Is this the beginning of more woes?
Just replaced the mass air flow sensor-$287.00 due to K & N filter oil element fouling the sensor. K & N does not respond to my message, and my mechanic tells me there is a FORD bulletin that does not advise K & N for this reason.
Your reply much appreciated!
I'm able to hear it with the AC on or off.
Any idea what this is?
Joe
I've heard a lot of things about oiled air filters in MAF-controlled cars, most of it bad.
I think that the leak in the header allows cold air to enter back into the engine causing the diesel sounds.
Check Exhaust manifold and all exhaust in front of the catalic converter
If you have any questions e-mail me at ruppy70@hotmail.com
Don't waste your money on the other crap non of thoes things should cause your engine to make a disel sound.
Also, last snow storm, I noticed a flourescent yellow fluid on the snow when I moved it to shovel. It was on the snow where the rear end was. Anyone know what that might be?
It started to o/heat which became the transfer hose from water pump to thermostat, all fixed. Yesterday all good then suddenly after being parked started up and felt like running on 3 cyl. Usual checks found an excess of water from tail pipe, but none in oil, removed plugs and three from the left side all sooted up and the others all clean. Removed inj manifold, 3 inlets clear, 3 oily and sooted up (same side as fouled plugs.) Feels like it is over choking, but have the feeling it is more sinister. Could it be a blown intake manifold gasket or electrical....Help it is hard to get advise down under. I am greatful for any ideas. By the way I have more worries, but this one is major
Another thing to check is to make sure that all of the plugs are seeing a spark.
If it is the head gaskets,and you have to replace them, you should probably also have teh heads removed and have them magnafluxed to check for cracks.
Good luck and keep us updated!
Is there anyone else that has had this problem?
When I ease up on the brake the car returns to its normal idle speed.
I have an 02 EXPL XLT 4.0 with 72k miles... I noticed the brakes were grinding pretty loud and took it into my local repair shop. They said the rotors were rusted and needed to be replaced with the brake pads on all four tires... has anyone else heard of this happening with such a new car? Everyone i've talked to thought 72k was real low for this kind of repair, please email me at: c.kidd1@comcast.net Thanks!
Thank you sooo much aubrnjohn...after changing too many parts myself, I finally found the (your) answer.
How about an easy one...is the pcv valve on '98 sohc v6 hidden under all that plastic (airbox-ventilator-fuel mixer-whateveritis)on top of the engine? can't see it and haynes manual doesn't show it.
my '91 navajo has it in plain view.
My '91 navajo(explorer sport) has 360k miles, a true champ and easy to work on...my '98 explorer has 122k and is a chump.
Please keep the discussion here so everyone will benefit from the exchange. To do otherwise defeats the purpose of a message board.
And, welcome to edmunds.com!
Your golden retriever is leaking???
In my opinion, it sounds like a crock.
$300 labor to replace a differential cover?...that alone tells me that they're trying to pull a fast one on you.
Besides that, I have never heard of this "new" differential cover.
I removed the rocker cover and then turned over the engine and found my cam shaft is staying still. I would presume that there is a key way on the crank(as there seems to be a lot of tension still on the chain) which has sheered. My Question is this... It is on the right hand side of the car, where the timing chain is positioned against the firewall. This looks like a mongrel to fix or get too. Any tips, hints or advise? Believe me I need it.
Cheers
ouch!
Well, at least you're finding problems. There's nothing worse then doing a bunch of diagnostic work only to find nothing wrong.
You won't get true compression readings if the cam and crank are not both turning.
The timing chain has sheared but there's still tension on the chain or on the crank?
Too many scenarios to list without more info.
I used to turn my engine over by hand by using a large socket right on the crankshaft nut. It will allow you to listen and feel your engine as it rotates the crank and moves the pistons up and down.
I have a 2000 exp xlt v6 and when I put it into 4wd low once to get out of the snow, the check engine light came out. It's able to get out of 4wd low, high, and into auto fine. No apparent problems. I took it to autozone, but they couldn't read the codes. So I bought a code reader from pep boys and still couldn't read the codes. I know the code reader was fine becuase it connected to my other car and read codes. So how do I start to diagnose the issue without the obd readouts? Is there another place to plug a obd reader other than the drivers seat? And what would cause the obd port to not work?
Shawn
Here is a summary. Front right wheel bearing $950.00. Set of shocks (self leveling)$5176.00.
Replacement motor with 147,000kms $4500.00
I think they are ripping us off down here!!
Anyway, i do really enjoy my explorer (when it is going) and being a LTD with full option I cant get anything here that matches it. So it is now a labour of love. Out of interest is the Limited edition, the same as the Eddie Bauer????
We dont have them here, and I see many references to them on certain forums. Keep you posted on my progress. Cheers
The cassette on the timing chain (rear) has let go and under advisement from my Ford dealer on the Gold Coast is that the engine needs to be removed to fix it. So is it easier to remove the engine with trans still on or off. I have found another engine with 45000kms on it identical to mine for 3500k so I figure I may as well repower with a lot newer than my old one. What do you think. All the help is appreciated.
See ya from Aus....Nick
I have pulled engines out both ways (with and without tranny)and, to be honest, they both have their + and -....I have never pulled this type of engine though so I would suggest "the less you have to disconnect, the better off you are"
Taking the tranny out with the engine is easier when it comes to disconnecting the engine from the tranny because you can do it out in the open....however, you will have more fluid to drain and more things to disconnect and reconnect when you are finished. AND having the engine and tranny out at the same time can be very cumbersome.
Leaving the tranny in is a little more "elbow grease" intensive when it comes to disconnecting and reconnecting the engine to the tranny, but your area of reconnection is more focused.
Remember, double check and triple check everything.
and good luck!
I have the exact same problem happening now. I ohmed out the headlight sw after I pulled it out, and it checks out good. I jumpered around the switch and the lights worked, then put the switch back on the connector and it worked fine for a night's driving, but now quit again. I have had lots of problems with my turn signals working intermitently, and so I think the problem is most likely in the column multiswitch. I'm looking at the Chilton version of the wiring schematic and looks like the flash-to-pass (pulling back on the turnsignal lever) will work independent of the main headlight sw, but the actual dimmer sw won't (pushing forward on the lever). This is what's happening with mine.
So if the red/yel wire from the main headlight sw to the dimmer sw (multifunction sw) is disconnected or cut, the low beams and high beams won't work. I need to check to see if the red/blk wire to the fuse panel (fuses 4 &8) have power.
I notice this noise slightly all the time. There is a slight hiss, but I'm unable to determine the source. It becomes much more noticable when I change the position (accelerate or decelerate) of the gas pedal on a smooth section of hi-way. It also does the same thing when the cruise control is active. This was actually my first suspect, but it is able to maintain constant speed, so I've kinda rulled this out. The noise almost sounds like its coming from inside the car possibly on the passenger side underneath the dash, but this is mere speculation on my part. It sounds vaguely like a leaking damper that has to equalize itself once the state changes. Again, more speculation on my part.
Anyone have any clues what is causing this?
TIA,
Inet
Is there any way to get this plug wire off without ripping it out. I can touch it, but do not have the leverage needed to remove the stuck boot. It doesn't appear that there is anything capable of being removed that will allow great access. I'm assuming there must be a tool I'm missing or just some good ole tricks of the trade.
TIA,
-Inet
