I normally keep my iPod on "Shuffle All". Hence, when I play it in my car, I just need to hit the Random button twice for to randomly play my song list. If I had selected a Playlist on my iPod, it will stick to that Playlist when I plug it into the car. The Random button at that time will just randomly play among the Playlist. To get it back to random among all the songs, I just go into the menu, view all songs and pick something at the top of the list. As soon as I hit Random I can then hit Next and I'm on my way.
- Merg
I checked today - my problem ONLY happens with podcasts. I listened to a song last nite - stopped it halfway through. Turned off my car. Got in this morning, turned on the car, hit the "on" button on the radio - song picked up right where I left it.
Then, I turned the radio off for 10 minutes while I drove. Turned it back on - same thing, it picked right up. However, if I do either that with a podcast, it will keep playing, for some reason......(although, I believe turning off the car DOES pause the podcast...it only happens while the car is still running and the radio is turned off).
The most recent firmware was provided with the map update for the Navigation System that was available starting this past January. If you hit the Random button and it first goes to Album Random and then just Random, you have the most recent update. If you don't have the Navigation System, I'm not sure what the most recent update is for the Audio system.
As for the Podcast not working correctly, I'll try to get one on my iPod and see what happens.
- Merg
I've never spoken with Infinity, but when i was having some random problems updating to the new firmware, Map&Soft referred me to another company, Hyundai Autonet which, i believe, developed the navi software. I can't seem to find the number they gave me to office in Tustin, California. But if you call Map&Soft's 800 number, they should be able to refer you.
This is with the 2009 Limited and 120gb iPod Classic.
I'd also like a true Power Button. If I hit Power, I want the system to turn off. If I want the Nav system to display, I'd hit the map button.
- Merg
Where did you see this "test" update on their site? As per the site's quality it had defninitely improved over the last 10 months.And while the price of $199 is a little steep, if you jump on board an pre-order the update when it somes out, they will discount it by 40-50%.
- Merg
Hitting the random button immediately starts playing a different song randomly without waiting for the current one to finish.
Otherwise, it plays the files fine, and the sound quality is great.
Also, I should not have to turn the radio off in order to pause the iPod. There should be a pause button available to me on the screen.
- Merg
Its still listed under 2009 Sonata when doing a search on their site.
40-50% off would make it an easier pill to swallow.
I tried a 32GB stick with 700 folders and 20+GB of music. It locked up the system with USB errors for any USB stick. How much music/ how many folders did you have?
Do you know anyone who's suceeded in finding out the limits? I had several other posts here asking similar questions. One answer said 128 folders; hopefully, that's not it.
I might buy a Santy would would like to mount the Iphone where "I" want it and I can't with this darned short cord. Maybe 2 cords could be spliced together???
Also, has anyone tried to rewire the USB/Aux box to behind the dash or anywhere else? I was thinking if I could remount it somewhere, having the cord in a permanent, hidden area.
It might be possible to just get a straight USB extension cable and an extension cable for the audio jack part of the cable. I would aasume that the hardware for splitting those functions are done in the Hyundai cable so it shouldn't matter that the cable is being extended.
- Merg
If I wanted to go to Aux to retain the iPhone's screen control, yet avoid decreasing sound quality by Aux'ing out the top headphone jack.....
Does anyone see a reason why this iPhone to 3.5mm wouldn't work to give me better sound?
http://www.amazon.com/inspiretech-iPhone-Auxilary-Audio-Cable/dp/B002ARDJZ4/ref=- sr_1_2?ie=UTF8&s=electronics&qid=1250551066&sr=1-2
I went on the Hyundai Accessory store website and found this information for you:
Will work in the following 2009 vehicles:
Elantra Touring
Sonata
Azera (non-navigation units)
Entourage
Santa Fe
Veracruz (non-navigation units)
Genesis
Works with the following iPod models:
- It is compatible with late model iPod products produced Irons mid-2004 on (4th Generations iPods, all Nanos, etc)
- This would include most iPod devices with the smooth front "Click Wheel"
- Operates with all Videos, Nanos, Color displays, Photos, iPod Touch
- Does not support Shuffles or the early Touch Wheel and Scroll Wheel models
- Early model functionality may be limited, while later advanced models may provide more options,
- Testing with the new Apple iPhone is not completed. Appropriate information will be distributed as available.
Here is the link to the website:
http://www.hyundaiaccessorystore.com/hyundai_ipod_cable.html
I hope that info helps.
The iPod cable charges the iPod’s battery when the vehicles key is on. The iPod may not turn off with the key, so confirm the iPod is off to avoid battery drain on the iPod.
Forgotten" but you have to check if it turns off. Some people have recommended you turn the radio back radio and then it will go off.
It is under warrenty make it the dealers problem.
You would also have to repay for XM for the new radio; it's tied to the specific receiver you have it on, and is not transferrable except under some rather extreme cases (theft, for example)
I know this is strange, but you may actually do better to scour a junk yard or two to see if you can find a late model Sonata/Azera/Genesis/etc, with the capabilities you want that's been totaled in an accident; then you know exactly what you're getting, and you can add the features you want. May not work for you (after all, the MP3 ports won't be in the correct spot....), but it might work.
Dealers are, of course predisposed to blame something else for any problem if they can. If you can't budge them you may have to do your own research by plugging in a temporary radio to eliminate that possibility, then replacing the car antenna with a temporary whip. If that fixes the problem, then it is somewhere in the car antenna If you connect the temporary whip at the radio, you check the cable. A car audio shop should be able to do these tests for a lot less than buying a cheap radio.
The other solution is to tell the dealer to replace the rear tint with whatever he sells, If that does not fix the problem, and your radio works less well than those of other cars the dealer owns, then the ball is firmly in his court, and there should be no charge for the tint replacement.
Thanks, John
