When we lived in Colorado where they have no law about covering truckloads of gravel, we had chips and small cracks repaired a number of times. Couldn't even tell they had been there. But on one occasion a crack developed from a chip that spread accross the entire windshield. The windshield was replaced, with no problems whatsoever.
Just this past February I picked up a chip on the Mass Pike. It was on the passenger side, so I went to a local place to have it repaired and wasn't satisfied at all with how it turned out. So a few days later I went to a different place -- J.N. Phillips -- and had the windshield replaced. The insurance covered both the attempted repair and the replacement with no deductible. Again no problems with leaks, at least so far.
If you do decide to replace it, I would suggest taking it into a shop rather than having someone do it in your driveway or parking lot. People have told me you get a better quality job if they do it indoors in a controlled environment. Replacing the glass itself takes only a short time, but you need to count on waiting or leaving the vehicle for a couple of hours because the adhesive has to set properly before it is safe to drive it. Any shop should be able to get an original Toyota windshield. Mine had speckled tinting behind the windshield-mounted mirror, and the new windshield is an exact match.
A Toyota 4Runner is much more of a real off road vehicle but isn't very comfortable or practicle.
I better idea would be to wait for the new Highlander, or get the excellent Honda Ridgeline. The Ridgeline can tow 5000 pounds and is really a great pick up truck because it's comfortable, and refined. Just add a bed cover and you're set.
So either a new Highlander or a Ridgeline in my opinion. But I recommend the Ridgline more
What do you think?
Why wait for the new model and pay $1,000's more, unless it's really a priority to get a new style.
A more fuel - efficient engine, reduced whiplash and better safety ratings, a quieter ride, a more comfortable ride, and better things
The new Highlander will not have worse fuel economy, and WILL be better than the previous in overall refinment, quality, and you know what I'm getting to. My point is, the new Highlander will be better, not worst.
http://www.edmunds.com/insideline/do/FVDP/Preview/styleId=100531781
That allows the use of a "learn burn" technique resulting in improved MPG. The RX350 is likely to get the new engine in the fall as is the Highlander.
What they know - Gas prices are going up, so the sales of SUVS are not the best.
THEY KNOW that fuel efficient cars are what PEOPLE WANT.
THEY HAVE a new fuel efficient engine.
*The gas mileage of a Toyota Highlander 07 will not be worse than the current one - you know that. It will be pushed up about 1 or 2mpg in the city.
[Just a suggestion if any of you are encontoring this]
a good friend of mine who's a car dealer, called me with this offer:
there is an Action these days for a 2003 HL, basic 4cyl,25k miles. He could buy it for me ( my wife actually) for $14k+ taxes.
I am not sure if it has the VSC available ( which I insist on having), but i'll find out.
WHAT ARE YOU SAYING ABOUT THIS OFFER?
My wife is insisting on buying- it's GOLD and TAN interior :confuse:
Thanks to ALL for any advice!
Dan
http://www.e85fuel.com/database/search.php
In the meantime I found out that car has no VSC ( standard on 2004 and above) and has an aftermarket sunroof installed. Not too crazy about that...
1)If I buy the 2006 Toyota Highlander, is the 4 cylinder engine powerful enough for a family of 4?
2)Is the air conditioner "limited in performance" when you have a 4 cylinder engine? One salesman told me the V6 engine will give better air conditioning performance when you are going uphill with a full load.
Any Highlander owner please advise.
From what I've read on the 4cyl. I think you'll be perfectly happy for 5 out of 7 days. For 2 days you'll take it easy. I would also recommend the 2wd with the 4cyl.
It's all relative. It's got enough power but until you drive it you won't know if it's enough for you.
Take the entire family out for a test drive. I know Toyota North and Star have larger inventories. They may be more able to accommodate test drives of the different types.
Assuming a fixed displacement "clutched" A/C compressor...
Since the I4 engine RPM will generally be higher than with a V6 the A/C in the I4 might even give better service. Excluding WOT operations where both have the A/C disabled.
If we assume a more modern variable displacement compressor system then the argument is mute on both sides.
Not made as good? LOL.....What do you base that on?
We have the 4 cyl here in Florida where we're always running the a/c, but no hills and usually it's just the wife and I. The 4 cyl is sufficient for us. But loaded down with 4 adults and in hilly areas, I'd go with the 6 cyl.
It appears that you have never tried or owned a Toyota 4cyl engine. This 4cyl has to be one of the most refined and reliable engines in the world today. Does it have the power of the 6cyl? NO. Is it smooth, quiet and strong enough for to satisfy many? You bet.
http://www.toyota.com/vehicles/future/ftsx.html
1) Does the Owners Manual recommend regular gas?
2) Are there any known problems/recalls with a 2004 FWD HL?
Any other things to test or watch out for? Thanks!
It's not a recall, but some people have complained in this forum about radio reception. Some have the in-glass antenna, and others the flex wire. I have the latter and reception is as good as in any car I have owned. But I would suggest that you check it out on a test drive and see if you get a clear signal for example with FM stations broadcasting from 30-40 miles away (as the crow flies).
Went to Bridgestone Turanza summer only tires primarily for quietness but they are more comfortable riding also.
I have recently purchased a 2006 highlander Limited (Non-Hybrid) and there is a bizzare problem with the navigation system. The navigation system will not dim into Night mode (black background) Night mode works only when the headlight switch is toggeled on and the key is turned to accessory. When I start it returns to Day mode. I read the manual and It says that Day mode will be remembered with the light in the on position if you shut the engine off if day mode is enabled. I have tried every combination of light modes and ignition combinations as well to no avail. I have even disconnected the battery. Please Help
KP
Thank you for any help!
Any luck with yours yet?
