The engine makes a rattling noise right before shifting into 2nd gear. It sounds like clattering valves. Higher octane doesn't help.
When slowing down to a stop it makes a hard clunk, I can't tell if it's the transmission or the driveshaft.
The transmission shifts slowly. Sometimes I think it's going to stop shifting all together.
Now the a/c system is messing up. I think the "flap" is stuck. It won't change from vent to defrost or heat.
As far as the body, the only problem is the clearcoat peeling off on the black sections around the doors and rear hatch.
Anyone else with these problems?
I opened the yellow plastic tab on the connector at the bottom of the rod, pulled the rod out of the connector, pulled it DOWN a little bit and reset it in the connector and closed the tab.
Now it is working OK. ......might only be a short term fix, but that is where the problem is. I might try to use a little spring to lift the rod if the problem returns.[Also need a new inside door handle as that was ruined in the struggle]. Oh yes ..take out the bottom left window track..it makes access much easier.
Any help would be appreciated. Has anyone experienced this, was it very expensive to fix?
Thanks again!
You can go to alldatadiy.com/ to get the information for your car, they have everything you need, cam timing and everything else, for $24 for a one year subscription.
Good Luck,
E.D. ISF
I already subscribed to alldatadiy.com and printed everything I need. I put camshaft timing into the search field and am not really turning up any information. Any hints on a better way to find it?
I found the information on how to set the timing, the only problem is, I can't find where to get the "special tools" needed to set the timing correctly. Any ideas of where I can rent/buy such tools?
I have been a ford guy from age of 16 on but with all the tranny problems I have had with all my fords at the 80K mark I am considering jumping ship. :confuse: It just seems that the ford tranny has always been the weak link.
Do yourself and your friends a favor, Bookmark this messege and send it to all your friends.
Good Luck,
E.D. ISF
40 K miles. Rebuilt transmission parts and labor is $4,200 + $ 140 for re-welding bolts. Car was in shop 900 miles ago and vehicle got excellent report as to condition on everything. 3rd gear is gone. Vehicle had normal transmission fluid level now. Also, the standard transmission service was done at 29K miles by dealer.
Another 02 XLT was in dealers shop with 68K miles, also with
transmission problems although I don't know specifics.
What's going on with this, especially at such relatively
low miles?
I've owned 4 Explorers over the last 8 years, and I will CERTAINLY not own another FORD again. My next vehicle is going to be a Honda or Toyota!
Please bookmark this messege and send it to all your friends.
E.D. ISF
blow about mine going at under 40K, the service writer
said they had an Escape with a defective transmission
come in with under 1K miles recently. I don't know if the
dealers care since they'll get paid regardless, but major
repairs like this get billed to Ford when under warranty
or to Ford ESP if under their extended service plan. Does Ford sub-contract these transmissions when originally
installed new or are they manufactured by their own plant?
My opinion is the reason Ford is hurting now is more related to the price of gas and still some residual from the rollover issues of the late 90s.
we both agree they are the best overall vehicles we have ever owned. that is meant as a compliment, not that we drove a pos prior to what we have now.
Check all this out and let us know what you find.
Good Luck,
E.D. ISF
I doesn't really matter to the owner who pays for the warrenty repairs, but they are still out of the use of their vehicles and they have all the aggravation to go through.
And what about a guy like me who buys a used vehicle 6 years old out of warrenty and plans to drive it for 6 years? He has to buy a reliable vehicle that won't break down and cost him money.
Meanwhile, the Honda and Toyota drivers are driving merrily down the road with big smiles on there faces.
Is your transmission an Automatic? You are very lucky to have 196,000 miles on it with no transmission problem, especially if it is an automatic. It is amazing to have sludge in an engine in 2,000 miles AND overheat 5 times and one day! That's pretty tough on an engine! How hot did it get each time, did it boil over? Overheating will destroy and engine quicker than anything. The post #5417 that I left for you on Sept 30 has all the information that you need. You need check and follow though on each item, it is like a flow chart, a logical process to arrive at the solution to the problem. Don't skip a step or leave anything out, make sure you cover all the bases. As I said, if you are not loosing any coolant and the system is tight and not leaking internally or externally, then the next logical step it to check the circulation of the coolant. The biggest factor there could be a clogged radiator, but you must be sure that the thermostat is opening and that the bottom hose is not collapsing when you accellerate up a hill. When engine is cold, start it up and feel the upper hose about once a minute to see when the upper hose gets hot, meaning the thermostat in opened. If you have doubts about the thermostat opening, or only partially opening, remove it and put it in a pan of cold water, set it on the stove, put thermometer in the water, and heat it up, and watch to see what temperature the thermostat opens wide open. I always test a thermostat before I put it in to be sure it works correctly. If you have doubts about the radiator, a radiator shop can flow test it for you or if you got one of those laser thermometers like I said in my previous post, you can measure the temperature of the radiator tanks and the temperature of the upper and lower hoses. The lower hose carries the coolant back to the engine and should be at least 10 degrees cooler than the upper hose. 20 degrees cooler would be better. But if there is very little difference in temperature between the upper and lower hose, that means the radiator is not transfering heat, and that is where the problem would be in that case. Either get the radiator rodded out, or replace it. Then put in a good 50%/50% mixture of antifeeze and distilled water.
