What happened to standing behind your product and not there just for the money.
Thanks for letting me vent......
Have you also looked through the Technical Service Bulletins for items that may relate to your conditions? I found that to do the most good. Yes, you will be doing some of the work that the tech should be doing but by identifying the problem and having printed the TSB will save the tech from attempting to look it up as there are literally hundreds per vehicle.
http://www.alldatadiy.com/recalls/index.html
If you want the detailed report you will have to fork over $27.00 for a years membership that also allows you to access repair info on your truck.
During the warranty period of my Silverado, my file exceeded 2" and the dealer supported me when the GM rep called to find out my status for them to try and deny buyback. With all the mods I had done on the truck a buyback wasn't practical so was offered the 5 year/100K miles bumper to bumper GM extended warranty at no charge.
I am from GM Customer Service. I apologize that you are experiencing problems with your vehicle. Can you please email me more information so I can look into the situation further? You can access my email by clicking on my name. Thank you,
Mariah GM Customer Service
Being a GM CSR must keep you busy. Do you know if GM will be assigning CSRs to sites like pickuptrucks.com and GM-trucks.com? Just curious.
Dean
At this time I don't know if they are going to put on those sites. I will let them know about your suggestion though. Thank you,
D
We also have a Hyundai & have never dealt with a finer run company, never a issue with warranty work, kept well informed of recall glitches, the way it should be, maybe I was spoiled!! The GM customer serviceroaming on these forums has asked me to contact them, with 11/2 years dealing with this issue & GM customer service & service depts I remain skeptical but opptimistic, I will post my results, I am done talking about it with them I need action! Thank you again for your assistance.
Any suggestions or ideas to cause and fix?
I am from GM Customer Service. Can you please email me more information about your situation so I can look into your concern? You can find my email by clicking on my name. Thank you,
I have checked the trans fluid hot and it is withing specs so I am concerned about the tranny since I plan on keeping this truck for a long time.
Any help would be appreciated and I am taking the truck into the dealer this week for review of the problem.
Thank you for getting back with me. How long has the condition been present in the vehicle? Can you please email me so I can get some more information from you? If you click on my name you will see my email. Thank you,
I had thought I would trade my truck in on a new vehicle but since I have been reading about all the tranny troubles with the 6 speed automatics I will wait and drive it till the wheels come off.
Look through previous posts to mine and yours and see ones wtih Mariah of GM Customer Service and see if you can get some relief with her on the case. Good luck on you needed repairs.
I have a 2000 Chevy Silverado 1500 Z71 with 5.3L. I had a problem arise a year ago. Whenever I would drive on a long trip and then come into a town, when I would take back off from a stop sign or light, the transmission would shift hard into second and third gears. I had the transmission flushed and filters changed. They found one of the solenoids broken ($5 replacement) in the transmission. Well this past weekend I was pulling my boat back from the lake when it started to do the exact same thing. Is the transmission fried? I need to find something out soon. I don't want to pull my camper or boat anymore if the transmission is going out.
I am from GM Customer Service. Can you please email me more information about your situation so I can look into your concerns further? You can get my email by clicking on my name. Thank you,
When I purchased the truck apparently it came with a yoke that was not sufficiently greased as many times this manifested itself as though I had been rear-ended lightly when stopped at a light. The GM dealer greased the yoke and this helped. But now I have this problem. Could it be that the yoke has to be greased again ? Does the yoke have to be greased several times over the life of the vehicle ?
I have checked the fluid level and it id right within specs and the color is still bright red. I've never used the truck to tow anything. Any Ideas ?
I apologize that you are having issues with your vehicle. Can you please email me more information about your situation so I can look into it further? You can get my email by clicking on my name. Thank you,
I have a 01 1500 4.3 po300 flashing engine light. let me say I have a scanner and consider myself to be somewhat knowledgeable. but I am looking for ideas.
I have po 300 right bank 2 4 6 misfires engine obviously lacks power. barely runs . I have -35 degrees cam retard. Wont run long or fast enough to do crk learn. I think it is symptom of misfire not cause. I have pulled exhasut off pass side to eliminate the cat. doesnt change it without cat c onected. I got it to run long enough to set o2 code but it was for the heater circuit. I have read that the injectors should have 11-14 ohms resistance if checked at the pins in the upper plenum Anyone heard that. Mine do not have between 5 - 8 ohms. on the 6.. Is it likely all 6 injectors went bad at once. the fuel trim is being cut off on the even bank -25% while odd side is dumping +25%. I want to believe its come down to pcm ,spider,02's, possibly maf but it doesnt change and has comparable readings to my v8 burban. i am open to ideas distributor, but that would explain timing but not dumping of fuel
fuel pressure is koeo 62psi, and 58 barely running. Thanks
Thanks for any help... I'm going to go cry now.
I apologize that you are experiencing an issue with your vehicle. Can you please email me more information about your situation so I can look into it further? You can get my email by clicking on my name. Thank you,
Just tired of the run around, and want to drive my truck!
Please help, any ideas?
Have you contacted the people you bought the vehicle from that there is a concern with the vehicle? Has anyone looked at the vehicle for the concern? Thank you,
I would contact the dealership about the problem and let them know what is going on. I would have a service tech ride in the vehicle with you so they can experience what you are talking about. I doubled checked for you and your 2005 vehicle doesn't have a powertrain warranty. Please keep me informed on how it goes. Thank you,
