Chevy S10 - GMC S15 and Sonoma Repair Manuals
alejandro1
Member Posts: 2
Do you know where I can buy a repair/maintenance manual for a Chevrolet S10 pick-up truck, year 2002?
i have an 1986 Chevy s10 2.5L 4 banger, 2wd pickup. I've put over $3000 into several new systems trying to get it running again. Fresh rebuild, put 2000 miles on it, then started acting up. has new computer, new starting/charging systems, new fuel delivery system (TBI base unit and injector, pump, filters, fuel pressure regulator), new ignition /timing system. as one of my friends put it, i've changed just about everything on that engine but the paint. still wont run. will start maybe twice a week, but wont run consistantly at all. if i cant get this truck running consistantly i'm putting it in the junkyard and be out $3000. HELP!!!
was recommended that i rewire it..cant find a complete wiring harness to do this with. we know the problem is electrical but we cant find it. This truck has been in 6 different electrical and automotive repair shops and NO ONE can find the problem.
HELP!!!!!!
Dubbledukes :mad:
ray
I'll answer anyway, in case it helps someone else who is making this same mistake..
You have long since past the time to take the truck to a professional who knows what he is doing. Your hit and miss approach, and throwing money and parts at it in the wild hope you may guess correctly, it costing you way too much money, and you are replacing many un-needed parts. It's nice to try to learn to do your own maintenance, but you are in way over your head, and all you are accomplishing is wasting your money and frustrating yourself.
You are not saving money when you buy many unnecessary parts, and spend so much time on the problem. Take it to a knowledgeable technician and he will have the problem solved in a hurry. One hour should be all a good mechanic would require to locate the trouble. Must longer than that, and you need to change mechanics. That means, at today's going rate, It will only cost you about a $100.00 bucks to find the problem. How much time and money have you wasted already, guessing and hoping?
Like Kenny Rogers said, "You got to know when to hod 'em, and know when to fold 'em..!"
The sludge in radiator wouldn't cause the proble, neither would the cap. Pull hose off the heater radiator to check circulation.
If the water is circulating and not hot, then the water isn't hot. Worst and last possibility,.... blown head gasket.. , but lets eleminate the little things first...
THEY HAVE COMPLETE SET FOR REPLACEMENT.
truck has new u-joints new drive shaft carrier bearing, new tires even though that has nothing to do with rpms... other than that truck runs great. No engine lights nothing. Even swapped the whole drive shaft from a 99 I have that has no vibration and it still vibrates. Now here is the catch. I took the back part of the drives shaft out and ran it up to 80 mph on a lift ... smooth as butter. but you can have the truck in neutral and it still vibrates when you rev it. Explain this one. Please.
In: Chevy S-10 [Edit categories]
Compare Ford Super Duty®www.southtx.texasford.com
Compare the Ford Super Duty with a Dodge Ram Heavy Duty.
Ads Improve
Answer:
On a 2000 model year, 2WD w/ 4.3 L motor the actual pump sits down below the front bumper, on the truck's right side and behind (i.e. above) a splash guard that runs the width of the underneath. The splash guard is horizontal w/ the ground and has 4 bolts that are easy to remove. A couple of small hoses and electrical connectors attach to the pump, which is maybe 4 inches across and dark colored (black plastic cap on one end).
Read more: http://wiki.answers.com/Q/Where_is_the_secondary_air_injection_system_located_on- _a_chevrolet_s-10#ixzz1LOQr1Nsq