Squeeze the bottom hose hard, it should not flatten, it should be stiff or have a spring inside of it to keep it from collapsing. If the hose is not hard, replace it.
And what was this you said "the oil filter was disgustin and black, and the air filter was also black. i fouind this weird because i had fuly serviced it only a few thousand miles ago", Very strange indeed. I drive mixed city and highway and I change my fully synthetic motor oil and filter every 7,500 miles and it hardly gets dirty, and I change the air filter every other oil change (15,000 miles) and it hardly gets dirty at all.
I don't know where you are driving, but it sounds like severe service, and you will need to do your services more often.
Good Luck,
E.D. ISF
Anyway, it's best to eliminate this cause right off the bat with a cooling system pressure test.
Otherwise, rapid overheating on a steep grade is generally a water circulation issue, meaning a bad radiator. Flushing is useless if the radiator is really plugged or rotted out.
~Tom
Is the replacement of an oxygen sensor a "big deal"? I know that playing with exhaust system components could lead to problems with frozen bolts, etc., but will oxygen sensors come off easily if I spray some WD40 and warm up the exhaust pipes for a minute or two? I'm looking for input to decide if I should do this myself or take the truck in to a repair shop. Also, could a dirty fuel line caused by running the fuel level down to below a 1/4 of a tank have caused this problem to develop?
Thanks in advance for the reply!!
Go to this link to learn all about the O2 sensors and how they work and how to read them:
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/0- 4/f6/02/0900823d8004f602.jsp
Replacing them is easy, use regular tools, just use common sense, tools must fit properly and some are harder to reach. Go to this link to find out all about replacing them:
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/0- 4/f5/f7/0900823d8004f5f7.jsp
Good Luck,
E.D. ISF
Keep your fingers crossed, I hope the codes don't come back.
Good Luck,
E.D. ISF
http://www.jasperengines.com/
Good Luck,
E.D. ISF (Electric Designer In Sunny Florida)
It ended up being caused by the rear wiper blade itself
being spliced into the incorrect position on the
pivoting wiper post. It was only off by a faction
of an inch. It appears that the rear wiper is very
sensitive to placement and if off by a little something
senses the incorrect position and forces the wiper to
continue operation. If the wiper is in the incorrect
position on the post it will eventually stop after about
a couple hundred wipes. Correct post positioning is
found by turning the switch off and allowing the wiper to
stop on its own and set on the resting pad provided.
Once the wiper stops pull the wiper off the post and
reposition it about a half inch from the wiper resting pad.
The wiper should operate correctly if you did this right.
If it does not attempt to reposition again with the wiper
blade slightly off the wiper resting pad until the blade operates correctly with the switch positions.
it has 114,000 miles and the maintenance is up to date
Next check and test the EGR System, refer to the repair manual for this. Remove the EGR Valve and clean out the vacuum passages.
Good Luck,
E.D. ISF
1- Airplane like noise, when demanding additional power from the engine, under medium to high engine load. It seems to be initiated by the throttle, and disappears when the load goes down.
2- Engine lacks of power when the airplane like noise appears... It happened also to my wife when driving uphill in normal city driving conditions, but I did not believe her.
3- When in flat sand, the car will not move in 4WD High... engine revs up to about 3500RPM, none of the wheels spin, feels like if the car is on "neutral", except that the engine won't rev higher than this. The only way of getting the car to move is by engaging 4WD low and... have some friends pushing!!! until reaching a downhill slope, then I can stop, switch to 4WD high and continue driving normally without being able to stop on flat ground without getting stuck by this lack of traction.
I went to the dealer... they checked "everything on the computer" and checked the "levels and pressures" in the transmission, and concluded that everything is perfectly normal with my car.
Can I have some suggestions on what the problems might be? I believe the mechanics available around here (Sultanate of Oman) require some guidance.
Other question: can I drive for long periods of time in 4WD low?
Mario :confuse: :confuse: :confuse:
