Toyota Tacoma Tires and Wheels
Also, which is a better tire to go with, BF Gooodrich AT or the Firestone Dueler (is the Dueler Revo better than the regular Dueler, what's the difference)?
Any input is greatly appreciated as I don't want to make a dumb purchase I'll regret later.
Around 30,000 miles, I noticed abnormal wear on the outer part of the tires. A tire dealer told me (for a $20 alignment check) it needed to be shimmied up so wear wouldn't occur on the outside of the tires (even though their alignment system said it was in range of good alignment). Decided to take it to a Toyota dealer. Took it to a Toyota dealer and had it aligned for $90 - even though the print out said it was only off 0.02 on the front (which I suspect it was within factory alignment and didn't need aligned but they didn't offer an alignment check - was told once it's entered into the computer you get an aligment (end of story) but that's another post I suppose.
Now, at the next oil change (asked for rotation also) the tires are abnormally wearing on the inside of the tires. The oil change company asked if I had bad suspension or something and said at 35psi my tires shouldn't be wearing like this on the sides since that's more pressure than Toyota recommends for the tires (something like 26 and 28 psi).
What puzzles me is that I've been running them at 35psi for a while and suspect they should be wearing on the middle of the tires if anywhere.
I'm at 37,000 miles and will buy new tires soon, but I wonder if this truck has a problem and will just chew up the edges of the new tires I have installed.
Only have 5000 miles on it and put Mitchlin tires on it when I bought it.
Had it aligned 5 times, 2 at the dealer and 3 at a Hunter alignment shop.
All said its in specks.
Stuck on what to do next, thanks for the info on the valve.
Does yours wander on the freeway????
Anyways, I'll be replacing the tires soon. I may go with the Continental 80,000 mile tires at the big W______ box store and see how they do. They cost just a little more than the Goodyear 50,000 mile tires. Anyone here put Continental tires on their Taco - Continental tires have a good reputation (don't they or do they not?). p.s. 99% of the time my truck is on asphault.
Is there anyway I can fix this? I was think about having a 1 1/2" lift kit (coil spring spacers ) installed on the front to lift the wheel well away from the front tires. Will this work and are there any better or cheaper options other than getting new tires?
I want to purchase a second set of rims with tires for road use only, to suit my TRD O/Road D/Cab. The original factory 16's run M/T tires for my off-road work and don't want to blow them out with excessive highway use.
Does anyone know somebody that is running 20" or 22" wheels? What width rim and tyre sizes are good without clearance problems? (with lift-kits and/or without)
EG; I'd like to run either 285/40R22's on 22x9's or 285/50R20's on 20x9's. Not sure of the offset needed to achieve either combinations. I look forward to any assistance. Cheers. :confuse:
Any ideas on how I can delete the warning light?
Mick
mickster144@yahoo.com
Mick
Also, will tires keep or would they dry-rot?... Any input would be appreciated!!
I would vote for the Firestone tire given the choice between these two !
tomrbuk
I've owned the truck since new and typically I get around 20mpg or safely drive around 300 miles to the tank, now I'm lucky if I get 260 miles per tank. I'm hoping as the tires wear my gas mileage will improve.
I have an 08 Taco double cab and my mileage goes from 21MPG down to 18MPG every winter. My mechanic says that Toyota's in general use more fuel in the winter (fuel / air ratio) So it might not be your tires or it might be a combination of the 2.
any suggestions will help, Like good ride, hopefully longer tire wear, no use 4 off road stuff
dliming
hehehe...
toodles..
