Horsepower to Weight Ratio
With so many people reluctant to buy a vehicle that uses more gas than the next guy, but is afraid of ending up with a slug that may get rear ended entering a 55+ MPH highway we need a standard. I would like to suggest 10:1 ratio of weight in pounds to horsepower. Easy to figure out. If your car weighs 3200 pounds you should have 320 horsepower. The mustang GT almost hits it and the GTO exceeds it, but as we all know GTs are overpriced and the GTO is a major gas hog (gas guzzler tax). The solution is to build lighter cars. A 150 HP engine would save gas and still have enough power to climb a hill with the A/C on if the car it pushes weighs 1500 pounds. How? Plastics and carbon fibre, tubular frames and air bags. Are they safe? You bet. That's how race cars are built. When buying your next vehicle look at the HP to weight ratio. If you come up with 16:1 you can count on it being a real dud. 9:1 and you can not only keep up in traffic, you'll be just plain fast. Ideas?
So perhaps the early adopters are more likely to be performance cars and even then you may have more emphasis on lightweight wheels and unsprung weight, aluminum blocks etc. Expensive items but maybe not as expensive to fabricate as exotic body and frame parts?
It'd be fun to post some other hp to weight ratios. As near as I can figure, the Smart comes in around 10:1 for its 50 bhp powertrain.
Also weight affects handling, braking, etc. so while you may be very "fast" at 10:1, you may also have to work very hard on anything but a straight road. (e.g. Viper).
What other factors do you have to look at? Coefficient of drag? How the weight is distributed or the front/rear bias?
Take a hypothetical 9000rpm engine with a flat torque curve of 100 ft-lbs. And another engine, 6000rpm redline with 150 ft-lbs of flat torque curve.
If you gear both of them so that the top of second gear is the same speed (usually 62mph), the high-revving one will have its torque multiplied 1.5 times more than the other one. So the wheels on both cars will experience the same torque per rev, thanks to the gearing.
But the high-revver will output more revs before they get to 60mph, so it'll actually reach 60mph faster. It's not totally intuitive to me... I might be wrong, so correct me if you see a mistake in there.
This reminds me of those word problems I couldn't do in school - if one guy leaves NYC driving a 9000 rpm engine and another guy leaves LA driving a 6000 redline engine, who will reach the steak house in Kansas City first?
I'll have to rely on a seat of the pants guess when the equations start flying.
Of course the case is so hypothetical as to be nearly meaningless in real world applicability.
Horsepower to Weight Ratios
Model weight HP lbs/hp price
1999 Dodge Viper 3,380 450 7.51 $80,000
2001 Corvette Z06 3,115 385 8.09 $48,055
2000 Porsche Turbo 3,400 415 8.19 $118,000
2000 Ferrari 360 Modena 3,241 395 8.21 $179,000
1999 Porsche GT3 2,975 360 8.26 N/A
1995 Corvette ZR-1 3,535 405 8.73 $65,000
1999 Corvette C5 Coupe 3,250 345 9.42 $37,171
2000 Porsche Boxster S 2,855 250 11.4 $54,303
2000 Audi TT 2,655 225 11.8 $36,000
2000 BMW M Roadster 2,899 240 12.1 $43,743
www.dpcars.net
Made in the U.S.A :Portland Oregon.
Just takes some doing by the person purchasing the car, its not for everyone, but people who have the will to drive something very different can find legal ways to do it... they also assume all the risks associated with it and most do, thats why it is possible but difficult.
I personally know people who have built kits and imported cars with a much lower build quality that the DP1 that have had zero problems getting the car thru the local DMV.
It all depends on how bad someone wants to do it. I see no problem with it as long as people know what they are doing....
Forbes
Many a Lotus elise made it into the U.S. with not a second look by DMV. Along with another 20 or so specialty cars.... IE: Ariel Atom, Seven, Westfield, Different TVR's... Etc,
No matter, my vision and reflexes wouldn't do any of these supercars justice. :sick:
Randy
Now if you're wondering then how does that work out with the equation of HP = Tq * RPM / 5252, you have to measure the RPM where you measure the torque. So the HP works out because RPM is not the engine rpm, but rather the wheels (or equivalently dyno rollers).
I think a good way to think of torque is the ability gain HP faster.
As an extreme example, try putting an F1 engine in a Hummer.. yes, the (peak) hp/weight fiqure will improve a great deal, but I bet it'll actually be slower in most cases! We can talk about the subject of torque, but we can omit the term "torque" entirely to simplify things and simply speak of HP, but now include RPMs.
So to truely determine the potential performance from hp/weight figures, we need to also consider hp/weight across all RPMs. But if we were to settle on "single" figure that's indicative of such across the board performance, perhaps *average* HP / weight would be it. Popular Hotrodding magazine for exmaple, scores participants' engines based on average HP in their annual EngineMasters contest.
Going back to the F1 example, it reminds me of a Motortrend article I read a few years ago where the author had his first experience driving an Forumla car. He stated that it was like learning how to drive a manual tranny all over again.. because clutching in at 4000+ rpms, still stalls the car!! Although I guess that's to be expected because that was close to where his car idled. I've read of more recent cars idling even higher..
Another example is Edmunds' own review of the Subie WRX wagon with automatic tranny: http://www.edmunds.com/insideline/do/Drives/Followup/articleId=48462
Accelerating right off idle resulted in 0-60 of 8.7 seconds. Brake launching at 3000 rpms, spooling the turbos up results in a 0-60 of 6.7 seconds. I should say though that the performance of turbocharged cars are even harder to model because not only does HP vary by RPM, but there is a transient effect varying HP at the same point of waiting for the turbos to spool up, if not already.
Another in similar vien was a C&D comparison of various cars. The S2000 faired significantly worse doing 5-60 (high 8's) than 0-60 (slipping the clutch in at nearly 5000 rpm; 6.1 if I recall). And again, I think we can predict or model these outcomes if we look at power delivery instead of only peak output.
1999 Corvette
2001 Corvette
I am missing something here Subygt?????????
You compare these cars to a 2007.
It is 2006 and they are selling 2007 Corvettes!
I agree that the weight to horsepower ratio does mean something but why are you talking about ancient history??? But your comparisons are meaningless. Why don't you compare a 2007 Porsche to a 1958 Corvette? That would be a real valid comparison wouldn't it!
The 2007 Corvette coupes and convertibles and the 2007 ZO6 are all street legal cars that are great sports cars!
It is pretty obvious that you don't own any of the 3!
