Chevy S10 - GMC S15 and Sonoma Steering questions
I have a 96 GMC sonoma four pot auto, the problem is the steering is very stiff, when I go round a curve and let go of the wheel it doesn't move back to center. I have replaced everything from the steering box to the wheels...could this be a steering box problem (it is ajusted right, done by the garage), or could it be the power steering, like having air in it or old fluid? (no leaks of strange noises and seems to be ok)
I'm running of of things to look for (and money).
Eddie.
ps the truck only has 78,000 on it.
Eddie.
Harry
The ball joints and all steering componants from the steering box to the trackrod ends have been changed. the only things that haven't been changed are the steering box and power steering pump.
With the steering centered, hold the adjuster while loosening the lock nut.
Try to turn the adjuster one flat of the nut (1/6th turn) looser then back. It uses a 3/16 allen wrench.
If it turns easily that is not the problem.
If it turns real hard, turn the steering wheel a full turn right or left, and try the screw again.
If it turns easily now, the "garage" tightened it too much.
The recommended procedure for adjustment calls for disconntecting steering linkage and turning the input of the gear with an inch pound torque wrench. No one I know does that.
A practical way to adjust it to a satifactory setting is to:
1. Loosen the lock nut.
2. Turn the steering wheel one turn from steering centered.
3. Back off the screw gently until it starts to feel slight resistance, or three turn, whichever comes first. Not more than three full turns!
4. Start the engine, turn the wheel to center then rock the steering wheel clockwise and counter clockwise so that the top center moves from 10:00 oclock to 2:00 oclock three or four times. Stop engine with the wheel centered. A few drops of P/S fluid will have leaked around the screw.
Gently tighten the screw until you just begin to feel resistance change. Then back off 1 flat.
5. Tighten the lock nut while holding the adjuster then test drive the truck. If it does not feel "right", try loosening one flat more. If it gets better try again, if it gets worse, tighten one flat.
This should make the adjustment as close to correct as can be done without removing the gear and adjusting it on the bench with a torque wrench.
If excessive force is required at any step of this procedure, stop, and take it to a professional that specializes in front ends.
Harry
Could this all be due to a bad pump, or is there other stuff that could do this?
HELP!
Jake
I took it to an auto shop several years ago where they tightened something which made my steering much better. I think is was my steering column but I'm not 100% sure. So it seems that something needs to be tightened again.
Any suggestions on what could need tightening or further inspection?
THE pivot pin tool. use your tool to take out the two pivot pins. they come out easy with the tool. at this point, re-attach the pivot lever and pull it to where the shaft goes down, this will allow the main chunk of the upper steering column to come off so you can access the four pivot bolts. the rack gear will come out to and is alittle tricky to get back once your ready to install, but is very possible just take alittle manuevering. anyways you also need an internal torx socket to tighten these bolts which you can also pick up, but its like ten bucks. i would definitly use lock tight on the bolts so you don't have to do this again. i had manual steering on my truck so those bolts got a good workout everyday. anyways once you got them tight just repeat your steps in reverse. its not that bad just take your time and make sure you get your steering bearings properly back in place. once you get it all back. i had to heat up the front bearing race so it would go back onto the shaft so the bearings were tight. i probably didnt explain all this perfectly, but if you have any more question just ask.
Having been through the back-forth thing too many times with the repair facility I was wondering if I can remove / adjust the steering shaft to get the wheel back to perfect on-center as it was before. I looked in my service manual and it seems the intermediate shaft can be removed, removing the pinch bolt but there aren't any definite instructions / illustrations on how to do it. If I'm not mistaken, there should be a flat on the intermediate shaft that this pinch bolt, when installed, rest against in order for the shaft to be "locked" into position correct? Where is is pinch-bolt? I'm not really thrilled about the alternative of removing the steering wheel / air-bag assembly to set the wheel straight. Does anyone here have any suggestions on how to accomplish this? It's more of an annoyance than anything.
any help would be most appreciated.
