. but that is shielded from road spray, salt, sand, crud, and corruption to large extent by the power distributor block.
the ground wire or the battery are the most likely culprits. round 'em up and interrogate them. one tap of a small screwdriver placed between the connector and either the battery or the block, which will upset a little metal and break through any corrosion in several spots, is a useful first test. mind you, don't swing that sledge like you mean business when tapping the battery post, or you are going to need a shower real fast to get the acid off.
After 4 years, I have no real complaints about the truck, except for the door rattle that several dealers have tried to fix. My rotors are about spent, seems like rotors should last more than 40,000 mi. Anybody have any suggestions for good replacement rotors?
rotors are not lifetime, machine 'em each set of pads, parts any more. on most cars they are so darn thin you can read through 'em. be glad you got 40K out of 'em, and didn't warp 'em like potato chips first time you had to slam both feet on the brake pedal.
OEM explorer rotors seem plenty tough, but there should be heavy-duty ones from the usual sources (raybestos, wagner, and autolite/bendix.) site unseen, and unmiked, those are the only sources I'd trust.
"look6phd" - see if you can find a dealer willing to go to bat for you for an after warranty claim. Good luck!
If your objective is an inexpensive car and you need the space, I would consider a used station wagon like the Taurus. If not, you can get a good used mid size sedan for the same price. And 4WD is over rated esp. for a vehicle the size of the Explorer, Tahoes etc. And if you don't o off road, then it's just one more thing that can go wrong.
You can get around better in the snow (less then 6 inches but then again why would anyone in their right mind drive around in deeper snow then this)with a front wheel drive vehicle and decent tires.
Therefore I am strongly considering a Ford warranty. I have shopped around and have gotten my local dealer down from $1600+ on a 100,000 6 year warranty to $1215, which they claim is their cost plus $50. (It is the Ford Extra care, which online also is quoted at over $1600)That is my lowest quote from 4 Ford Dealers.
My question is this...is this a good deal?
I've had numerous little things go wrong and frankly I don't expect the Explorer to go to 100,000 miles without some sort of major meltdown.
Thanks for the imput.
Mike
I don't think she buy an Explorer or any other SUV not unless there is some over lying factor that determines she must have 4WD.
mseenviro: I normally don't recommend extended warranties since the odds are agianst you that you will recoup your money (how else would they stay in business). But in this case it seems like you will rest easier if you have one. Just make sure you buy a Ford backed extended warranty. A lot of peopel ahve been having problems with third party warranties recently. Check out the warranty page here on Edmunds to see some nightmare stories of companies denying claims or declaring bankruptcy.
M
Ok in terms warmth @ the Maxium setting.
I am certain the Anti-Freeze mix is 50-50.
Does anyone else with a Ford Explorer 4x4 XLT (1998) have this problem?
Also I heard the U-Hall People will not rent trailer(s) to be towed with the
Explorer(Any Explorer),but will for the Mountainer(SP). What do you
guys/girls think............?
Best of the New Year to All......
washijl@auburn.edu
as for the U-Hell issue, read a few posts back, the short version is U-Haul runs a lean ship and they don't like unnecessary complications or costs. couple lawyers for folks injured/killed by => KILLER TIRES! <= tm also included U-Haul in some suits, and they don't wanna play no more.
Another issue that I am having is a rapid bumping sound (cannot really be felt inside) coming from the front end. The lower ball joints have been replaced, so I know it isn't them.
ALL of these things, save for the groaning, showed up after my wife called me asking me how to ge the truck out of 4WD Lo!!! Wouldn't be a big deal but she was on a DRY paved road. She said that it was in 4WD Hi because the road was snow covered, but the snow lifted and the roads dried out so she "in haste" shifted it into 4WD Lo, and not back to Auto 4WD. So here I am trying to figure out what the heck to do. It used to be so tight, now it sounds like a bucket of bolts. BTW, the 4WD still works fine.
Any others with imput, your thoughts are greatly appreciated. Thanks!
Bought '03 Explorer in August of '03. On the way home from dealership, it started humming between 55 and 65 MPH.
Trip to dealship #1 - "We fixed it!" 10 miles later, hum was back.
Trip to dealership #2 - "We fixed it!" 15 miles later hum was back.
Trip to dealership #3 - "We fixed it!" 20 miles later, you know.
Trip to dealship #4 - "We know what the problem is and we do not have a fix and we will not try to fix your car." Turns out there's a known issue related to the balance of the driveshaft.
Trip to attorney #1. Long story short, in NC the lemmon law goes like this...
-FMC gets 3 chances to fix issue through SOP
-FMC get certified letter and has 15 days to schedule "Last chance to fix".
-If it gets fixed, every one goes home.
-If not, customer's choice money back or new vehicle
Ford never contacted me during the 15 days they had to schedule the last chance fix. Corporate also failed to return my calls and I had two dealships play ignorant. Additionally I was told I had to go through the arbitration/resolution board. Hogwash.
I have tried to give Ford my allegiance over the years purchasing two Rangers and then the Explorer. All brand new. Each vehicle failed to meet my quality expectations and service was always strict adherence to mileage guidelines and almost adversarial. (They refused to straighten the bed on my ranger because mileage was > 12K miles and cosmetic fixes had to be performed before 12K miles.)
The Explorer will go back to Ford via buyback according to NC statutes next week.
I got home ...Next morning on way to work it was making the worst whining noise ..
I perfect harmony with the RPMs...
Then started slipping when moving thru the gears...
Very bad...I took it to FOrd the next day.
Just got call from local Ford shop , and they say I need a new trans....
they will order one on monday...
Truck is 1 yr old and only 9,100 miles.
ANy others with similar problems...
This is my 2nd Mnteer, and I also had 2 explorers...
First major problem for me......
