Discovery Transmission Woes
I have a 1997 Land Rover Discovery with 69,534 miles on it. I just got it about a month ago. I was driving home and I was going up a hill and the vehicle started to rumble a little as the vehicle began to slow down. I pressed the gas a little more and the car was bucking lightly. The RPM guauge was revving really high, so I pulled over, tried to put in 4 wheel drive to help it along and nothing. I shut the vehicle off for about 1-2 minutes. Started it back up again and put it in 'drive' and it ran fine for about 2 miles and started to slow down again. I stopped for about a minute or so, started the vehicle again and it ran for another mile or so. I repeated this til I got home.
I am hoping that the transmission is still good and this is a minor problem. My gut feeling is that the torque converter has gone bad. Big Money!
I need some input on this, please!
chrisusvi
chrisusvi
Good luck!
I have been diagnosed from brakes which I replaced to transmission to trans box to no avail. Of course the dealer does not hear it, only every one else.
Any suggestions?
I've towed tons on a full car trailer... including a Disco 2 - no issues at all, other than I had to ask them to fine tune the inertia brakes because I thought they were coming on too late..
Sounds like a shift lock pin or one of the other pins and gates in the top end of the shifter. There's a lot of nylon bushes in there can can get old and crack... probably a good time to have it all redone if you have it apart.
Get yourself a good shop manual and have at 'er.
Pretty simple repair...
Try calling Rovers North for some advice or check their website for a blown up diagram... they're usually pretty good at helping you out over the phone, but you better have at least the top part of the shifter assembly apart or you'll be wasting their time.
http://www.roversnorth.com/store/c-327-levers-linkage.aspx
